Prusa Core One not usable inhouse... Sorry, but the sound was to intensiv
Strona 10 / 11
Gyoenastaader
(@gyoenastaader)
RE: Prusa Core One not usable inhouse... Sorry, but the sound was to intensiv
For me, stealth mode does nothing. The motor whine and resonance are just as bad. I am beginning to wonder if there is an issue with pre-2024 stepper motors. On Reddit there has been a few threads of people discussing motor noise issues with older MK4S. So there seems be at least a few categories of issues, old MK4S machine conversions, newer MK4S machine conversions, kit machines, and pre-assembled. I think for Prusa to make steps forward, they need to start categorizing where parts came from and potentially their age.
Opublikowany : 12/08/2025 5:27 pm
1 ludzie polubili
Gyoenastaader
(@gyoenastaader)
I solved the whine issue. It was the MK4 stepper motors.
There are a few posts around here and Reddit saying people replaced their motors and the machine was much quieter. I can confirm.
If you upgraded your MK3 to an MK4 sometime before 2025, I strongly recommend buying replacement X/Y motors and the accelerometer kit. If your motors have "Prusa i3" on them, replace them! Sitting 5 feet away, I can barely hear the printer, and not at all if I have headphones on. Before I could hear the printer over my headphones with music.
Opublikowany : 20/08/2025 5:43 pm
1 ludzie polubili
Frankone
(@frankone)
Hello,
that sounds very interesting for me. What labels are on your new motors?
Opublikowany : 29/08/2025 7:01 pm
Posted by: @gyoenastaader
Maybe it's due to a bad batch of motors and not the motors as a whole. I have the Original Prusa i3 motors and after phase stepper tuning with the accelerometer my printer is very quiet. It's certainly not loud enough that it has to be in another room. I didn't have the motor whine to begin with but I did have the resonance issue everyone else has been reporting.
Opublikowany : 30/08/2025 3:44 pm
Tim
 Tim
(@tim-21)
My new Core One was atrociously loud. But now after two large demo prints at full speed (stealth made little difference in noise levels), the printer has quieted down some, about 47dBA in Stealth (at 1 meter), and generally under 52dBA in normal. On the other hand, my decade old Mk3 barely hits 40dBA... lol. Speed has costs.
Opublikowany : 30/08/2025 7:33 pm
Posted by: @dr-ava-shamban
I'm sorry to hear you're struggling with the noise from your Prusa Core One. It can definitely be a challenge to have a 3D printer running in a shared living space.
As others have pointed out, there are some great solutions to this problem. A well-built enclosure can make a huge difference, as it not only contains the sound but also helps with print quality. Another common approach is to look into silent stepper drivers. While it requires some technical know-how, it can drastically reduce the noise level.
Hate to be rude, but this reads exactly like an AI response. The Core ONE only has a "well built enclosure" and what is a "silent stepper driver" in this context?
Opublikowany : 30/08/2025 7:59 pm
GBMaryland
(@gbmaryland)
Well, I can say, not being an AI, that my Core One was never really loud... and remains pretty quite.  Only time I had an issue was when printing the CoreBoxx... and somehow a part came off the build plate and jammed under the bed... it was the largest mess I've ever seen on a 3D printer... and all of the adjustments had to be recalibrated.  (literally)  ...and it's still nice and quiet. I think it's even more quiet than the H2D I've got....
Opublikowany : 30/08/2025 8:04 pm
Kevin A
(@kevin-a)
Glad I came across this thread and realised it wasn't just me. My old Mk4 sat about 2 feet behind me and never bothered me once wrt noise. The Core One is in another room and I can still hear it and it's an irritating noise. Worth noting it was in the same room as a laser engraver and that doesn't bother me in the same way and that’s loud 🤣. That and the constant re-homing for up to 5 minutes and when you change filament I'm sorely tempted to revert it back to a Mk4, enclose it and have done with it till there’s some sort of update or go the Creality/Bambu route for an X/Y machine. Stopped building a Prusa based XY home-brew when they announced the core one, that was a mistake, but may be the way forward using the core one bits.  Not sure these updates are what they used to be as never seemed to get much benefit out of the Mk4S update as just introduced some cooling artefacts on back corner of print and excessive cooling fan on some profiles gave bed adhesion issues in some instances until you found the right fan speed. Somehow IMO getting the motors off the metal frame would help as that seems to be the main source of excitation for the overall frame somehow replacing the pressed steel plate with a better carriage. Who was the genius who though mounting motors on pressed steel plate was a good idea? With all the connected steel panels it's a regular resonant sound box for a whole range of frequencies so guessing there’s no easy fix with most of the various solutions more being about what particular harmonics people find irritating and hence attenuated would be my guess. My personal opinion is to get the motors of the steel panels and on to something isolated or less resonant.
At over 60 years of age and born deaf if I think it's noisy then it probably is 😉 What's interesting is that my hearing aids filter regular stationary noise but don't filter the Core One. Not having an analyser can't prove but I'm guessing the non stationarity of the noise is what is making it irritating for me.
Opublikowany : 01/09/2025 4:00 pm
Frank
(@frank-8)
I'm in the U.S. and couldn't find any source for this here.  Anyone else find a U.S. source for these nylon blind rivets?
Opublikowany : 02/09/2025 3:43 pm
ssmith
(@ssmith)
 Looking for R3045 rivets, DigiKey lists them here.
