Prusa Filament Dryer excellent addition
Página 1 / 2
Butters
(@butters)
The Prusa USS Drybox I was sold immediately when I saw it; this is what I wanted for the CoreOne. I'm sorta glad that I was extremely slow in assembling my CoreOne. 😀
Although, can it fit all filaments ? I was going to purchase a filament dryer but I'm glad that this just fits on the side. This dryer is an excellent idea
Respondido : 19/11/2025 12:17 am
It is not a filament dryer, just a storage box. If a filament has already absorbed humidity, the USS box can't dry it because there is no heater built in.
Anyway, it might be a nice storage solution. But given the cost I would only consider it for a couple of filaments which I am using most often. Everything else will be stored in other ways and will still need to be dried before use. And whether Prusa's claim works out that you can "place the spool inside once and leave it there until you’ve used it up" will depend on how long it takes you to use up the spool.
Respondido : 19/11/2025 7:23 am
RE: Prusa Filament Dryer excellent addition
Posted by: @jurgen-7
Nylon filaments, especially PA6 are unprintable after 2 days in a dry box with < 10% relative humidity. I've been using a relatively cheap dry box solution. Can't imagine the Prusa dry boxes are going to be cheap.
Respondido : 19/11/2025 4:46 pm
Butters
(@butters)
How can I purchase filament now and keep it in excellent condition even if I use is sparingly ? I'd have to buy a separate dryer or is there a specific way to store it ?
Respondido : 19/11/2025 6:24 pm
Thomas Lynch
(@thomas-lynch)
I keep my filament in these water tight sealed plastic boxes. Each box has 4 or 5 little cotton bags filled with Silica-Gel. It keeps my filament at about 20%RH.When it goes to about 30%RH I just take out the little bags and empty the Silica-Gel onto a paper plate and put it into my microwave for about 2-3 minutes and put it back into the cotton bags and return them to the box they came from. Each box holds about 15 rolls of filament. I have 4 of them all full of filament. When I need a certain filament I just go into one of these boxes and take what I need, use it and return it to the box it came from. It is always dry and ready to go. I have been doing this for quite a few years and have never had a problem with wet filament.
Tom
Respondido : 19/11/2025 7:39 pm
2 les gusta
Miembro
Posted by: @butters
I would a Polydryer by Polymaker.  It is the best of both worlds.  It is both a dryer and a storage box.  You can also buy additional storage boxes.
https://us.polymaker.com/products/polydryer?variant=43078512181305
Respondido : 19/11/2025 7:53 pm
1 les gusta
Cédric
(@cedric)
Posted by: @hyiger
https://www.prusa3d.com/de/produkt/prusa-uss-drybox/?fbclid=IwY2xjawOJiGlleHRuA2FlbQIxMQBzcnRjBmFwcF9pZA80MDk5NjI2MjMwODU2MDkAAR5sVXgNkbv8FV-1u865nKWB0FUJx2J8_JPI95MPTr4wHSdaucjHnadkr-CzDw_aem_br_PSMn8zVVJtFph1lE35Q
33euro, not bad at all
Respondido : 19/11/2025 9:12 pm
Butters
(@butters)
$50 in my currency. The Prusa DryBox is the best solution, at two it's cheaper then the Polymaker link suggested above. With this drybox all moisture is removed from the filament ?
Respondido : 19/11/2025 9:20 pm
Posted by: @butters
No. As stated before, the Prusa box does not have a heater, so it cannot dry filament which has already become moist. It can only keep filament dry when it is already dry, for a while. In contrast, the Polymaker solution does contain a heater, which explains its higher price.
The term "drybox" is not used fully consistently. But nearly always it means just a passive, well-sealed box which keeps dry stuff dry, the way the Prusa box does. A device that can make humid filament dry is typically called a "filament dryer".
Respondido : 19/11/2025 9:29 pm
2 les gusta
Posted by: @butters
Put a raw steak in a dry box, then take it out after a week. Is it beef jerky? No, it's still a raw steak (and probably moldy).
Respondido : 19/11/2025 10:00 pm
mnentwig
(@mnentwig)
Posted by: @hyiger
Posted by: @butters
Slice it as thinly as reasonably possible (that's the hard part), marinade in a bottle of Worchestershire sauce, soy sauce, a few spoonfuls of Ketchup, a glass of whiskey and a few ingredients I forgot. Reduce time to about 12h and we're talking business.
Is this getting OT? 🙂
Well almost. Note to self, when next buying a food drier for beef jerky, make sure it fits filament spools :facepalm
Respondido : 19/11/2025 10:49 pm
1 les gusta
Butters
(@butters)
Steak and whiskey dry out filaments. Rather does someone want a steak and whiskey.
Respondido : 19/11/2025 10:50 pm
mnentwig
(@mnentwig)
Posted by: @butters
And a bottle of Worchestershire / Soy sauce spoonfuls of Ketchup forgotten ingredients etc and most importantly a box with some kind of heating element 🙂
Respondido : 19/11/2025 10:59 pm
Miembro
That is incorrect.  I don't think you understand the difference.  The Polydryer is an authentic dryer.  It will keep your filament dry and remove moisture.  The Prusa dry box will keep a roll dry, but does nothing for wet filament.   That is $80.  A dry box from Prusa is $32, and it is $29.99 from Polymaker.   I will buy a few Prusa boxes, but only to use on the sides of Prusa printers and keep the filament dry.
I currently own a dozen of the Polymaker versions, and they work great.  I have four dryers and 12 or so containers.
Posted by: @butters
Respondido : 19/11/2025 11:07 pm
Butters
(@butters)
I'll just get a dryer and a filament dry box from Prusa see how it works out. I understand what you mean along with the other reply about the differences.
Posted by: @cwbullet
Posted by: @butters
Respondido : 19/11/2025 11:34 pm
Butters
(@butters)
I wish that there was a dyer that would attach to the side of the CoreOne, rather then having a separate unit. 😶
Respondido : 19/11/2025 11:35 pm
Miembro
Good.  The bottom line is that the Prusa box is not a dryer.  I also have a filament dry cabinet made from a camera cabinet.  It is for long-term storage.
Posted by: @butters
Posted by: @butters
Respondido : 19/11/2025 11:36 pm
Miembro
Not exactly what you asked for:
https://www.printables.com/model/1253387-core-one-polydryer-shelf
https://www.printables.com/model/1384864-core-one-polydryer-shelf
https://www.printables.com/model/1367903-polyheater-for-core-one-foldable-polydryer-chamber
The last one is to use the ehater as a chamber heater.
I love printables.
Posted by: @butters
Respondido : 19/11/2025 11:49 pm
iftibashir
(@iftibashir)
Expensive, but really nice boxes IMO! They seal closed really well!
Respondido : 15/04/2026 4:24 pm
rjb2222
(@rjb2222)
I bought a Plolymaker dryer set up. I love the tool so far. I plan to dry my filiment and move it to a sealed unit with dessicant for the duration of the roll. I havent done any nylon yet so I am unsure if my plan will work with that material but I can get a dedicated set up for Nylon later.
Respondido : 17/04/2026 12:18 am
Página 1 / 2
