Auto retraction question
gb160
(@gb160)
Hi, I'm interested about the auto retraction feature thats implemented on the core one, I think it's used after filament has been loaded, and also at the end of every print.
How would I go about figuring out exactly what goes on when this happens?
I'm interested in reproducing the exact steps via gcode.
I presume I would need to look somewhere in the Core one firmware files to see exactly what goes on, but have no idea where to start looking.
If anyone can offer any help or insight it would be greatly appreciated.
Thanks.
Posted : 13/10/2025 12:01 pm
Posted by: @gb160
Thanks.
I believe that is the M600 g-code (filament change) which would be here: M600.cpp
This post was modified 2 days ago by hyiger
Posted : 13/10/2025 3:13 pm
RE: Auto retraction question
For some odd reason, it looks like Prusa doesn't merge branches back into master. This might be more accurate (i.e. up-to-date): https://github.com/prusa3d/Prusa-Firmware-Buddy/blob/v6.4.0-RC/lib/Marlin/Marlin/src/gcode/feature/pause/M600.cpp
Posted : 13/10/2025 3:37 pm
gb160
(@gb160)
Posted by: @hyiger
Thanks buddy, I'm not 100% sure this is what I'm looking for, but it's a start.
Ideally I need to look at what commands are getting executed when a print ends...the printhead moves to park position then the important bit I'm interested in...it purges a tiny bit of filament then a very slow retraction (you hear the retraction going on and the filament gets fed back out of the printer)
My understanding is this is to relieve any pressure built up in the nozzle, and it is very effective in stopping any filament oozing out of the nozzle. This is the exact behaviour I want to reproduce in Gcode.
I need to reproduce this mid-print, (don't ask 😂), but my attempts so far have failed.
Any idea where I would find that ?
Posted : 14/10/2025 7:04 am
Steve
(@steve-5)
@gb160,
The operations sequence to which you are referring is the "ramming" to form the filament tip followed by a retraction to pull the filament out of the hotend to prevent ooze.  This sequence can be replicated in g-code by sending move commands to the extruder motor.  For reference, here is the link to the Buddy firmware g-code which may be helpful in designing the custom code; buddy-firmware-specific-g-code-commands
Regards,
Steve
Posted : 14/10/2025 1:05 pm
Posted by: @gb160
OK, I think I know what you are after. I've been poking around in the firmware code and found this: FILAMENT_RUNOUT_RAMMING_SEQUENCE  So as @Steve pointed out you can send this to the extruder.
I guess something like this in the "Before Layer Change G-code"
; Ram filament before layer change in middle of print
{if layer_z > max_layer_z / 2}
G1 E7 F1500
G1 E-50 F2700
G1 E-5 F50
G1 E-50 F1500
{endif}
This post was modified 10 hours ago 2 times by hyiger
Posted : 15/10/2025 1:29 am
gb160
(@gb160)
Posted by: @hyiger
Posted by: @gb160
G1 E7 F1500
G1 E-50 F2700
G1 E-5 F50
G1 E-50 F1500
{endif}
Man you're a star ! Thanks for this.
Im gonna give this a try later.
I won't be needing it on layer change, hopefully just need to use it once.
Long story short I need to basically stop printing altogether for a short period of time (while other stuff is going on) , and oozing with certain filaments has meant I have to babysit the printer during this process.
I've got it very close with a simple extrude then a slow retraction, hopefully this approach will solve the problem once and for all.
Posted : 15/10/2025 7:38 am
gb160
(@gb160)
On these numbers ,  i think the approach is right, but I cant see those numbers being right for what I want.
eg, unless im interpreting these numbers wrong, thats retracting 105mm of filament being retracted. Surely thats going to back the filament completely out of the extruder? ie, to change the filament.
I'd love to know exactly what speed/lengths Prusa uses for this 'ramming' just at the end of a print... They back it out enough to stop the oozing, but obviously nowhere near the amount thats used for filament change.
This is definitely the right path though. Thanks for your assistance mate ( and @steve-5 )
Posted : 15/10/2025 10:41 am
