Toolhead parked position
cupu
 cupu
(@cupu)
Hello everyone,
I am (maybe stupidly) worried about where the toolhead parks after a print is done, namely the right back corner of the enclosure (as viewed from the front).
When assembling the printer we were told to put the print head in the front left position and make sure the pfte tube with the toolhead wire harness is not "too arced". But after a print is done, the toolhead moves to this (max x, min y .. I guess) position where the cable harness and pfte tube are very much arced. Is that a problem? If you finish a print and leave it like that potentially for days?
Maybe I am making a big thing out of nothing but I thought I'd ask.
Thank you very much.
Posted : 31/08/2025 8:13 pm
RE: Toolhead parked position
I don't think this is a problem. The cables and PTFE tube get actively bent back and forth all the time during printing. Having them sit still in a bent position should not cause much weakening of the materials.
Also, you might be remembering the build instructions incorrectly? The only caveat regarding the routing of the tube and cables which I can find is in step 6.43:  "Ensure the main cable is not too tight and does not pull the Nextruder backward." It's not about strain within the cable and PTFE tube itself, it's about pulling on the Nextruder (which could cause positioning errors during printing).
Posted : 31/08/2025 8:26 pm
cupu
 cupu
(@cupu)
Hi Jurgen,
Thank you for your reply. I do forget and misremember things all the time, including this occasion.
I am indeed referring to that section (thanks for finding), just below what you pasted is the line I was attempting to reference
The main cable does not form an excessively large arc.
For me , it feels that in the parked position the arcs are quite pronounced and all of my prints so far never actually reach that position. It's helpful to know other people are using it just fine and it's not a problem. I suppose I can always change the gcode to park it somewhere else. If this discussion advances, next time I do a print I'll take a screenshot of my parked arcs and post here.
Thanks again.
Posted : 01/09/2025 7:56 am
Posted by: @cupu
Hmm, interesting. I had been looking at the PDF version of the build instructions which I saved in early April when building my Core One kit (PDF having the advantage of being quickly searchable). And that version does not have the clause about the "large arc" yet, and neither the corresponding illustration which shows the two undesirable paths. That must be a later addition to the build instructions.
The way I interpret the "excessively large arc" caveat, it is meant to avoid situations where the tube & cable would not have enough room and get jammed against the left side wall. The "large arc" does not translate into "small bend radius" in my understanding. So I remain unconcerned about the parking position.
If you want to change the parking position via Gcode, you may encounter a surprise, by the way. There is a thread where a user was trying to change the parking position for a different reason, namely easier access to the nozzle for checking and cleaning. He found that the firmware seems to include a hard-coded command to move the extruder back to the rear right as the very last step after completing a print: https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/print-finish-parking-position/paged/2/#post-762777
Posted : 01/09/2025 12:17 pm
cupu
 cupu
(@cupu)
Hi again Jurgen,
Thank you for your answer. The term "large arc" does not seem to indicate "small bend radius" but I figured it could be something lost in translation as one of the undesirable paths you mention also does not indicate a large arc.
Good tip about the aparent firmware hardcoding. I will look more into it but I am less worried now than when I initially posted. So far I do a "home" command from the control menu after I am done with printing and that's good enough.
Regards!
Posted : 01/09/2025 2:22 pm
Steve
(@steve-33)
I am the person that originally posted the park and purge/retract position not being editable. It is indeed set in firmware which in my opinion a poor decision. I went into further detail on github and it is being "investigated". It's is difficult for me to remove the dangling filament cleanly due to limited movement in my shoulders and I did burn my forearm on one occasion! Problem is if you don't get every last bit off it's highly likely that nozzle cleaning fails on next print. I did contact support on this who were totally unhelpful quoting "we wont help with custom gcode", I explained I was partially disabled and they said "our printers are for all" total rubbish and it made no difference whatsoever with my request.  I believe that is discrimination which is illegal under EU law.  IF nothing further happens on this I WILL report them to the relevant authorities and we'll see how that goes for them..
Posted by: @jurgen-7
Posted by: @cupu
Posted : 15/09/2025 10:13 am
