Belt tension adjustment
Pagina 3 / 4
Rainer
(@rainer-2)
RE: Belt tension adjustment
Not everyone wants to screw on a new printer themselves.
I would try to loosen the belts and move the X axis all the way to the front.
Then I would slightly loosen the screw of the metal bracket on the X axis.
Now the X axis should be parallel to the frame.
I would gradually tighten the screws again and observe whether and when the gantry starts to warp again.
I would either try tightening only the screws that do not cause warping or try using shims.
Then bring to the recommended tension and check whether the gantry is still parallel.
This would at least allow you to narrow down the sources of error.
Postato : 21/02/2025 9:34 pm
LordMelkor
(@lordmelkor)
Posted by: @yamsooie
I just got mine today and it has the exact same issue, only the gap is 2-3mm.
Ugh. I have the same issue. Are y’all opening tickets with Prusa?
Postato : 26/02/2025 3:11 am
George
(@george-4)
I'm waiting for my kit, and i've added then accelerometer as well in the order.
Is there a way to check the belt tension using the accelerometer? If not, shouldn't there be an option like this, especially for the Core One, seeing how important it is for them to be tightened the same?
Postato : 06/03/2025 10:13 am
Posted by: @george-4
Even better, there is a way to check the belt tension without the accelerometer. 😉 Just use Prusa's regular tuning app, which now includes instructions for the Core One and knows about the 85 Hz target frequency for its belts' resonance.
Postato : 06/03/2025 4:56 pm
George
(@george-4)
I know about the app, but when i used it with my mini, it shows the belt as too tight, even though the PETG tool has it as being just right, sitting in the middle of the marks.
also, when i tried using the app, the reading kept changing. So its up to if you are strumming just right, holding the phone at just the right place, and your phone’s mic hole is gunk free ;). Even if it looks clean, lint and dust gathers.
With a built in accelerator, i guess it could start vibrating and then telling you “yeah, keep going, keep g… There!”
Postato : 06/03/2025 5:02 pm
Wouldn't there be a challenge in that the resonance frequency of the oscillating print head is affected by both belts in parallel? No matter whether you excite the motion via one or both motors at a time, both belts are always pulling at the print head and are hence contributing to a compound spring constant.
It might be impossible to distinguish two correctly tightened belts from one too tight, another too loose, via the accelerometer. Or is there some clever trick which other CoreXY printers use to tell the two contributions apart?
(I believe the Bambu Lab printers use the accelerometer to diagnose that "something is wrong" and instruct you to check the belt tension. But they then use their spring-loaded, semi-automatic tensioners to actually set the individual tension on the two belts.)
Postato : 06/03/2025 5:12 pm
George
(@george-4)
Hm. Don’t know what bambu does to be honest. If only one motor is pulling at a time, it would still have the wrong readings you mean since its coupled with the other one.
Postato : 06/03/2025 5:15 pm
Yes, that's what I would expect. Imagine a mass suspended from the ceiling on two springs which are arranged in parallel. If you wiggle one of the springs to excite a vertical oscillation of the mass, the other spring will still contribute to the total spring constant. (Which, together with the mass, determines the resonance frequency.)
Postato : 06/03/2025 5:22 pm
Vedel
(@vedel)
Utenti
I had horrible luck with the belt tuner in the app, and ended up using the website version instead. That worked much better.
Postato : 06/03/2025 8:48 pm
2 persone hanno apprezzato
Brian
(@brian-12)
There is no way to check belt tension with the accelerometer.
The only good ways to measure belt tension is via frequency (belt tuner) or by measuring flex.
Postato : 07/03/2025 1:47 am
ormandj
(@ormandj)
 So update on my saga. My old printer was returned, new one sent, with the belts both at 85Hz using the tuner, there was a _slight_ angle to the X axis where it would not sit flush on the right side when the left side was flush. Prusa support ended up having me loosen the belt on the left side, in my case, prop something small in front of the left stop, and very gently pull on the right (I assume bending the brackets gradually), rinse and repeat multiple times, re-tightening the belts each time checking for skew.
I am not suggesting anybody else follow this procedure, but clearly Prusa support is aware of this issue. You have to be extraordinarily careful and apply only very light tension, and repeat multiple times. You can easily break the plastic parts if you use too much pressure, so I highly suggest engaging with Prusa support before doing anything.  It's a lot of work, but I can now report my Core One has both belts at 85Hz and now sits flush against the end-stops at the front on both sides.
