Prusa Core One - Intial thoughts......
Seite 4 / 8
Joern Markset
(@joern-markset)
Mitglied
RE: Prusa Core One - Intial thoughts......
I was surpriced by the tiny print area concidering Bambulab being a real competitor 🤔
Even though I`m a huge Prusa fan I think I`m gonna hold my horses a bit on this one. It`s tempting, but I gotta stay strong now 😂😂
Veröffentlicht : 20/11/2024 6:17 pm
sgyffy gefällt das
efvee
(@efvee)
To upgrade my MK4 to an MK4S costs €109.-
Then from MK4S to Core One €489.-
Totals €109.- + €489.- = € 598.-
New Core One kit costs € 1049.-
Difference €1049.- - €598.- = € 452.-
I hope my by that time one and a half year old MK4 will bring that amount when I sell it.
Veröffentlicht : 20/11/2024 7:21 pm
I highly suspected that the MK4S PC-CF parts were printed on either the AFS system or some other enclosed printer we didn't know about.  The print quality was incredible on those parts.
I can get the same quality on a Mk3S or Mk4S with a lousy LACK enclosure. The key is to really dry the living daylight out of the PCCF.
Veröffentlicht : 20/11/2024 9:01 pm
jseyfert3
(@jseyfert3)
Posted by: @iftibashir
Posted by: @sembazuru
Yeah, I've watched that video too much. 🤪 I just checked and the shot of the MMU3 is at 7:30 of the official video.
Ah yes I see - so looks like it will screw on to the outside of the frame - top rear - but also looks like the top cover of the frame has been removed? Either way it seems some imagination needs to go into spool placement again, as I assume Prusa's suggestion would be to fan them out behind the printer as before!
I don't think that would be Prusa's suggestion. They quietly (IMO) introduced an enclosure addon for the MMU3 for people that bought the MK4 + Enclosure + MMU3 bundle, that fairly neatly holds all 5 spools on the outside of the enclosure and buffer on the hinged lid. Pretty slick. Almost as slick as Chris Hill's solution. In fact what's interesting is that Prusa went with mounting spools on the outside of the enclosure for their MMU3 version, because the Prusa enclosure when ordered standalone comes with an interior spool holder, top right, just like Chris Hill's spool holder, and a bowden tube that routed to the Nextruder. Maybe they thought sticking 5 spools inside was to crowded?
Anyway, I'm going to print Chris Hill's solution, starting this evening, and have it hold me over until I get a Core One.
Veröffentlicht : 20/11/2024 9:05 pm
Ordered one pre-built ONE. Because why not 🙂 Will probably also upgrade my Mk4S's.
I think it's actually mindboggling that they offer an upgrade kit from Mk4S to One. I can't believe any other company would have done it.
My main reasons are:
1. Smaller footprint. I'm running out of space in my workshop and can really use the smaller footprint compared to my LACK enclosures
2. Better print quality at greater heights. At least on paper a CoreXY should do better with taller models.
3. I'm really not impressed at all with the "always perfect" first layer on my Mk4S's. PLA is fine but with PETG and ASA I need to manually adjust it almost every time. My old Mk3.5 and my Minis on the other hand… once Live Z is calibrated, I can just start the print and walk away. Now interestingly, I don't have the same problem with my XL even th0ugh the load cell is the same. Why? Beyond my pay grade. But I hope that the One will be on par with the XL and not the Mk4S.
Veröffentlicht : 20/11/2024 9:07 pm
Oregun gefällt das
vhubbard
(@vhubbard)
Prusa is addressing thermal stress with the steel parts in the Core One.  Thermal changes warp and twist a machine.    I worked with machine tools holding .001mm, and we worried when there was more than 2C temperature change in the shop.   3d printers are far from  .001mm tolerances, but they need to be better machines.
As the use of higher temp materials has gone up, PETG for printer parts is being eliminated.   MK4S part changes show this.
