					                		Thumb screws vibrating loose on Core One - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/thumb-screws-vibrating-loose-on-core-one/</link>
                <lastBuildDate>Wed, 20 May 2026 23:17:06 +0000</lastBuildDate>
                        <title>RE: Thumb screws vibrating loose on Core One</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/thumb-screws-vibrating-loose-on-core-one/#post-791372</link>
                        <pubDate>Tue, 05 May 2026 10:41:24 +0000</pubDate>
                        <description><![CDATA[Interesting idea - thanks for the suggestion.   Posted by: @robin_13 I wonder if you put a small &quot;O&quot; ring under the head, it may work like a lock washer due to the friction.  I have seen sim...]]></description>
                        <content:encoded><![CDATA[<p>Interesting idea - thanks for the suggestion.  </p><blockquote data-userid="520449" data-postid="791358" data-mention="robin_13"><div class="wpforo-post-quote-author"><strong> Posted by: @robin_13 </strong></div><p>I wonder if you put a small "O" ring under the head, it may work like a lock washer due to the friction.  I have seen similar things done with other equipment.</p></blockquote><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>cwbullet</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/thumb-screws-vibrating-loose-on-core-one/#post-791372</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/thumb-screws-vibrating-loose-on-core-one/#post-791371</link>
                        <pubDate>Tue, 05 May 2026 10:40:33 +0000</pubDate>
                        <description><![CDATA[I have added this to my checklist also.   Posted by: @geoff-steele I do swap nozzles somewhat frequently and a while back noticed the hot-end had rotated a little and found it had loosened o...]]></description>
                        <content:encoded><![CDATA[<p>I have added this to my checklist also.  </p><blockquote data-userid="582827" data-postid="791344" data-mention="geoff-steele"><div class="wpforo-post-quote-author"><strong> Posted by: @geoff-steele </strong></div><p>I do swap nozzles somewhat frequently and a while back noticed the hot-end had rotated a little and found it had loosened off and could easy be moved by hand. I've not had the nozzle fall out and/or scratch the bed so must have just caught it in the nick of time. Checking these thumbscrews has become part of my between-print checklist. </p><p>TBH I'd never thought to ask if this was normal, a potential problem, or just another me-issue before seeing this thread</p></blockquote><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/thumb-screws-vibrating-loose-on-core-one/#post-791371</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/thumb-screws-vibrating-loose-on-core-one/#post-791359</link>
                        <pubDate>Tue, 05 May 2026 03:51:06 +0000</pubDate>
                        <description><![CDATA[I can imagine the lower one might cop a bit of heat. If the nextruder was long-term I might consider it, though checking those two thumbscrews when I clean the nozzle between prints isn&#039;t a ...]]></description>
                        <content:encoded><![CDATA[<p>I can imagine the lower one might cop a bit of heat. If the nextruder was long-term I might consider it, though checking those two thumbscrews when I clean the nozzle between prints isn't a hassle really</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Geoff Steele</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/thumb-screws-vibrating-loose-on-core-one/#post-791359</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/thumb-screws-vibrating-loose-on-core-one/#post-791358</link>
                        <pubDate>Tue, 05 May 2026 02:51:44 +0000</pubDate>
                        <description><![CDATA[I wonder if you put a small &quot;O&quot; ring under the head, it may work like a lock washer due to the friction.  I have seen similar things done with other equipment.]]></description>
                        <content:encoded><![CDATA[<p>I wonder if you put a small "O" ring under the head, it may work like a lock washer due to the friction.  I have seen similar things done with other equipment.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Robin_13</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/thumb-screws-vibrating-loose-on-core-one/#post-791358</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/thumb-screws-vibrating-loose-on-core-one/#post-791344</link>
                        <pubDate>Mon, 04 May 2026 22:59:53 +0000</pubDate>
                        <description><![CDATA[I do swap nozzles somewhat frequently and a while back noticed the hot-end had rotated a little and found it had loosened off and could easy be moved by hand. I&#039;ve not had the nozzle fall ou...]]></description>
                        <content:encoded><![CDATA[<p>I do swap nozzles somewhat frequently and a while back noticed the hot-end had rotated a little and found it had loosened off and could easy be moved by hand. I've not had the nozzle fall out and/or scratch the bed so must have just caught it in the nick of time. Checking these thumbscrews has become part of my between-print checklist. </p><p>TBH I'd never thought to ask if this was normal, a potential problem, or just another me-issue before seeing this thread</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/thumb-screws-vibrating-loose-on-core-one/#post-791344</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/thumb-screws-vibrating-loose-on-core-one/#post-791343</link>
                        <pubDate>Mon, 04 May 2026 22:46:26 +0000</pubDate>
                        <description><![CDATA[Thanks.  I might try that.   Posted by: @hyiger I didn&#039;t have both thumbscrews get loose but I did have one do that. It happened when I was still very new to the printer, tried to remove the...]]></description>
                        <content:encoded><![CDATA[<p>Thanks.  I might try that.  </p><blockquote data-userid="590790" data-postid="791339" data-mention="hyiger"><div class="wpforo-post-quote-author"><strong> Posted by: @hyiger </strong></div><p>I didn't have both thumbscrews get loose but I did have one do that. It happened when I was still very new to the printer, tried to remove the nozzle without loosening the screws, and bent the tip of one of the screws. I had to order replacements. Unless you frequently remove nozzles maybe a small amount of blue Loctite? </p></blockquote><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/thumb-screws-vibrating-loose-on-core-one/#post-791343</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/thumb-screws-vibrating-loose-on-core-one/#post-791339</link>
                        <pubDate>Mon, 04 May 2026 22:12:41 +0000</pubDate>
                        <description><![CDATA[I didn&#039;t have both thumbscrews get loose but I did have one do that. It happened when I was still very new to the printer, tried to remove the nozzle without loosening the screws, and bent t...]]></description>
                        <content:encoded><![CDATA[<p>I didn't have both thumbscrews get loose but I did have one do that. It happened when I was still very new to the printer, tried to remove the nozzle without loosening the screws, and bent the tip of one of the screws. I had to order replacements. Unless you frequently remove nozzles maybe a small amount of blue Loctite? </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>hyiger</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/thumb-screws-vibrating-loose-on-core-one/#post-791339</guid>
                        <title>Thumb screws vibrating loose on Core One</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/thumb-screws-vibrating-loose-on-core-one/#post-791337</link>
                        <pubDate>Mon, 04 May 2026 22:09:31 +0000</pubDate>
                        <description><![CDATA[Anyone else having an issue with the thumbscrews vibrating loose after several prints and the nozzle dropping and scratching the bed?]]></description>
                        <content:encoded><![CDATA[<p>Anyone else having an issue with the thumbscrews vibrating loose after several prints and the nozzle dropping and scratching the bed?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/thumb-screws-vibrating-loose-on-core-one/#post-791337</guid>