Postato : 13/03/2025 9:06 pm
1 persone hanno apprezzato
So even after they have been made aware of the problem, they still ship printers where the gantries are not properly squared? And instead tell customers to bend things in the field, risking damage to the bearings? I am not impressed.
Postato : 14/03/2025 6:14 am
kara
 kara
(@kara)
Utenti
Just a heads up: I had approximately 5mm space on one side which was kind of possible to compensate by different belt tensions on left and right side but calibration of the Y axis would fail. It turned out I did mount the X axis pulley the wrong side (teeth further from the motor instead of closer). After reversing it, it was aligned perfectly.
The step that needs to be double-checked is https://help.prusa3d.com/guide/5-corexy-assembly_835522#843284.
Postato : 05/07/2025 7:53 am
Ckobar
(@ckobar)
Just to encourage everybody who is building his kit, conversion or preassebled.
maybe I was just lucky, but when building my conversion kit I took special care when installing the xy assembly. I had to unscrew the linear rail from the brackets several times, bend the brackets ever so lightly and test again. Eventually I got it square. ( wheel tilting the xy frame slightly the linear rail slides to the front and back without gap.
Upon finish I tensioned the belts with the tuner to 85—87 herz. Since adjusting one the other changes as well, so that took quite some time. In that phase I compared the belts by ear.
and I was very surprised, that the all calibrations successfully finished on the first run.
so it’s doable 😁
btw. I whited to install the vesonite bearings on y. But I found there where binding when tightening the linear rail on the brackets. Seems the normal bearings ar much more forgiving.
Postato : 06/07/2025 8:10 am
Posted by: @ckobar
Did you adjust the distance and parallel alignment of the Y rods? The two rods over-constrain the movement of the X gantry, and I am surprised that Prusa's assembly instructions don't include this step. (Or at least they did not when I built my early kit.)
Loosen the screws which hold the mounting blocks for one of the Y rods, then push the X gantry all the way back and forward. This will nudge the Y rod into the correct position. Lightly tighten the mounting block screws, repeat the X gantry movement, then tighten the mounting blocks fully.
Postato : 06/07/2025 8:16 am
Ckobar
(@ckobar)
Good advice. I will check .
Postato : 06/07/2025 6:35 pm
Cedric Hurth
(@cedric-hurth)
Utenti
In my case, the X-axis motor pulley was too low. I had stupidly adjusted it with the same side of the provided tool than the Y-axis one.
See attached picture.
Thanks to Prusa tech support (Nikola) for finding it out from my pictures.
Postato : 22/09/2025 1:13 pm
GROG
 GROG
(@grog-2)
Utenti
I purchased a kit and managed to complete the calibration steps.  (That took a while) Then after printing 4 or 5 items the Core One started failing calibration checks.  Specifically, it's generating homing errors and precise refinement errors.  Any guidance which can be provided would be appreciated.
I'm focusing on adjusting belt tensioning.  Quick gantry alignment is a particular focus.
4. Check the alignment with the belts still loose, and carefully push the gantry forward. Since the loose belts will not pull it all the way, you may need to guide it by hand. Verify that there is no gap on either side at the front position.
  • When I've loosened the belt tensioners I'm unable to bring the gantry flush with the front stops as suggested. So far I tighten both sides until I can't detect slack by tapping the gantry against the stops on left and right front sides.
  • I've updated the bios to support the harmonic based tuning of the belts but don't have the knack of dialing it in within the required frequencies.
  • At the moment, I have the gantry within the frequency ranges, but it's still failing with the precise refinement error.
Postato : 23/11/2025 12:09 am
Posted by: @grog-2
You have to be very careful when making this adjustment. Loosen the belts again and bend the gantry by hand until it is flush with the stops when you bring it forward. Next, when you are tightening the belts you must turn each screw by the exact same amount. So left one 1 turn, right one 1 turn etc until the belts get tight. Then switch to 1/4 turn each alternating between left and right. If you don't do this you will bend the gantry and the Y calibration test will fail.
Postato : 23/11/2025 2:51 am
mnentwig
(@mnentwig)
When tightening the screws, you can do (minimal!) gantry adjustment by imbalancing the screws. Otherwise it may come down to sheer luck whether you tightened them sufficiently in balance or not (very small adjustments, like 1/12 turn "hour-on-the-clock-face"):
Pulling the screw on the left side will move the left gantry end towards the door and vice versa. Release the opposite side by the same amount and if in doubt, re-run belt calibration to bring total tension back on target. Those tunings are very sensitive, that is, 1/8 turn makes a significant difference.
Postato : 23/11/2025 9:33 am
Pagina 3 / 4
