How to decrease Print Start Time
GeneMpls
(@genempls)
I see an older thread on this- hoping there might be some other fixes for those of us who only print PETG and short prints for prototypes. I have a MK4s also.
Publié : 09/12/2025 7:11 pm
For the absorb heat phase you can either press "skip" on the UI screen or disable for certain filament types in gcode. To do the later you can add the following to the Printers->Custom G-code section or you can simply remove (or comment out) the G29 G ; absorb heat line.
{if filament_type[initial_tool] !~ /.*(FLEX|PLA|PETG).*/}
G29 G ; absorb heat
{endif}
As for (temporarily) skipping the bed leveling and reusing the previous mesh. You can comment out this section:
; MBL
M84 E ; turn off E motor
;G29 P1 ; invalidate mbl & probe print area
;G29 P1 X150 Y0 W100 H20 C ; probe near purge place
;G29 P3.2 ; interpolate mbl probes
;G29 P3.13 ; extrapolate mbl outside probe area
;G29 A ; activate mbl
Also, for example, perhaps save the profile as "Prusa CORE One 0.4 nozzle (skip bed level)" I wouldn't skip bed leveling all the time. If you are doing a print, remove the previous print then do another then it's probably safe to skip. I usually don't bother with this unless it's a really small print.
Ce message a été modifié il y a 2 days par hyiger
Publié : 09/12/2025 7:57 pm
mnentwig
(@mnentwig)
What I'd do is go through the profile's G-code and remove the problematic codes. M109 and G29 G come to mind (for me it's OK to calibrate at uncontrolled nozzle temperature but of course you need it once for printing)
edit 1 min late - see above.
Ce message a été modifié il y a 2 days 2 fois par mnentwig
Publié : 09/12/2025 7:58 pm
GeneMpls
(@genempls)
RE: How to decrease Print Start Time
I would love to see something in the PrusaSlicer to bypass it {hint,hint Jos}- I built mine and don't even have all the cladding on the case. Thanks guys, Gene
I am guessing that they never considered anyone using without needing the heatsoak, but I have Prusas going back many years and we do exist.
Publié : 10/12/2025 4:46 pm
