					                		Whats on the USB stick - missing due to box damage - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/</link>
                <lastBuildDate>Sun, 19 Apr 2026 05:20:36 +0000</lastBuildDate>
                        <title>RE: Whats on the USB stick - missing due to box damage</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/paged/2/#post-741982</link>
                        <pubDate>Sun, 23 Mar 2025 19:54:00 +0000</pubDate>
                        <description><![CDATA[My prusa memory stick that came with the Core One failed today.  Nothing special happened. I finished one print, then sliced and sent another print to the machine - which didn&#039;t start.   I&#039;m...]]></description>
                        <content:encoded><![CDATA[<p>My prusa memory stick that came with the Core One failed today.  Nothing special happened. I finished one print, then sliced and sent another print to the machine - which didn't start.   I'm looking at it unsure what was wrong - slicer on Prusa Connect tab showed a failure to upload the model to the printer. So back looking at the printer - no clue. Turned it off and on again and it came up complaining there was no memory stick installed.</p><p>Unplugged it and put it in my PC, came up as a RAW unformatted drive. Formatted it as FAT32 and back in the printer and all is working again.   Only question is how this could have happened.</p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>PaulGregg</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/paged/2/#post-741982</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/paged/2/#post-741785</link>
                        <pubDate>Sat, 22 Mar 2025 16:10:58 +0000</pubDate>
                        <description><![CDATA[EDIT: It seems that the &quot;Power Panic&quot; function is essentially the latter option I had assumed: Printer detects a power outage and still has enough power in the capacitors to place and leave ...]]></description>
                        <content:encoded><![CDATA[<p>EDIT: It seems that the "Power Panic" function is essentially the latter option I had assumed: Printer detects a power outage and still has enough power in the capacitors to place and leave everything in a defined state. So, does "Power Panic" replace "power loss recovery" in the more recent Prusa printers?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Jürgen</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/paged/2/#post-741785</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/#post-741783</link>
                        <pubDate>Sat, 22 Mar 2025 15:56:14 +0000</pubDate>
                        <description><![CDATA[Posted by: @walter-layher If you are using the &quot;power loss recovery&quot; feature, the printer will write the current state of the print job to the USB drive. This happens after every line of gco...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="523574" data-postid="741771" data-mention="walter-layher"><div class="wpforo-post-quote-author"><strong>Posted by: @walter-layher </strong></div><p>If you are using the "power loss recovery" feature, the printer will write the current state of the print job to the USB drive. This happens after every line of gcode, I believe, otherwise it would not be very useful for recovery. Just do a line count on a gcode file and you will see how many write cycles there are for just one file. For instance the gcode for the Prusa Belt Tension Meter is half a megabyte and already has over 20k lines. This is probably also the cause for the drive getting very hot, which was reported by many users. USB thumb drives were no created for the purpose of being written to continuously and they will fail if treated this way. That is why it is not recommended to use them as e.g. a boot drive for an operating system.</p></blockquote><p>Ah, that would be an explanation for USB drives failing prematurely. I was not aware that this is how the "power loss recovery" works. I was assuming a separate buffered memory exists to remember the current state, or a "poor man's uninterrupted power supply", e.g. a gold cap which gives the CPU a few seconds to write the state to USB if (and only if) it detects a power outage.</p><p>I assume the recovery feature is enabled by default? I will disable it on my printer then, since power losses are very rare here. It would be interesting to know whether users who have encountered USB stick failure had "power loss recovery" enabled.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/#post-741783</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/#post-741771</link>
                        <pubDate>Sat, 22 Mar 2025 14:42:11 +0000</pubDate>
                        <description><![CDATA[If you are using the &quot;power loss recovery&quot; feature, the printer will write the current state of the print job to the USB drive. This happens after every line of gcode, I believe, otherwise i...]]></description>
                        <content:encoded><![CDATA[<p>If you are using the "power loss recovery" feature, the printer will write the current state of the print job to the USB drive. This happens after every line of gcode, I believe, otherwise it would not be very useful for recovery. Just do a line count on a gcode file and you will see how many write cycles there are for just one file. For instance the gcode for the Prusa Belt Tension Meter is half a megabyte and already has over 20k lines. This is probably also the cause for the drive getting very hot, which was reported by many users. USB thumb drives were no created for the purpose of being written to continuously and they will fail if treated this way. That is why it is not recommended to use them as e.g. a boot drive for an operating system.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Walter Layher</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/#post-741771</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/#post-741751</link>
                        <pubDate>Sat, 22 Mar 2025 13:57:52 +0000</pubDate>
