Print sheets across different printers
andynewsom
(@andynewsom)
I have a few print sheets for my MK3S. Would I be able to use them with the CoreOne? I assume the fit wouldn't be perfect, but as long as they aren't too big, they should work, no?
Respondido : 04/11/2025 8:02 pm
miroslav.h4
(@miroslav-h4)
MK3S print sheets can be used without any problems. They fit exactly.
Esta publicación ha sido modificada el hace 14 hours 2 veces por miroslav.h4
Respondido : 04/11/2025 9:06 pm
1 les gusta
RE: Print sheets across different printers
The only minor disadvantage is that the Core One purge area is over the silk screen which will peal off over time. However, this is a very minor issue and won't damage the sheet.
"Some filaments feel the rain, others just get wet"
- Bob Marley
Respondido : 05/11/2025 12:16 am
1 les gusta
chmax
(@chmax)
😀 ... unless you implement my modification to the gcode to allow random purge start location (to avoid what I experienced in my mk3 and mk4 where the purge line dug itself into the plate).
Posted by: @hyiger
Esta publicación ha sido modificada el hace 24 mins por chmax
Respondido : 05/11/2025 10:46 am
Mercur12
(@mercur12)
...but occasionally the purging fails because the nozzle lands on the smooth silk screen.
Respondido : 05/11/2025 10:48 am
