Advanced Filtration G-Code
Staldy
(@staldy)
Hello there,
I installed the Advanced Filtration on my Core One using this mod, In the menu, I did not enable “Filter all materials” (this is the English equivalent of what I see in the French).
After printing ABS, PC-CF and TPU for a few days, I switched back to PLA and noticed that the filtration system was still running. Since I disabled it for the materials mentioned above, this doesn’t make much sense to me, as PLA doesn’t require filtration.
I already control the top vent using G-code, and I would like to do the same with the filtration system so I can have full manual control over the rebel filtration.
M870 {if filament_type[initial_tool] =~ /.*(PLA|PETG|FLEX).*/}O{else}C{endif} ; Open vent for low temp materials
However, I’m a bit lost regarding which G-code to use. I found references to M147 (filtration) and M148 (post-print filtration), but I also saw people mentioning M106 P4. With all this information, I’m not sure what the correct thing to do, I would like to have a fonctionnal G-Code:
  • No filtration for PLA, PETG (and probably TPU, correct me if I'm wrong)
  • For ABS and PC-CF, I believe only post-print filtration is needed due to the high chamber temperature. Is that correct?
Thanks in advance for your help.
Posted : 18/01/2026 7:16 am
oftherocks
(@oftherocks)
RE: Advanced Filtration G-Code
Was looking for this answer also...
Posted : 12/03/2026 3:43 am
The advanced filtration fan is #3 so
M106 P3 S128 ; fan 50%
M107 P3 ; fan off
Can use it in end-gcode something like
; Run filtration for 3 min after print
M106 P3 S255   ; filtration fan full
G4 S180        ; dwell 3 minutes
M106 P3 S0     ; filtration off
Posted : 12/03/2026 3:52 am
3d0zer
(@3d0zer)
Hello Hyiger,
Can you please tell me how you found these codes as Prusa seems to say for filtration and Core One these codes should work:
See under G-Codes Subtitle:
https://help.prusa3d.com/article/advanced-filtration-system-for-prusa-core-one_887189
G-codes
Starting from firmware 6.4.0, it is possible to use two G-codes to control the chamber filtration activation. Note that the G-codes will override the menu.
M147 will set the Automatic Filtration and Post-print Filtration to ON. M148 will set the Automatic Filtration and the Post-print Filtration to OFF. Note that the code needs to be set in the starting code before the purging code.
Posted by: @hyiger
M107 P3 ; fan off
Just a guy with a Core One L on a 3D Journey
Posted : 08/06/2026 11:01 am
3d0zer
(@3d0zer)
In this topic I made, it seems that the codes are put in the wrong order to work:
https://forum.prusa3d.com/forum/prusaslicer/advanced-filtration-and-ventilation-temp-regulation-settings/#post-794130
Posted : 08/06/2026 12:10 pm
Posted by: @3d0zer
Hello Hyiger,
Generally I find this stuff by digging around in the firmware source code because Prusa's documentation is not always up-to-date or 100% accurate. One thing to keep in mind is that some g and m-codes act as macros. That is they may cover the behavior of multiple individual g-code underneath. I guess a shorter way to say it is there are multiple ways to do the same thing.
Posted : 10/06/2026 7:57 pm
3d0zer
(@3d0zer)
I wonder why a tech firm as Prusa does not have good documentation of their own software.
It should really not be that hard, but it seems as far as I read the the people / users always have to puzzle to get the answers.
Anyways, I love my machine, hope there will be more clearity later.
Posted : 10/06/2026 8:24 pm
Posted by: @3d0zer
Prusa is much better than other firms in this regard. Example, in one extreme, Bambu Labs doesn't publish their g/m-codes at all (at least not that I'm aware of). I had to back them out using an AI.
I would say Prusa's documentation is maybe a year out-of-date. But no more than that. Some of the Core One specific g/m-codes are still undocumented (last time I checked) pertain to the chamber fans and automatic vent.
Posted : 10/06/2026 8:31 pm