Using steel and no aluminum in the frame for consistent thermal expansion reduces deformation, but it still grows.   Example 30c delta of steel over the 270mm is .1mm.   Per layer this is not noticeable.   When your part comes out .1mm taller over 270mm that is usually within tolerance expectations.  A 270 mm PETG part will change height by .6mm over 30c by my calculations.   That is why PETG when allowed to cool to room temp usually just slides off the sheet.  The thermal size change vs. steel size change breaks it free.  Machine thermal size changes are currently hidden in the printed material size changes.
For current print tolerances thermal expansion is not a major concern, but the warping, twisting and stress caused by dissimilar materials in a machine frame is a concern.   The temperature control for material also provides a consistent temperature for the machine minimizing any deformation caused by temperature changes. It may seem minor now, but in a few years, when XY positioning capabilities move from the current .08mm to .02mm or better, it will become more noticeable.   With control of the temperature. exapansion can be predicted.  Then slicers can scale parts for thermal effects on the machine and part.
MMU3 buffer, spools will work as they always have.   I think we are asking is there a neater package for spools and buffer coming for the MMU3.
Veröffentlicht : 20/11/2024 9:35 pm
Brian gefällt das
gruagach
(@gruagach)
Really excited for this product.  I’ve been meaning to jump into 3d printing by buying a Prusa for many years now…the CORE One has likely pushed me over the edge.  I should have the funds saved up by spring.  The only concerns I have is regarding a filter solution.
Veröffentlicht : 21/11/2024 2:23 am
Oregun und nhand42 gefällt das
Armand
(@armand)
Well at least it seems the door wont break like other brands 😀
Veröffentlicht : 21/11/2024 6:28 am
Intveltr
(@intveltr)
The buffer and spool holder solution might need to be a 3rd party product or opensource project (for 3rd parties to sell as kits/assembiles). I imagine some sort of sensor on each filament. When it senses more than a centimeter or so of back-feed on the filament, it would trigger a motor to roll the spool backwards to take up slack.
The Filamentalist spool holder is a good solution that's worked well for me.  No motors; it uses a 1-way bearing to rewind the spool using the force exerted on the filament as it's being pushed back.  It makes loading the filament easy: with the spool sitting on the holder, you simply push the filament into the tube until the MMU3 picks it up.
Veröffentlicht : 21/11/2024 8:43 am
Pepan
(@pepan-3)
Definitely will upgrade. It checks all I need.
Veröffentlicht : 21/11/2024 10:03 am
ManelTo
(@manelto)
¡Preciosa!
Sorry for my poor English. I try to do my best.
Veröffentlicht : 21/11/2024 10:30 am
gruagach und nhand42 gefällt das
Nutthouse
(@nutthouse)
Mitglied
I am wondering if there will be an upgrade for the MK4S with MMU3 with or without an enclosure. I would love to see a kit that allows for MK4s with MMU3 to be upgraded or something that can modify the existing Prusa Enclosure. The main reason I got the Prusa is being able to upgrade, but if the upgrade for the Core is only for the Base model, then it is not as useful for all the people who bought the MMU3 and/or enclosure.
Veröffentlicht : 21/11/2024 11:20 pm
Scott
(@scott-18)
I was quite disappointed from my MK4S. Everyone seem to say they get as good results with it than a Bambu X1C. I got ton of ghosting no matter what I tried with my MK4S. Even Prusa Support didn’t do anything to help me as they ran out of idea.
My X1C gives me perfect results, and I can’t say that for my MK4S.
I really hope CORE One will be more consistent and will do a better job than my MK4S…
I absolutely wish I will love Prusa again, as with my first i3 MK3…
I also hope they will find a solution to well integrate MMU3 without doubling footprint of the printer.
Veröffentlicht : 22/11/2024 7:10 am
Pepan
(@pepan-3)
You can upgrade from MK4S with MMU3. But its sad, when someone just bought enclosure, that there is no path. I think Prusa should say something when mk4s went out. People who bought that with enclosure may be pissed off now.
Veröffentlicht : 22/11/2024 9:00 am
iftibashir
(@iftibashir)
You have to look at this from a business perspective. You can't release a new product and tell your buyers "here is our new printer, but we have another even better printer in the works too so you may want to hold on"!
