Display Core One Einstellung
Mario Anders
(@mario-anders)
Hallo, brauche mal Hilfe zu meinem Core. Jedesmal wenn ich einen Druck anstosse mit dem PC dann muss ich zu dem Drucker rennen und aud den Knopf drücken damit der Druck startet. Mein MK4s macht das nicht. Hat jemand nen Tip ob man das ausstellen kann?
Also ich schicke den Druck ab und dann steht im Display "ob der Bauraum sauber ist u.s.w"
Opublikowany : 22/07/2025 8:43 pm
tbr
 tbr
(@tbr-2)
RE: Display Core One Einstellung
Du bist hier im englischen teil des Forums gelandet.
I don't think I've seen such a question on the Core One display and I'm printing all the time via the Prusa Slicer and Prusa Connect.
Could it be that you have some custom GCode that injects this? Also if you haven't upgraded yet, a new firmware (6.3.4) is out.
Opublikowany : 24/07/2025 8:32 am
I can't recall a prompt to check that the build area is clear. But there is a prompt that reminds the user to open or close the ventilation grille, depending on the filament type.
Good news: Since firmware version 6.3.3 the prompt times out after a minute or so. Since firmware version 6.3.4 you can disable this prompt entirely via Settings → Hardware → Check Ventilation Grilles. Hence, no need to head over to the printer to start a print.
Opublikowany : 24/07/2025 11:48 am
tbr
 tbr
(@tbr-2)
I might have a lead. I just noticed that the slicer asked me to confirm these things when I went to "Set Ready".
Maybe @marioanders191-1 hasn't noticed that you can set the printer "ready" remotely?
Opublikowany : 26/07/2025 8:03 am
