MK4S to Core One Conversion Manual.
Page 2 / 2
Barry Robbins
(@barry-robbins)
RE: MK4S to Core One Conversion Manual.
It's interesting that the NFC set isn't reused give this is a common part.  Maybe removing it from the tape damages it?
Posted : 01/05/2025 3:40 pm
John
 John
(@john-3)
Posted by: @barry-robbins
I looked at my rods and they looked fine.  I did order replacement trapezoid nuts and bearings as they're not that expensive. Rods are an additional $50, so unless necessary I wouldn't.
Posted by: @ralf-4
I think my bearings and rods still work good on the MKS4. Are you thinking off replacing them in advance just to be on the safe side ?
What ist the usual lifetime in printing hours of these parts ?
best regards
Ralf
It does of course depend heavily on the usage of the printer. But as you already have it apart, replacing the bearings is a good idea. You only need 2 anyway. Especially the X and Y will degrade due to the load on them. You can hear and feel it when you move them over the rod on their own. In some cases a bad bearing can damage the rod by creating grooves in them, this can cause issues when printing. Just something to check when you have it apart.
Posted : 01/05/2025 3:57 pm
LarGriff
(@largriff)
Or was it an oversight in the manual?  I wouldn’t discard it unless you verify they sent another one.  😅
Prusa MK4S/MMU3
Bambu P2S/AMS2Pro
Posted : 01/05/2025 6:48 pm
John
 John
(@john-3)
Posted by: @largriff
It is probably two fold. Difficult to remove and reuse. And a very cheap part not worth the effort.
They our usually very generous with what they sent with upgrade kits. I have a box full of assorted screws and fasteners.
Posted : 01/05/2025 7:14 pm
KevinTi
(@kevinti)
Section 7 Step 24 in the Conversion kit manual refers to a new coil and cable in the Electronics and chamber parts package
Posted : 01/05/2025 8:53 pm
FergyMcFerguson
(@fergymcferguson-2)
The MMU3 Conversion kit also modified the location of the filament sensor while the MK4S did not.  That's the primary difference I believe.  Likely we will need to wait for an official MMU3 modification for the Core One nextruder.  I'll be keeping all my little pieces / parts in case this is something that can be done with the existing MMU3 upgrade parts.
Posted : 02/05/2025 1:10 am
iftibashir
(@iftibashir)
So it seems its a disassembly of the MK4, cleanup of the parts, and then pretty much a standard kit build for the Core One?
Posted : 02/05/2025 9:51 am
chmax
(@chmax)
apparently so, I hope it is simply the result of a cut&paste to create the first version, there are a number of changes I sure hope will be applied to the instructions in newer version. My biggest problem at the moment is the uncertainty on the old-style display. I ordered a kit for the old-style display, but the instructions don't mention the old display... I guess by the time the kit ships (june in my case) the instructions will be a little more detailed...
Posted : 02/05/2025 2:35 pm
Sembazuru
(@sembazuru)
Posted by: @chmax
I can't say for sure (not having either the upgrade kit nor the old style display), but I imagine the big thing would be a different back cover and where you re-attach the faston connector. You might want to compare the difference between the two displays on the MK4->MK4S upgrade instructions.
See my (limited) designs on:
Posted : 02/05/2025 7:44 pm
chmax
(@chmax)
That is not the point... I am interested about the readiness of the old style display'  kit version I have ordered and is supposed to ship with batch 7...
Posted : 02/05/2025 9:43 pm
Sembazuru
(@sembazuru)
Posted by: @chmax
Someone mentioned on the Kit waiting list thread that they heard that only the new LCD kits are ready and shipping, the old LCD kits should be "soon". I wonder if that is why the instructions don't mention the old LCD yet...
Take that with as large a grain of salt as you'd like. 😉
Posted : 02/05/2025 9:46 pm
FergyMcFerguson
Well that’s interesting as I have an old style display and I’m in Batch 1.  Guess we’ll see how that goes.
Posted : 02/05/2025 10:01 pm
Page 2 / 2
