Prusa CORE One kit assembly instructions
Page 10 / 10
Ahalm
(@ahalm)
RE: Prusa CORE One kit assembly instructions
Posted by: @chris-hill
 It took me a long day to build my kit - taking my time and going carefully.  Obviously the Prusa staff will do the job more efficiently, but I'd be surprised if one person could build more than two in an 8-hour day.  Even if it's a production line arrangement where one person does nothing except, say, the base assembly all day, the aggregate time for a build might work out at 2-3 printers per person per day.  So kits make a lot of sense in terms of getting a lot of printers into customers hands.  It probably pays them to make sure it's an enjoyable process so that enthusiasm for the kits remains high.
In one interview, available somewhere deep in Youtube, one of their engineers said, that it takes around four hours from their staff to assemble. From him it took seven hours on first time.
Publié : 27/04/2025 4:27 pm
2 personnes ont aimé
gb160
(@gb160)
Posted by: @ahalm
I think it took me around double that, but I'm convinced I could halve that if the parts were better arranged, de-bagged etc. I would imagine that the engineer who did it in 7 hours first time had plenty of space, all the parts sorted etc.
I swear I spent half of that time searching through boxes and bags...I enjoyed building it, but it could've been much more enjoyable if each section had its own parts divided up separately.
This was the first printer I've built from scratch, and definitely something I'd like to do again.
Publié : 28/04/2025 6:11 am
gadget01
(@gadget01)
Despite the part-hunting process, I admire Prusa's packaging though- it's a noteworthy achievement.
Maker of things
Publié : 28/04/2025 6:38 am
Membre
It does improve the experience.
Posted by: @gadget01
Publié : 28/04/2025 9:16 am
Barry Robbins
(@barry-robbins)
I spend the time organizing the hardware in a parts box when I build something.  Will do this on the C1 just to make things easier.
Posted by: @ahalm
Publié : 28/04/2025 4:50 pm
sreinert86
(@sreinert86)
Posted by: @el_hopaness
I just had an issue with the nozzle scratching my heat plate in the far left corner. The cable cover for the heat bed was raised too much, so that the Nextruder fan shroud would touch the cover before the nozzle would touch the bed. I assume this messed up the meshing algorithm (some interpolation of the exact bed coordinates, I guess?).
Anyway, the reason for the raised cover was clearly the M3x10 screw (cylinder head) installed according to the instructions. I exchanged it with a spare "rT" screw of the same length. Maybe someone can check and confirm this. You can move the Nextruder into the far left position and see if the nozzle can touch the bed or not. This may require to rotate the Z-rods by hand.
This is now fixed in the assembly instructions. I built the kit last weekend and there it still was the cylinder head M3x10 - with this comment in mind, I already put the flathead screw in the heatbed-cover.
If you check the manual now, its an M3x10rT -> HERE
So, it's evolving - even the version numbering hasn't changed. I would like to see any changelog or something, so I could check regularly if crucial changes like this one were made so I can check my printer...
Publié : 30/04/2025 8:29 am
3 personnes ont aimé
gadget01
(@gadget01)
I just finished assembling my Core One today and printed the included Benchy, which came out perfect! It took me just over a week since I did not have time to assemble it in a single session. I commend the Prusa team for their solid work on the assembly instructions. It was worth whatever additional waiting time for the kit to ship.
I have some minor improvement recommendations. Any machine subject to vibration, where parts are assembled with machine screws into metal, aside from screwing into a lock-nut, should use non-permanent thread-locking compound to avoid self-loosening.
Attaching the right side panel handle with the filament sensor was quite a fiddly chore. Trying to hold the panel to the frame, keeping a small button-head hex screw on the end of a screwdriver while aligning the screw holes of the filament sensor was quite a challenge. I ended up turning the machine onto it's left side to allow the right side panel to sit stable via its own weight without the tendence of the screws to fall and bounce to an unreachable area. It was also helpful to use painter's tape to hold the handle in position until getting one of the screws started.
It's easier to tension the XY belts before attaching the upper acrylic side panels. Not the adjustment itself, since those screws are easily accessible at the front, but checking the belts acoustically using the app is easier done from the outside of the machine vs trying to reach in through the door opening.
Maker of things
Publié : 04/05/2025 2:07 pm
1 personnes ont aimé
ssill2
(@ssill2)
I have two kits that are meant to ship soon.  This is good info.  I've not been a big fan of the phone app method of tuning.  Does the old-style petg printed device still work.  I keep one around for adjusting the belts on my two units.
Publié : 04/05/2025 2:23 pm
iftibashir
(@iftibashir)
Phone method didn't work for me - gave me readings all over the place. Only got it to work briefly. In the end I just went by feel. Luckily it looks like I got it close enough as all works perfectly!
Publié : 04/05/2025 7:23 pm
Barry Robbins
(@barry-robbins)
The phone method doesn't work for me either.  I printed the GT2 tension tool from Prusa on my MK4, the last system it was designed to print on.  Hoping that works for me.
Posted by: @iftibashir
Publié : 04/05/2025 7:28 pm
ssill2
(@ssill2)
yeah my readings were also all over the place.  As far as I can tell the when I put the needle in the middle between the lines things are fine.  I never had to do the tensioning on the XL since I bought it assembled, I'm a little leary of messing with that thing when the next hardware rev comes out for it.  I got an email mid last week that said they might have to use Fed instead of DHL but then a follow-up email that said DHL was good again lol.   What's duty like on these things?  I sure glad I ordered my 2 kits when I did.  The price of these has nearly doubled since I ordered them on the first of march
Publié : 04/05/2025 7:37 pm
gadget01
(@gadget01)
I figured out the other day that my phone was picking up low frequency noise from a ventilation fan running in the next room and interfering with the measurements. I closed the door to that room and bam- it started picking up on the belt strumming as intended.
Maker of things
Publié : 04/05/2025 10:29 pm
GreenPea
(@greenpea)
I anticipate the myriad of tiny nuts & bolts so printed some gridfinity on my 'old' printer and a slanted binholder on the laser. https://www.printables.com/make/2598053
Posted by: @gb160
Posted by: @ahalm
Loving the learning curve!
Publié : 05/05/2025 7:57 pm
iftibashir
(@iftibashir)
Video Build Guide now live!
Prusa Core One Video Build Guide
Publié : 05/05/2025 8:29 pm
4 personnes ont aimé
Page 10 / 10