Apple have released the iPhone 16, but they already have a 17, maybe even the iPhone 18 in the works already. You can't kill your sales in that way. The Core One has been announced, although I'm sure Prusa has already been looking into the next developments for it, all in order to keep up with technology and the competition.
What Prusa has done though, is provide plenty of notice - so in effect they've killed all their Xmas sales of the MK4s and people will now wait for the Core One, and place pre-orders instead. Moreover, they have a clear upgrade path for MK4S owners to move to the Core One with absolutely no compromises, which I do commend them for.
The MMU3 is an add-on, and its compatible with the Core One. In fact I have te MMU3 just delivered to me and waiting to be built. I'm still going to build and put it on my MK4s because if worst comes to the worst, it can be removed, the MK4s upgraded to the Core One, then the MMU3 put back on - no biggie.
The only people who may be disappointed is those who have the MK4s in an enclosure already, although for them its a choice of whether to upgrade and scrap the enclosure, or keep it and add the Core One alongside - depends on their use case and budget.
I feel the only thing Prusa need to crack is their shipping speed and their communication with those who have pre-orders. Finding out about late shipments and delays etc from an online forum is not on - they need to be emailing customers regular updates directly.
--> MK4 - MK4S - MINI+ - MMU3 - Accelerometer Guide - BambuLab A1 Combo <--
Veröffentlicht : 22/11/2024 9:25 am
Painted Futures, Oregun und jseyfert3 gefällt das
nhand42
(@nhand42)
Posted by: @pepan-3
The upgrade path is the same. Just remove the MK4S from the enclosure before starting the upgrade.
Veröffentlicht : 22/11/2024 9:49 am
Brian gefällt das
Pepan
(@pepan-3)
I understand. But its unusual for Průša to release printer and few months later release another you can upgrade to but you can throw away other stuff you bought (like enclosure). Dont take me wrong. Im absolutely thrilled and glad, there is even conversion path from mk4s to core one. When its online Im buying it. And Im also glad, I didnt invest in Prusa enclosure yet :-).
Veröffentlicht : 22/11/2024 10:37 am
iftibashir
(@iftibashir)
If I already had a MK4S in an enclosure, although the conversion can be done, as mentioned above it does mean having to resell or scrap the original enclosure, so personally I'd probably sit this one out and wait a while TBH.......
Luckily, I was close to purchasing the enclosure but the footprint and general size put me off........ glad I didnt go ahead with it now!! lol
Veröffentlicht : 22/11/2024 10:55 am
Oregun gefällt das
iftibashir
(@iftibashir)
The footprint for the Core One is smaller, which is great, but its a ton heavier in comparison because of all the steel.....
MK4S : 7 kg, 500×550×400 mm; 19.6×21.6×15.7 in (X×Y×Z)
Core One : 22,5 kg, 415×444×555 mm; 16.3×17.5×21.8 in (X×Y×Z)
Veröffentlicht : 22/11/2024 10:58 am
Oregun gefällt das
Lvet
 Lvet
(@lvet)
It’s not exactly the same.
Apple operates with a predictable roadmap—for example, every September/October, they announce a new line of iPhones. The same applies to iPads and MacBooks, with updates typically released every 12 to 18 months.
Prusa, on the other hand, had a 4-year gap between the release of the Prusa i3 MK3S and the Prusa MK4 (excluding the MK3S+, which was merely a minor update). This prolonged gap gave competitors like Bambu Labs an opportunity to enter the market unchallenged.
Now, within just a few months, we’ve seen the release of the MK4S and the announcement of the Prusa CORE One—just in time for the holiday season, potentially disrupting end-of-year sales. On top of that, every new product order requires a months-long wait, leading to the conclusion that Prusa’s business strategy is, at best, bizarre.
What keeps them afloat is the fact that they produce excellent products, enjoy a stellar reputation, and have a loyal, dedicated customer base.
Veröffentlicht : 22/11/2024 11:49 am
Painted Futures gefällt das
Seite 4 / 8
