Startup procedure for printing takes way too long
Yoyo
 Yoyo
(@yoyo-3)
It takes around 14 minutes before starting to print PETG in a 20 celcius degrees room.
Can we do something about it ? This is crazy.
Opublikowany : 02/08/2025 6:57 pm
tbr
 tbr
(@tbr-2)
RE: Startup procedure for printing takes way too long
Are you on the 6.3.4 firmware yet? They made the "heat absorption" cycle more adaptive and I barely notice it nowadays. Especially for consecutive prints where things are warmed up.
You could also comment the following line out from the custom G-code to skip the "heat soak" if you are confident it's not needed:
G29 G ; absorb heat
Opublikowany : 02/08/2025 7:49 pm
JingleMePringles
(@jinglemepringles)
It should be noted too in order to do this, you will need to use the slicer in expert mode.
Posted by: @tbr-2
G29 G ; absorb heat
Opublikowany : 03/08/2025 12:34 am
Protoncek
(@protoncek-2)
I've commented out that line myself, too. I am on latest FW, which supposedly have this heat cycle more adaptive, but i didn't notice any (big) difference, heat absorption pause is still there, also immediately after long print, when it should really totally cancel it. I'm sure that after 1-2 hour print whole printer is warm enough, but printer still waits for this (annoying) heat absorption.
I don't see any difference in my prints. I guess it could be important/visible if room temperature would be low, like 10 degree Celsius or lower, while at 20+ it's absolutely not important.
Opublikowany : 03/08/2025 1:36 pm
1 ludzie polubili
zapta
(@zapta)
Posted by: @yoyo-3
20 minutes for heating and heat soak is pretty good.
Opublikowany : 03/08/2025 5:43 pm
Yoyo
 Yoyo
(@yoyo-3)
I don't understand why my A1 Mini starts a print with similar conditions in less than 5 minutes (with 80 degrees bed).
I think it's fair to wait 5 minutes for a PETG print to start, but 15 min doesn't make any sense.
Opublikowany : 04/08/2025 9:34 am
zapta
(@zapta)
Posted by: @yoyo-3
Does the Mini starts printing as soon as its bed and nozzle reach the target temperatures or is it some stabilization waiting time?
Opublikowany : 04/08/2025 11:57 am
Raaz
 Raaz
(@raaz-2)
Posted by: @yoyo-3
- no chamber to heat up
- no stabilization time for perfect dimensional accuracy (independent of room temperature)
- maybe less accurate probing
You can disable the waiting time in the start g-code and if there's some minimum chamber temp. set in the filament profile, also disable that (0°C).
I stored a "quick start" printer profile that does all that and it's very quick.
If you're interested, I can upload a project with all settings included 🙂
Opublikowany : 04/08/2025 7:04 pm