                        <description><![CDATA[The one USB drive failure I had was after hitting the RESET button to recover from a filament loading error.  That was when my printer was only a couple of weeks old.  I wish I knew how many...]]></description>
                        <content:encoded><![CDATA[<p>The one USB drive failure I had was after hitting the RESET button to recover from a filament loading error.  That was when my printer was only a couple of weeks old.  I wish I knew how many others failed during a RESET vs all other conditions.  My hypothesis is that when the RESET occurs while writing to the drive, it gets corrupted.</p><p>I wish Prusa would just get rid of the RESET button and revise the firmware to allow controlled recovery from errors vs uncontrolled RESETs.  In other words, when there is a problem such as a filament loading error, there should be more than just an option to retry.  There should be options to retry OR abort, which would methodically close the files as it recovers.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>LarGriff</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/#post-741751</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/#post-741749</link>
                        <pubDate>Sat, 22 Mar 2025 13:37:54 +0000</pubDate>
                        <description><![CDATA[I wonder if people are deleting the files once printed in effect feeing up the space again and this space is then written to again and again so in effect it is always the same flash area whi...]]></description>
                        <content:encoded><![CDATA[<p>I wonder if people are deleting the files once printed in effect feeing up the space again and this space is then written to again and again so in effect it is always the same flash area which is used over and over.</p><p>If this is the case, then leave all existing prints and just keep adding to the drive until it gets full, only then delete everything and start the process again, this way you use all the flash memory. I highly doubt that wear levelling is implemented in these usb drives.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Chocki</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/#post-741749</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/#post-741735</link>
                        <pubDate>Sat, 22 Mar 2025 12:11:58 +0000</pubDate>
                        <description><![CDATA[Does the Prusa firmware write to the USB stick frequently? (or at all?) Assuming that I don&#039;t capture video, will it use the USB drive to record log files, or to store any intermediate files...]]></description>
                        <content:encoded><![CDATA[<p>Does the Prusa firmware <em>write</em> to the USB stick frequently? (or at all?) Assuming that I don't capture video, will it use the USB drive to record log files, or to store any intermediate files?</p><p>I struggle to imagine that any USB stick -- even a very cheap one -- could be worn out in a matter of months via read cycles only. On the other hand, even a sloppy implementation of a FAT32 library should not be able to create any data inconsistencies as long as it only reads from the file system. Nevertheless, USB stick failures seem to be somewhat common with Prusa printers. Any ideas what might be going on there? </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/#post-741735</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/#post-741732</link>
                        <pubDate>Sat, 22 Mar 2025 11:56:20 +0000</pubDate>
                        <description><![CDATA[I ended up buying a 16GB Microdrive for just £4.29 which works a treat, no point in spending loads on a super large and fast drive when this does and is small enough to be unobtrusive yet ca...]]></description>
                        <content:encoded><![CDATA[<p>I ended up buying a 16GB Microdrive for just £4.29 which works a treat, no point in spending loads on a super large and fast drive when this does and is small enough to be unobtrusive yet can be grabbed and pulled out if needed to. (The USB socket is very tight on this printer)</p>
<p>I'm using PrusaLink for uploading print files to the printer, so the drive will remain plugged into the printer.</p>
<p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/d8ec6720-screenshot-2025-03-22-115432.png"><img class="alignnone size-medium wp-image-175337" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/d8ec6720-screenshot-2025-03-22-115432-600x500.png" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/#post-741732</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/#post-741069</link>
                        <pubDate>Tue, 18 Mar 2025 22:31:12 +0000</pubDate>
                        <description><![CDATA[You can use larger than 32GB USB drives, as long as they are formatted as FAT32. Windows is unable to format drivers larger then 32GB as FAT32, so you need to use a 3rd party tool such as Ru...]]></description>
                        <content:encoded><![CDATA[<p>You can use larger than 32GB USB drives, as long as they are formatted as FAT32. Windows is unable to format drivers larger then 32GB as FAT32, so you need to use a 3rd party tool such as Rufus to format larger drives. </p>
<p>https://rufus.ie/en/</p>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>steve457</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/#post-741069</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/#post-740873</link>
                        <pubDate>Mon, 17 Mar 2025 21:24:45 +0000</pubDate>
                        <description><![CDATA[I can recommend SanDisk Ultra Fit drives. They are from SanDisk and they are small. Perfect for that control panel.]]></description>
                        <content:encoded><![CDATA[<p>I can recommend SanDisk Ultra Fit drives. They are from SanDisk and they are small. Perfect for that control panel.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Biomech</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/whats-on-the-usb-stick-missing-due-to-box-damage/#post-740873</guid>
