Print sheets across different printers
andynewsom
(@andynewsom)
I have a few print sheets for my MK3S. Would I be able to use them with the CoreOne? I assume the fit wouldn't be perfect, but as long as they aren't too big, they should work, no?
Posted : 04/11/2025 8:02 pm
miroslav.h4
(@miroslav-h4)
MK3S print sheets can be used without any problems. They fit exactly.
This post was modified 4 months ago 2 times by miroslav.h4
Posted : 04/11/2025 9:06 pm
RE: Print sheets across different printers
The only minor disadvantage is that the Core One purge area is over the silk screen which will peal off over time. However, this is a very minor issue and won't damage the sheet.
Posted : 05/11/2025 12:16 am
chmax
(@chmax)
😀 ... unless you implement my modification to the gcode to allow random purge start location (to avoid what I experienced in my mk3 and mk4 where the purge line dug itself into the plate).
Posted by: @hyiger
Posted : 05/11/2025 10:46 am
Mercur12
(@mercur12)
...but occasionally the purging fails because the nozzle lands on the smooth silk screen.
Posted : 05/11/2025 10:48 am
chmax
(@chmax)
interesting, never had that so far!
Posted by: @mercur12
Posted : 05/11/2025 11:13 am
Mercur12
(@mercur12)
I carefully scraped off the silkscreen in that area without damaging the surface of the board.
Then it worked again. I didn't dare try removing the lettering with solvent. 🙄
Posted : 05/11/2025 11:47 am
All I want to do with my 2 Prusa Satin sheets is to dunk them in a barrel of solvent and then set them on fire. I'm so glad I got the Cryo sheets instead... But there is a whole thread on that so I won't hijack this one.
Posted : 05/11/2025 4:32 pm
miroslav.h4
(@miroslav-h4)
Posted by: @hyiger
But then don't forget to post a picture of the fiery execution of those printing plates here, so we can get something out of it too. 😀 😀
This post was modified 4 months ago by miroslav.h4
Posted : 05/11/2025 6:14 pm
Posted by: @miroslav-h4
To be fare, I'm still using one of the satin sheets but it's covered with polypropylene packing tape. I paid something around $40 for the Prusa PP powder coated sheet but then I found (to my annoyance) that the PP filament I use doesn't stick to it at all and a $2 roll of packing tape works way better. The other sheet? Will probably sacrifice it to the solvent vat along with my Prusa textured plate which is even more useless.
Posted : 05/11/2025 6:53 pm
Mercur12
(@mercur12)
@hyiger  If you're so dissatisfied with Prusa printplates, which ones would you recommend?
CryoGrip Pro Glacier? Others? ...and for PA/Nylon?
Posted : 07/11/2025 8:44 am
The CryoGrip Pro Glacier is what I use for everything except PP. Polypropylene can only stick to itself so the sheet surface has to be PP based.
I print a lot of PA/Nylon as well as ASA and it sticks perfectly to the CryoGrip. For TPU, it sticks too well so I sometimes need a glue layer (which is true of TPU and any sheet). PC filaments also stick really well. I even had a PC print warp and pull the sheet off the bed!
As for PLA (which I rarely print) and PETG I can run the CryoGrip 15-20C cooler than the Satin plate.
I also don't need to clean the CryoGrip between prints (or at all really). I just sometimes give it a wipe-down to remove any debris. The sheet itself is immune to finger prints.
Posted : 07/11/2025 3:25 pm
