Very large percentage shown for 'Absorbing Heat' readout
Frank
(@frank-8)
I happened to notice this while printing a test piece in PP.  Notice the very large percentage number for 'Absorbing Heat' readout?
Posted : 01/09/2025 5:50 pm
angular1673
(@angular1673)
RE: Very large percentage shown for 'Absorbing Heat' readout
Yep had that too. First 3% then 5% then this huge number starting with 4 like yours that kept changing a bit while keeping the amount of numbers, then back to 3% then 6% then back to  5% and then it was done 🙂
Posted : 01/09/2025 6:01 pm
Posted by: @frank-8
That could only occur within a few seconds after the Big Bang. On a more serious note, what version of the the firmware do you have installed?
Posted : 01/09/2025 6:18 pm
Frank
(@frank-8)
I checked my calendar, and the Big Bang was last year sometime, so I don't think that was the cause ;).
I have the latest firmware.  However, I believe the most salient fact is that I was printing with PP for the first time, with the heated bed temp set to zero.  I suspect that the obviously invalid percentage was caused by dividing the current bed temp by the target bed temp - i.e. dividing by zero, giving an indeterminate value.
On a related note, this is the first time I saw the 'Skip' option displayed (although I think it is there all the time), allowing me to skip the 'absorbing heat' step.  I now suspect that 'Skip' function was put in because (at least in part) because of this failure condition.
Posted : 01/09/2025 7:35 pm
It could be a divide by zero or one that the result is cast to a different type for display.   The value pictured is FFFF FFFF in hex so a 32bit number thats all 1's in binary
Posted : 01/09/2025 8:19 pm
Tim
 Tim
(@tim-21)
Firmware version?
Posted : 01/09/2025 8:45 pm
Posted by: @neophyl
That’s also -1 in 2’s complement.
Posted : 01/09/2025 9:19 pm
Posted by: @frank-8
Makes sense. Probably worth creating an incident in the GitHub repo. Definitely a bug
Posted : 01/09/2025 9:21 pm
