For those getting the INDX are you getting the 4 head or 8 head?
Are you getting the 4 head INDX, 8 head or passing? Poll is created on Dec 15, 2025
Página 1 / 2
I don't see myself doing prints with lots of colors (maybe occasionally 2 or 3 colors) I would mostly be doing multi-material prints. So I'm thinking "4 is good enough" but then I'm in some sort of FOMO situation if I don't get the 8... I don't have any experience working with a multi-toolhead setup so I'm trying to think of a use-case to justify getting 8 heads. I suppose I could keep my top-8 filaments always loaded and assigned to a nozzle. But then the nylons can't stay in a dry box for too long anyway.
I guess I'll start with 4 heads and add more if needed later.
Respondido : 15/12/2025 8:56 pm
Fwiw I have never needed more than 4 heads on my XL ... OK it *might* be useful to have more for big prints if spool-join was likely to be needed but that's a fairly extreme use-case.
Respondido : 15/12/2025 9:12 pm
vega480
(@vega480)
RE: For those getting the INDX are you getting the 4 head or 8 head?
8 for sure! I print magnets. Most were 3-4 colors. Only for a family business. Now that I am moving onto making my own designs to print and sell. I maxed my 5 colors. And had to make some changes to bring it down to 5. I look forward to more colors. I also look forward to multiple nozzle sizes. A larger one for infill, 0.4 for general details, 0.2 for clear small text. And as I branch out, I am looking to do something that includes a flexible filament. Even if I stick to lower color amounts, keeping 8 loaded could allow for a single machine to cover more of my designs without changing filaments out too often. Already looking to max out my Core One L once they release that beast of an INDX setup.
Respondido : 15/12/2025 10:05 pm
1 les gusta
I already use multiple sizes - my setup is usually 3x0.6 (one hardened) and 2x0.4  The larger nozzles are for larger, strong sections and the smaller for functional details like involutes, threads and print-in-place bearings; I have tried smaller nozzles but for me the strength trade-off is unacceptable.  It's rare to need more than two colours for labels and graticules, very occasionally three when one 'colour' is transparent to allow LED lights to shine through panel indicators.
I generally bypass the ptfe tubes when printing flexibles, rather than using Prusa's interleaved anchors I intersect closed loops to get really strong connections.
Respondido : 15/12/2025 10:36 pm
Four for now. I have an XL-5T and an MMU attached to one of my Core Ones and hardly ever use all extruders. For a while I dabbled with having a 0.6 mm nozzle on the XL but didn't find much use for it.
My personal preference aside, the fact that you're even asking the question tells me you don't have an urgent and obvious need for 8 extruders. So why spend the money. Instead go with 4 and if you find yourself longing for more after a while, one advantage of the INDX system is they're cheap.
Respondido : 16/12/2025 12:48 am
Posted by: @foxrun3d
Well I don't need 8 for sure and given my current workflow and design ideas even 2 would probably be enough... Just trying to see if there is an use case I overlooked. Cost is not something I'm factoring into this. Indeed I will start with 4.
And I was certain that 5 head XL owners would chime in as to how their tool heads were being utilized. So at minimum it makes for an interesting conversation.
Respondido : 16/12/2025 1:23 am
iftibashir
(@iftibashir)
I have no need for 8. But if I am to get the INDX system I would just go all in or nothing at all. I don't want that FOMO feeling later! lol
TBH I have 13 colours feeding my H2D at the moment - I use it more for having the colours loaded and ready without having to manually load/unload all the time. I dont think I have every gone over 4 colours for any multicolour print - but that could change if I see there's very little wastage now! I'm planning to get the Vortek system for the H2D to reduce wastage but I do still think the INDX system is better overall - and much faster too.......
Respondido : 16/12/2025 8:50 am
chmax
(@chmax)
I am hoping to see some price structure before I need to decide 4 vs 8. If upgrading to 8 later is more expensive than the founder's edition 8 version I will go for 8 even if I currently do not need more than 4...
Respondido : 17/12/2025 1:27 pm
vhubbard
(@vhubbard)
4 at first, you can always add to it if needed. If multi-nozzles for 1 print were supported, I would go with 8. Small nozzle for perimeters, larger for infil, Layer matching etc. It bup to the slicer software folks to make the multi-heads more usable.
Respondido : 17/12/2025 5:22 pm
vhubbard
(@vhubbard)
Edit broken again... ... Small nozzle for fine details on perimiters, larger for infil. Layer matching etc. will be up to the slicer software folks to make the multi-heads more useful.
Respondido : 17/12/2025 5:26 pm
I'll try to ask over on discord but I'm thinking "What if I only need 5 or 6?" I should just be able to get the 8 and remove 2 or 3 and keep them as spares right? Or even if I really only need 4, I can use the other 4 as spare replacement parts.
Respondido : 17/12/2025 5:40 pm
1 les gusta
chmax
(@chmax)
or leave them all installed and offline the one that fails... I like this idea.
Posted by: @hyiger
Respondido : 18/12/2025 1:41 pm
iftibashir
(@iftibashir)
Posted by: @hyiger
I'd leave the 8 installed. If you don't need them just yet, thats fine, but you have the option. Better than just keeping additional as spare parts doing nothing.....
Respondido : 18/12/2025 3:00 pm
1 les gusta
Posted by: @iftibashir
But the eight tools will largely block your view of the print area. Add the black lid on top, and block the side windows with the side-mounted spools (or even Prusa's slightly larger dry boxes) as shown in the promo shots and at FormNext, and you will hardly be able to check on your print.
Respondido : 18/12/2025 7:58 pm
chmax
(@chmax)
Posted by: @jurgen-7
Good point, I guess I will look at the black top stl file once out and see if I can embed a downward periscope (that sounds much better than a little mirror pointing down) 😀
Respondido : 19/12/2025 1:08 pm
GBMaryland
(@gbmaryland)
Am I mistaken or did Vordick just say that Q2 is the earliest they’re going to release general sales of the INDX? (could have sworn that it was Q1 initially…)
I guess I’ll be upgrading that H2D to an H2C…
Respondido : 20/12/2025 9:34 am
It was "Shipping starts at the end of Q1 for the pre-ordered Founders' Edition". Which aligns nicely with general sales starting some time in Q2.
Respondido : 20/12/2025 10:41 am
Posted by: @gbmaryland
Am I mistaken or did Vordick just say that Q2 is the earliest [...]
Oh, by the way -- who is Vordick? Someone at Bondtech? I don't think I have come across the name yet.
Respondido : 20/12/2025 11:58 am
GBMaryland
(@gbmaryland)
Bahahaha… that’s my phone in English getting confused about a non-English word… And translating it into the name of someone I know. Go figure; Grammatical error.
Yeah, their website now says Q2 and I’m taking that to me a Prusa Q2.  (aka, the beginning of Q3… 🥴 )
As such, I just took the INDX money I had set aside and bought the 40 W laser for the H2D I also have…
Esta publicación ha sido modificada el hace 6 days por GBMaryland
Respondido : 20/12/2025 1:24 pm
gb160
(@gb160)
I'll get 8, most probably only install 4 initially.
The reason I'll get 8 is that we've no idea what availability will be like wrt to single nozzles... could take months to be able to get any more.
Also it's very likely that the general release prices will be bumped compared to founders edition.
Respondido : 20/12/2025 1:46 pm
Página 1 / 2
