Bed Heating does not reach the set temp of 60 degrees
Since two days my new CoreOne has a problem witht the temperature on th print sheet. I use the original Prusa PEI sheet and texture sheet. As some of my prints the alst two days failed, i checked for the temperature of the print sheet. Set to 60 i only can measure 45 degrees, i have to put the temperature to 80(!!!) degrees to rech a bed temperature of 60 degrees. What goes wrong?? The chamber is closed and the last weeks after delivery all worked fine. I cleaned my printsheets several times until I found that the temperature ist too bad. Any suggestions?
Opublikowany : 09/05/2025 10:04 am
