MK4S to Core One Conversion Manual.
Page 1 / 2
Buells
(@buells)
The build manual is up!!!
https://help.prusa3d.com/guide/1a-introduction_207277
Publié : 30/04/2025 5:51 am
2 personnes ont aimé
Buells
(@buells)
Reused MK4S Parts
Publié : 30/04/2025 6:05 am
sh4q
 sh4q
(@sh4q)
RE: MK4S to Core One Conversion Manual.
I‘m wondering if I need to modifiy the nextruder of my MK4S with MMU3, or if i can leave it as it is.
Publié : 30/04/2025 8:27 am
chmax
(@chmax)
Did I miss the instructions for the older type of display? The version I clicked though seems to have only the steps for the newer display version...
Publié : 30/04/2025 8:52 am
Ondrashek
(@ondrashek)
You can print as usual without MMU3. Just needed to be disabled on menu 🙂
Publié : 30/04/2025 9:47 am
John
 John
(@john-3)
Excellent, just ordered some new steel rods, and I can rebuild the remaining parts as MK3S.
Publié : 30/04/2025 10:58 am
Rappayellow
(@rappayellow)
Membre
Looking through the manual super quickly, it looks like you don't need to do anything to the extruder minus remove the fans and cage.  Everything else stays the same.  What I do not know is how the cable feeds to the buddy board.
Publié : 30/04/2025 11:16 am
John
 John
(@john-3)
Chapter 6, step 17 and on.
Publié : 30/04/2025 2:07 pm
1 personnes ont aimé
AvariCe
(@avarice)
Maybe I'm an idiot, but on this step there is no mention of the purple screw. Is there something I missed?
Publié : 30/04/2025 2:08 pm
LarGriff
(@largriff)
There is no mention of what to do about Nextruders that have already had MMU3 modifications.  Should they be reverted to stock or used as is?  I think the differences are: baseplate, idler arm, latch, filament sensor.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Publié : 30/04/2025 3:16 pm
Dennis
(@dennis-4)
I didn't see any mention of this but just want to be sure.
We don't need to pre-print any parts for this conversion, correct?
Dennis
Publié : 30/04/2025 7:06 pm
S
 S
(@s-2)
The guide mentions that you may want to print a new lubrication pacifier for the bearings you will be re-using, but that's it:
https://help.prusa3d.com/guide/1a-introduction_207277#887473
Publié : 30/04/2025 7:23 pm
BPearce
(@bpearce)
Membre
My admittedly vague recollection is that both the MK4S conversion and the MMU3 conversion modified the Nextruder using the same parts -- so if you have an MK4S with or without an MMU3, you should be all set. (This could probably be confirmed by looking at the documentation for the MK4S and MMU3.)
Publié : 30/04/2025 8:04 pm
Ondrashek
(@ondrashek)
Correct
Parts
Publié : 30/04/2025 8:10 pm
Dennis
(@dennis-4)
Thanks.
Publié : 30/04/2025 8:58 pm
iftibashir
(@iftibashir)
Posted by: @largriff
I actually already removed my MMU3 prior to receiving the Core One as I wanted to move it across, but I'm not so sure now. Thinking of keeping the Core One single colour and putting the MMU3 back on the MK4s!
Anyways, in your situation I would leave the plate as its a 'harder wearing' one anyways, but would remove the idler and replace with the original filament sensor (spring/magnet/ball) configuration. It only takes a few minutes and could rule out any possible issues later. If I weren't filming my build to create the video guide I would have stuck the plate and o-ring that comes with the MMU3 kit into my Core One Nextruder TBH - personally I think this should be a standard part.
Publié : 01/05/2025 8:52 am
iftibashir
(@iftibashir)
Looking at everything that comes out, and the items you are left with after the conversion, I feel I'd rather buy the kit and keep the MK4s as it is......
Publié : 01/05/2025 8:53 am
Ralf
 Ralf
(@ralf-4)
I think my bearings and rods still work good on the MKS4. Are you thinking off replacing them in advance just to be on the safe side ?
What ist the usual lifetime in printing hours of these parts ?
best regards
Ralf
Publié : 01/05/2025 12:01 pm
Canadian Custom Woodwerx
(@canadian-custom-woodwerx-2)
Wonder if it comes with the new core one print sheet. I don't see it pictured in the "things to keep" from mk4s disassembly
Publié : 01/05/2025 1:54 pm
Barry Robbins
(@barry-robbins)
I looked at my rods and they looked fine.  I did order replacement trapezoid nuts and bearings as they're not that expensive. Rods are an additional $50, so unless necessary I wouldn't.
Posted by: @ralf-4
best regards
Ralf
Publié : 01/05/2025 3:28 pm
Page 1 / 2