Opublikowany : 02/09/2025 4:46 pm
Posted by: @frank-8
I got mine off of eBay: https://www.ebay.com/itm/256621235774
Opublikowany : 02/09/2025 4:59 pm
1 ludzie polubili
J.J. Kucharczyk
(@j-j-kucharczyk)
Not in my case.
I got the XY axis motors from Prusa. I bought brand new LM10LUU linear bearings, Linear Rail Core XY, belt tensioners and replaced everything. I should add that I replaced the new parts with new ones! The machine made strange noises from the very beginning. Hours spent searching for a solution, hours with technical support from scratch. Days spent dismantling, replacing and reassembling CoreOne.
The result?
https://photos.app.goo.gl/EaDx4ennkRdCMjUX9
https://photos.app.goo.gl/Js9n22JVA4ncdzBZ9
I loosened the bearings as mentioned in some posts, moved them and tightened them.
No one can advise anything.
I think the squeaking comes from the spot marked in green, but I'm not sure because there's an echo in the chamber and the entire grinding process begins at the point marked in red and proceeds as indicated by the arrow.
I put CoreOne up for sale. I think I'm giving up after eight weeks of not being able to work and constantly trying to fix something that is supposed to work so wonderfully.
What was the best thing that came out of it? I was forced to buy a printer and decided to take a risk by changing teams** after over 3 years of trusting Prusa.
I was not disappointed, because this is how a professional 3D printer should work:
https://photos.app.goo.gl/DG3KB4BfX52pa5wN8
Opublikowany : 09/10/2025 3:01 pm
Artur5
(@artur5)
Looking at this picture with the toothed side of the belt running over a smooth idler is cringeworthy. No wonder Core One owners complain about VFAs...
Opublikowany : 09/10/2025 8:29 pm
Posted by: @artur5
I've read of others swapping out the smooth idler for a toothed one and it makes no difference. Seems switching to 1.5mm belts is more promising. For me, I'm only printing functional stuff for my other hobbies so don't really care about VFA.
Opublikowany : 10/10/2025 3:54 pm
iftibashir
(@iftibashir)
Interested to know what you changed to?
Ive been using a H2D alongside my Core One, and it's been perfect every time. My Core One has been sitting unused......lol
Posted by: @j-j-kucharczyk
Not in my case.
The result?
Opublikowany : 14/10/2025 8:08 am
J.J. Kucharczyk
(@j-j-kucharczyk)
Posted by: @iftibashir
I switched to H2D and ordered H2S with AMS for personal use. I will most likely put CoreOne up for sale as soon as I deal with those noises of tin scrap during printing.
https://photos.app.goo.gl/QHqLBekz6FGvRtew8
Over the past 8 weeks, CoreOne has only been printing for about 6 hours – it was impossible to be near it. In the last 2 weeks, H2D has been printing practically non-stop. I am sorry to leave Prusa after so many years of trust and satisfaction. But I am not interested in what the last technical support representative wrote: “a positive learning curve during continuous attempts at repair.” The positive curve of designing new things is more important to me.
This post was modified 4 months temu 2 times by J.J. Kucharczyk
Opublikowany : 14/10/2025 8:49 am
1 ludzie polubili
rosic
(@rosic)
I bought the kit, made sure everything is assembled as perfect as possible, lubed and so on. After calibration and phase stepping my Core ONE is super quiet. I have it basically next to me, I don't even bother closing the door of the room the Core ONE is situated. My previous printer was Creality K1 Max and that was a whole different story.
But important to note, that a friend of mine went from MK4 -> MK4S -> Core ONE and his steppers are much louder. High pitched tone, printer is basically "screaming". Both print perfectly but his is much much louder.
Opublikowany : 17/10/2025 10:27 am
mnentwig
(@mnentwig)
Yes, the motor tolerances seem to play a role. I read this thread before I received the kit, and about the first thing I did when unboxing was to try turning the motor shafts.
On XY, one feels considerably "rougher" than the other. In operation - surprise ... -  one diagonal is quiet, the other one noisy. Still, the noise level of my unit is quite manageable. I haven't even tried stealth mode.
Opublikowany : 17/10/2025 6:41 pm
Philippe BAUER
(@philippe-bauer)
Prusa must do something quickly
My prusa core one is also noisy. On my XL all problems have been solved with input shaping and phase motors calibration (read the attached mp4 file). It’s not the case on the core one. Change to stealth and silent running doesn’t change anything on the core one. It’s very effectiv on the XL. Conclusion: it’s possible to do something. We are waiting...........before to buy chinese silent printers🤪🤪
Opublikowany : 23/10/2025 4:54 pm
inzekt
(@inzekt)
Mine also came as a kit, assembled, lubed, set up, calibrated the belts, input shaping, phase stepping, etc and it is really quiet. I mostly hear the fan of the advanced filtration blower. My guess is, that the pre-assembled printers with the stock input shaping and phase stepping parameters are just a a roll of the dice. Looking at the construction of the printer it is just a huge metal resonance box. If there is any misalignment, gaps, loose bolts, belts, etc, it is unavoidably make noise. And if it does, it will amplify it for sure.
When I assembled it, I automatically put thin, but dense, sticky sound dampening material I had lying around to the bottom and the recesses of the side panels, as they were sounding like cymbals when unpacked them. I did not want to worry about it later, so I can't speak if it helps at the end, but I don't have any issue with the noise whatsoever.
Opublikowany : 24/10/2025 8:30 pm
Strona 10 / 11
