Print sheets across different printers
I have a few print sheets for my MK3S. Would I be able to use them with the CoreOne? I assume the fit wouldn't be perfect, but as long as they aren't too big, they should work, no?
MK3S print sheets can be used without any problems. They fit exactly.
RE: Print sheets across different printers
The only minor disadvantage is that the Core One purge area is over the silk screen which will peal off over time. However, this is a very minor issue and won't damage the sheet.
- Bob Marley
😀 ... unless you implement my modification to the gcode to allow random purge start location (to avoid what I experienced in my mk3 and mk4 where the purge line dug itself into the plate).
...but occasionally the purging fails because the nozzle lands on the smooth silk screen.
interesting, never had that so far!
I carefully scraped off the silkscreen in that area without damaging the surface of the board.
Then it worked again. I didn't dare try removing the lettering with solvent. 🙄
