Prusa Core One not usable inhouse... Sorry, but the sound was to intensiv
Stránka 1 / 11
tomtim
(@tomtim)
I have now banished my Prusa Core One to the cold garage. Unfortunately, you can't run it in the house.
Despite the marble plate and squash balls, the noise when you print is so intense that you can't use it indoors.
I also have the feeling that too cheap drivers have been installed, it makes music like printers from 5-6 years ago where you thought the printers spoke when printing.
Too bad about the money for the printer.
Really, if someone is thinking about this, they must have a warehouse or garage. You can't use it indoors with firmware 3.30.
Since no new firmware came today, only for the MK series, I assume that this printer is simply to be sold without first support. The firmware is a beta and not a release... Too bad...
My MK4s has printed here day & night without hearing anything. It was simply the best printer ever... It's coming back here now.
Napsal : 14/03/2025 4:14 pm
3 lidem se líbí
Drid-Ghost
(@drid-ghost)
RE: Prusa Core One not usable inhouse... Sorry, but the sound was to intensiv
Are you sure you have firmware 3.30?
Currently, 6.3.0
Napsal : 14/03/2025 4:21 pm
tomtim
(@tomtim)
1 meter from the printer. Sorry, 6.30 🙂 Wrong finger
core one
Napsal : 14/03/2025 4:22 pm
2 lidem se líbí
Drid-Ghost
(@drid-ghost)
Did you ever write to the support chat and give them the video?
And if so, what was their statement?
Napsal : 14/03/2025 4:25 pm
1 lidem se líbí
tomtim
(@tomtim)
I don't want to deal with the support anymore, unfortunately you often only get answers. The belt doesn't fit, etc...
Prusa has received a 1 for the design of the Core One. But the sheet metal and the bearings (why is only one plain bearing installed) were simply cheap. No quality. The plates all creak when you apply a lot of pressure. With small ones it works, but not like the one on the video, your ears fall off. And the fans are switched off because they are even more annoying when they run at 50%. I don't care if it's 52 degrees in there...
I work in the metal industry and can judge that well.
The wrong money was saved here. The printer is more just for looking at or small 5x5cm prints
Napsal : 14/03/2025 4:36 pm
Ondrashek
(@ondrashek)
Wait until someone starts selling MK4 parts from a conversion kit and convert your Core One back to MK4 ;-D
Napsal : 14/03/2025 4:53 pm
5 lidem se líbí
tomtim
(@tomtim)
Yes, you could do that. I'm also thinking about sending the Core One back.
It would be a shame because the design of the case just looks good. I had already considered removing the side panels because they also vibrate a lot and make a sound, but then it's no longer a case, and I don't want to spend money on new side panels.
Napsal : 14/03/2025 4:58 pm
clearwater
(@clearwater)
I've heard it's not exactly quiet, but how loud are we talking? Like can't have a conversation in the same room? If it's in the basement you can't have a conversation on the main floor? Or is it just noticeable? I don't plan to have mine running 24/7 so if it's only making noise in the basement for a few hours, I can accept that... but I haven't seen anyone so displeased with the noise level that they talked about sending it back.
Napsal : 14/03/2025 6:12 pm
steve457
(@steve457)
I'm also curious how much louder we are talking about here. My MK4S also makes some noise and has resonance at certain speeds, so I wouldn't expect any printer to be whisper quiet. If you have both the MK4S and Core One could you measure the sound level using a dB meter with both printing the same object using the same structural default setting?
Napsal : 14/03/2025 7:45 pm
tomtim
(@tomtim)
I removed both side panels and then it got a bit better. But only with certain movements.
I wrote to Prusa's chat and was told that something is wrong with xy movements. I made and uploaded videos. These are now being analysed.
I have now mounted a side panel with cable insulation around the edge and ahh, look, just as quiet/loud as without a side panel. So one vibration less.
There are still 1-2 movements, for example when creating the first edge, then the second edge line is a little quieter and there are no extreme vibrations during filling. So it still needs to be optimised via the software.
this vibration tone
ere it is a little longer – printing normally and sometimes you can hear the buzzing/vibrations.
even longer
I hope you feel like watching this.
