After Core One + upgrade to Core one filament will not pass new assembly
ke5wth
(@ke5wth)
after i upgraded the filament adapter to the core one plus, filament will not pass more than 2 inches... seems to be blocked by something.
Best Answer by FoxRun3D:
The side filament sensor housing seems more sensitive to proper screw tightening than it should. I had a different but related issue when I upgraded my Cores. One would show as always inserted even if there was no filament in there. Turns out I had to loosen the two screws that hold the two main parts of the sensor together. Took me forever to figure out.
Publié : 10/01/2026 11:51 pm
RE: After Core One + upgrade to Core one filament will not pass new assembly
De-assemble it, loosen the central screw and make sure the lever can still move. Make sure you can pass a small piece of filament through before closing it up again and putting it back.
Publié : 11/01/2026 1:04 pm
1 personnes ont aimé
Mchad65
(@mchad65)
Mine is tricky too. I May disassemble and try loosening it after reading this. I found if the inserted filament has a good curve to it, that is mostly what causes the difficulty. I either try and straighten it by counterbending it, or it will also work if I rotate the filament in the tube to essentially turn the bend away from what it’s catching on. Hope that makes sense…
Ce message a été modifié il y a 5 months par Mchad65
Publié : 11/01/2026 1:54 pm
Publié : 11/01/2026 2:48 pm
Jürgen found out that if the magnet on the lever extends out more than 1mm, it can bind on the cover.
I'm in the middle of a project to completely redesign the side sensor to use an optical wheel. I might abandon it though since it'll become superfluous once I install the INDX.
https://github.com/hyiger/filament-monitor/blob/master/README.md
Publié : 11/01/2026 5:32 pm
k1mu
 k1mu
(@k1mu)
If you're able to insert the filament past the ball, to the point where the insertion is detected because the sensor triggers, but then can't push it further, take a look at the PTFE tube between the sensor and the extruder.  You may have pinched the tube when trying to remove it during the upgrade.  There's not a lot of extra room.
Publié : 12/01/2026 3:47 pm
ke5wth
(@ke5wth)
THanks, i loosed the center and two sides and remounted. Filament passes now. Thanks
Publié : 14/01/2026 2:23 am
