The Cryogrip Pro Glacier plate is an excellent cheaper alternative to the Satin plate with one minor caveat on the Core One
Strona 2 / 7
RE: The Cryogrip Pro Glacier plate is an excellent cheaper alternative to the Satin plate with one minor caveat on the Core One
Also, I like mine (of course) since it's a lot more compact and uses less material. Plus it's fun to design stuff.
Opublikowany : 17/09/2025 2:38 pm
Chocki
(@chocki)
Anyone tried this with PC Blend yet? also what are TPU results like.
PC blend I have to use the Satin sheet and add brims and even then it curls up something rotten on larger prints if it does not detach first!.
Opublikowany : 17/09/2025 5:30 pm
Posted by: @chocki
I'm doing a large Nylon blend shortly. I can give PC-CF a try but don't really want to print anything large since the filament is really hard to come by recently.
Opublikowany : 17/09/2025 6:15 pm
Throttlebottom
(@throttlebottom)
Posted by: @chocki
I bought one of these plates specifically to run TPU without glue stick, and it works fantastic in that regard.  Haven't had occasion to print anything else on it yet.  I have some PCCF which I used with glue stick on a factory satin sheet, the fibers really help keep it flat.   At some point I will try the PCCF on the glacier too.
Opublikowany : 17/09/2025 8:49 pm
Posted by: @throttlebottom
Posted by: @chocki
This plate is sorcery/witchcraft. Everything I throw at has a perfect first layer, it sticks and doesn't warp off the plate and I don't have to keep cleaning it like I do the satin plate. And (after factoring in shipping) it's $30 cheaper than the Prusa satin plate.
I'm doing a PA6 print right now of a simple box that usually only sticks to the Prusa PA plate (or satin with a lot of glue). I'm using a bare plate that I haven't even cleaned and it's sticking like a champ.
Opublikowany : 17/09/2025 9:12 pm
gb160
(@gb160)
Really tempted to try one of these.
Once again though, these things are much more expensive from Amazon UK, than they are on Amazon US.
Opublikowany : 17/09/2025 10:31 pm
Posted by: @gb160
Know that all too well (I bounce to London 4 times a years)... £32.99... ouch almost twice as much.
Opublikowany : 17/09/2025 10:37 pm
Here is a PA6 (Nylon print)
Opublikowany : 17/09/2025 10:41 pm
As soon as the PC-CF comes out of the drier I'll try that next.
Opublikowany : 17/09/2025 10:44 pm
pjs37
(@pjs37)
Yeah I just got one and I been impressed so far.  There is one print I still want to try and see how it goes as I had issues with warping on my satin sheet.
Opublikowany : 18/09/2025 12:47 am
Here is PC-CF
Opublikowany : 18/09/2025 3:48 am
So far I've thrown at it:
  • PLA
  • PETG
  • TPU
  • ASA
  • PA6-CF20
  • PPA
  • PC-CF
None of these prints were with a glue stick. All my Prusa plates are being retired.
Opublikowany : 18/09/2025 3:55 am
GBMaryland
(@gbmaryland)
The only issue I’ve run into is when you have a print tower… sometimes you do have to use glue on the plate to make sure the print tower doesn’t fall over on larger prints. Specifically when you’re doing multiple colors… (in this case it was PETG)
I’ve pretty much printed all of the stuff that you’ve mentioned with the exception of the nylons, which I’ve been looking for an excuse to make something in nylon  Kevlar… but nothing has come up and it’s way too expensive just to screw around with.
Opublikowany : 18/09/2025 10:37 am
langjai
(@langjai)
I think I like your’s better. The one out there now sets the pad too far in the -Y direction. I can only use the back half of the pad, otherwise the gantry will slam into the front stop during the wipe cycle.
Opublikowany : 18/09/2025 12:30 pm
Posted by: @gbmaryland
Had the same problem with the satin plate. I did a multi-material/multicolor print (PC-CF and PETG) and the purge tower wouldn't stick to the plate. Not going to try it again until the INDX is released and I'm not interested in the MMU.
Opublikowany : 18/09/2025 3:02 pm
For fun, will try PP-CF. If that sticks to the plate and doesn't warp off it then I will pack up all of my Prusa sheets and move them to the closet
Opublikowany : 18/09/2025 3:03 pm
Posted by: @langjai
I saw your comment on Printables, will create a right hand version after work. Need to be careful that the heat block doesn't intersect with it when the purge line is created.
Opublikowany : 18/09/2025 4:21 pm
GBMaryland
(@gbmaryland)
Posted by: @hyiger
Challenge Accepted:
Showing off filament
Opublikowany : 18/09/2025 8:28 pm
Posted by: @hyiger
Challenge Accepted:
Right now I'm throwing wood at it... as in: Prusament Woodfill Chocolate Brown
And it sticks to the plate like a boss. This is my only plate from now on for anything.
Opublikowany : 18/09/2025 9:03 pm
1 ludzie polubili
GBMaryland
(@gbmaryland)
Posted by: @hyiger
Posted by: @hyiger
Challenge Accepted:
I'm working on a project where I'm having the university high-res scan in Beretta stocks so that we can prototype them without nuking trees, then recycle the printed stocks. Once the firearm is fit to the olympic shotgunner, we can use a duplicator to make the finished (e.g. insanely expensive) stock for the competitor... or the final synthetic stock.
I've been consider a few different wood fiber embedded products to see how well they stain, etc.  The real challenge is the mechanical strength of the printed variants. The final versions can be spun up using a 5 axis wood milling machine, etc., or done more or less by hand.
Opublikowany : 19/09/2025 12:21 am
Strona 2 / 7
