Prusa CORE One + important links
Page 1 / 2
Jan Kratochvíl
(@jan-kratochvil)
Member Admin
Homepage for the Prusa CORE One
Did you know that each printer we produce has its own main section in our help section? It is your one stop location for links to everything you will need for your printer including the current up to date final release versions of;
  • Firmware
  • Drivers & Apps (includes PrusaSlicer)
  • Printable parts
  • Assembly manuals
  • 3D printing handbook
  • Helpful articles and guides
  • ...and a lot more
https://help.prusa3d.com/product/core-one
Printable 3D models:
Example models (verified G-codes) that are shipped on the USB Stick are also provided in our drivers and app package and can be downloaded as a part of the Drivers & Apps package, which is available here:
help.prusa3d.com/article/sample-g-codes_529630
Networking (Prusa Connect and PrusaLink)
We have an extensive collection of guides and articles on getting set up with either Prusa Connect or Prusa Link and adding various options to each. The can be found over here. help.prusa3d.com/category/prusa-connect-prusalink_1636
E-SHOP & Spare parts
Main page in the eshop for the CORE One
https://www.prusa3d.com/product/prusa-core-one/
Main page for parts; (please note, you have to be signed into your account on the eshop)
https://www.prusa3d.com/category/core-one/
Printable parts
Our Printables page for downloading spare parts, you can print yourself:
https://www.printables.com/model/1167816-core-one-printable-parts
This topic was modified 11 months ago by Jan Kratochvíl
Posted : 03/04/2025 4:50 am
5 people liked
altaic
(@altaic)
RE: Prusa CORE One + important links
Nice! Might want to add https://www.printables.com/model/1167816-core-one-printable-parts
Posted : 03/04/2025 5:01 am
Barry Robbins
(@barry-robbins)
Is it me or are the printable parts just limited to 1 item at the moment?
Posted : 04/04/2025 12:19 am
Jan Kratochvíl
(@jan-kratochvil)
Member Admin
The Printables link currently contains only PG adapter and we are working on a user printable parts. It should be released soon,
Posted : 04/04/2025 5:55 am
altaic
(@altaic)
Posted by: @jan-kratochvil
Any chance the printable nextruder parts will be released? I've got a few modifications in queue, but reconstructing everything is a pain.
Posted : 05/04/2025 1:32 am
Brian
(@brian-12)
Posted by: @altaic
It's the same as the MK4, so depending on the parts you need you can probably grab them from the MK4 parts.
Posted : 05/04/2025 2:02 am
altaic
(@altaic)
Posted by: @brian-12
Posted by: @altaic
Where would I find those? The open source at prusa page links to a github repo, but I didn't see the nextruder there, and I've looked on printables without luck.
Posted : 05/04/2025 2:54 am
Brian
(@brian-12)
Posted by: @altaic
Posted by: @altaic
Printables.
https://www.printables.com/model/451500-mk4smk39s-printable-parts
Posted : 05/04/2025 2:56 am
altaic
(@altaic)
Printables.
Perfect, thank you!
Posted : 05/04/2025 3:05 am
altaic
(@altaic)
Hmm, on closer examination, I think a few of the parts may be interchangeable with the Core One, but most unfortunately look quite different.
Posted : 05/04/2025 3:33 am
Brian
(@brian-12)
Posted by: @altaic
If depends on what you want models for.  The Nextruder itself of the same.  I imagine the gantry mounts and the fan duct are different.
You could do a comparison from the assembly manuals from the kits as well to see what's the same and what's different.
Posted : 05/04/2025 4:26 am
altaic
(@altaic)
I'm comparing with the low poly C1 gantry model in the Prusa Slicer assets. Well, that, and I can simply look at my machine and tell it's different.
The gearbox cover and idler assembly (plate, lever, swivel, and nut) look to be the same. Everything else is different. For that matter, even the electronics door from the Prusa Slicer assets is different from the one on my machine (which has only one screw and a notch).
Posted : 05/04/2025 5:17 am
cbutters
(@cbutters)
Any idea why the printable parts page was removed?
Posted : 12/04/2025 1:58 pm
Brian
(@brian-12)
Hopefully to upload all the parts.
Posted : 13/04/2025 2:51 am
Jan Kratochvíl
(@jan-kratochvil)
Member Admin
We are finalizing tests and preparing Printable parts to be updated 🙂
Posted : 14/04/2025 4:40 am
5 people liked
Chris Hill
(@chris-hill)
Seems like there's ben n update to the Core One printable files today: https://www.printables.com/model/1167816-core-one-printable-parts/files
Plenty to go at in there now.
Posted : 16/04/2025 12:36 pm
Barry Robbins
(@barry-robbins)
Poking around now and wondering if the PETG parts can be done in PCCF.  The one I'm asking about specifically is the Z motor mounts.  The design seems intended to offer flexibility and wondering if the change in material would be a problem.
Posted by: @chris-hill
Posted : 16/04/2025 12:51 pm
Jan Kratochvíl
(@jan-kratochvil)
Member Admin
The PCCF is recommended due to the enclosed chamber, where it can get pretty warm. If you try to print those parts in PETG, it may work for a while, but over time, the PETG will soften, and the printer may not function properly.
Posted : 17/04/2025 5:16 am
Chris Hill
(@chris-hill)
Hi Jan - I think Barry was asking about the other way around - can the PETG parts be printed in PCCF, or would that make the Z motor mounts too rigid, for example?
Posted : 17/04/2025 7:49 am
Jan Kratochvíl
(@jan-kratochvil)
Member Admin
Oh right. I would not recommend it for the motor mounts, as they need to move slightly, and PETG is a better material for this purpose. The same goes for the main cable clip that you have to open to get the cable through; using PCCF will crack that part if you try to open it. The rest of it sounds fine, but this procedure has not been tested, so I cannot guarantee it.
Posted : 17/04/2025 8:35 am
Page 1 / 2
