The 6.4.0-alpha firmware is awesome (so far)
Page 2 / 2
Print_Fandango
(@print_fandango-2)
RE: The 6.4.0-alpha firmware is awesome (so far)
I guess that is where my confusion was coming from.
Posted : 12/09/2025 1:13 am
Tim
 Tim
(@tim-24)
The sharp peak change you are looking for happens as you turn the knob; not when you stand there looking at the belts with a stable frequency. If the belt is moving while the light is strobing, the frequencies do not match. The belt should appear stable and unmoving, or 'locked' with the strobe.
But I agree with you, the user information that comes with this alpha is, well, nearly useless. Not sure how Prusa expects people to really test the feature if it the usage is so obtuse.
Posted : 12/09/2025 1:47 am
Posted by: @tim-24
No, that is not how it works in this case. The belt is not moving laterally, it’s vibrating. It needs to be tuned to the belts resonant frequency. I suggest you try it for yourself first before commenting.
This post was modified 1 day ago by hyiger
Posted : 12/09/2025 1:58 am
Print_Fandango
(@print_fandango-2)
The instructions say to look for slow movement.
To confirm. Was I doing it right in the video??
Posted : 12/09/2025 2:01 am
Posted by: @print_fandango-2
If you match with the web app and plucking the belt (with the head in the same position) then you did it correctly. Be careful with Prusa's instructions they tend to go through several iterations before they make sense. This is an alpha product so don't expect detailed (or correct) instructions at this point.
Posted : 12/09/2025 2:03 am
gb160
(@gb160)
Posted by: @hyiger
Yeah I've noticed this, but also willing to cut some slack because the instructions are written by people who probably dont use English as their primary language, often getting interpreted/misinterpreted by people who dont use English as their native language.
There's no reason why they cant release a simple, decent frame rate video (with subtitles for every language under the sun).
As the old saying goes, actions speak louder than words, and would clear up anything that is lost in translation.
Just to clear something up: have the target frequencies changed again ? last time I looked it was 98/92.
This post was modified 23 hours ago 2 times by gb160
Posted : 12/09/2025 7:52 am
Tim
 Tim
(@tim-24)
Posted by: @hyiger
Posted by: @tim-24
It really IS the way it works. Whether motion is horizontal left right or horizontal front to back or up to down, the goal is to stop the motion with the strobe. Movement, in this case capturing a resonance, is captured using a strobe to synchronize the light to the motion.  Any deviation from a stopped image means the two frequencies are not aligned and synchronized. It really is very simple physics.
When the two are not sync'd, you get a beat frequency, that slow motion in the video. If that motion is once per second, it means the belt is 1Hz away from the light (or possible a harmonic of 1 Hz), but that'd probably be obvious.
ps: In case it isn't obvious @hyiger, the belt really is moving as it vibrates. Just as it moves when you pluck it.  From Google:
To use a strobe light to measure resonance, set up an object to vibrate and apply a strobe light, then adjust the strobe frequency until the object appears to be stationary or to vibrate slowlyWhen the strobe frequency matches the object's natural frequency (its resonance frequency), the object appears frozen in time, revealing its modal shape.
This post was modified 23 hours ago 2 times by Tim
Posted : 12/09/2025 8:15 am
Posted by: @tim-24
Posted by: @hyiger
Posted by: @tim-24
Until you install the firmware and do this for yourself you are just spouting incorrect information
Posted : 12/09/2025 12:33 pm
Print_Fandango
(@print_fandango-2)
Posted : 12/09/2025 12:46 pm
Posted by: @tim-24
What is obvious is that you are coming across to me and others in this forum as really rather arrogant.
The frequency resolution is 0.5hz you are most likely not going to be exactly on the resonant frequency so the belt for most is not going to stop in the strobe, slower yes but not stopped as you initially posted. As in Prusa's initial instruction and in their gif. Again, you should not comment on things you haven't tried for yourself.
This post was modified 18 hours ago 5 times by hyiger
Posted : 12/09/2025 12:57 pm
bowtie6
(@bowtie6)
Interesting video about a handheld strobe and Core One belts...
And I realize this is NOT using the new FW tuning procedure.  I found it interesting regarding the belt movement when the proper frequency is achieved.
This post was modified 11 hours ago by bowtie6
Posted : 12/09/2025 7:46 pm
Page 2 / 2