Napsal : 14/03/2025 8:21 pm
Brian
(@brian-12)
Not sure if you've searched around on this but I suspect the issue is related to motor noise, and I suspect improved phase stepping will improve the issue.  The XL was very loud initially as well.  Many blamed the metal panels and there were all kinds of mods from people to make it quieter.  Prusa finally released the phase stepping and all of the noise complaints went away.  It reduced the noise by 90% easy.
On GitHub Prusa developers said they are working on it for the core one.
I also suspect it's not all machines as I've watched many reviews where they do sound tests and measured it at 62 db with the door closed.  That's not loud for a 3d printer imo.
I do agree that the MK4 is nearly silent, much quieter than the XL and the MK3.
The motors and drivers are the same on the core one as the MK4 so I believe the possibility of it being quiet are there, hopefully they'll be able to improve the motor tuning.
Good luck.
Napsal : 15/03/2025 12:14 am
3 lidem se líbí
tomtim
(@tomtim)
hopefully yes...
Napsal : 15/03/2025 6:13 am
1 lidem se líbí
Posted by: @brian-12
Given that Prusa already had this experience, what were they thinking when they released the Core One without the phase stepping calibration?!
Well, most likely they were thinking "Oh $#!+, we are going to miss our target ship date." But it seems like an unwise decision to risk the reputation of the Core One by taking this shortcut. Heck, they even advertise quiet operation as one of the advantages of the Core One over the Bambu Lab competition!
Prusa has acknowledged that the lack of phase stepping calibration is a bug. But there has been no update beyond "we are working on it" on February 6th: https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/4461
Napsal : 15/03/2025 6:26 am
1 lidem se líbí
tomtim
(@tomtim)
Yes, exactly. I was able to quiet the printer down a bit by removing the side panels. One of the left side panels is now held in place again with a cloth tape like the kind used to hold cables (cable harnesses). This helped on the left side. However, it doesn't help when it prints the frame of components, it still buzzes, albeit quieter. You can now also walk along the side panels and hear it a little more muffled. I think the tape really helped a lot. It also has to be attached to the back wall. That also still sounds very tinny.
I would have thought that after 6 weeks the next firmware would come at least as a small bug fix for many things.
But nothing... a shame. Another opportunity missed
Napsal : 15/03/2025 7:05 am
Proper counter-measures against the noise will have to tackle both -- the source (excitation of noise through stepper motor resonances) and the amplification via resonating panels.
I hope that phase stepping calibration will go a long way to reduce the motor noise -- the fact that noise seems to vary quite a bit between different Core One units  makes it plausible that motor-specific tolerances are an important contributor. I just cannot understand why Prusa apparently moved the firmware team to 6.2.x maintenance during those critical weeks after the Core One launch.
For dampening the side panels, I am not quite sure I understand what you have done -- you mentioned using cable insulation?? Once I receive my kit, I intend to apply foam tape with an adhesive backing, to be attached along all the frame edges which support the panels. That should definitely stop any rattling, and will hopefully also dampen vibrations of the panels (in bending mode) by absorbing some energy.
Napsal : 15/03/2025 7:18 am
tomtim
(@tomtim)
I used this tape. If you use a thicker one, you can't clip on the black clips because they won't be long enough. Then you'd have to screw the side panels on, but that's only good if you use good screws. If you have to remove the side panels later, you'll have your work cut out for you.
Napsal : 15/03/2025 8:11 am
1 lidem se líbí
tomtim
(@tomtim)
I'm just testing this a bit...
70% print speed seems to prevent the vibration at the frame lines. Now it's printing at a level that's just about acceptable. Not the goal, but at least... duct tape and 70% seems to improve it.
Napsal : 15/03/2025 8:15 am
Posted by: @tomtim
Those plastic rivets come in different lengths. What's the hole diameter on the Core One, 3.x mm? In that size, a quick search brought up rivets for up to 8.5 mm material strength. That should hopefully be enough for the polycarbonate panels, frame profiles, and say 3 mm of foam padding?
Napsal : 15/03/2025 8:43 am
tomtim
(@tomtim)
The Prusa rivets are 2.9mm, so that could probably fit.
Napsal : 15/03/2025 8:54 am
These are the ones I found. If 7.5 to 8.5 mm material strength should be too long, the vendor has shorter variants in 1 mm steps:
https://www.ettinger.de/p/spreizniet-oe3-0-7-5-8-5-polyamid-6-schwarz/072.21.380
Napsal : 15/03/2025 8:56 am
2 lidem se líbí
Stránka 1 / 11
