					                		Core One MMU3 Prototypes - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/</link>
                <lastBuildDate>Sat, 16 May 2026 20:27:18 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/15/#post-757056</link>
                        <pubDate>Thu, 10 Jul 2025 20:04:39 +0000</pubDate>
                        <description><![CDATA[My 1m MMU cable from Blurolls arrived today, so naturally I had to drop everything and try it out.
First step - replace the original cable and test it on the MK4S that the MMU is originally...]]></description>
                        <content:encoded><![CDATA[<p>My 1m MMU cable from <a href="https://www.blurolls3d.com/products/blurolls-prusa-mmu3-extended-1-meter-cable-for-prusa-core-one-mk39-mk4s-3d-printer-multi-filament-printing?VariantsId=11076" target="_blank" rel="noopener">Blurolls</a> arrived today, so naturally I had to drop everything and try it out.</p>
<p>First step - replace the original cable and test it on the MK4S that the MMU is originally fitted to.  Works fine.</p>
<p>Next step - take the plunge and try it out on the CORE One.  The cable is plenty long enough now to reach the side-mounted MMU (using @dancan13f's mounting rail), and power and control work just fine.  Unfortunately, my original plan to feed the output of the MMU into the side filament sensor isn't going to work, because the total path from the MMU, via the filament sensor, and through the original bowden tube, is about 1.4m, and the maximum bowden length that can be set in the firmware is 1m.  Whatever length is set in the firmware is the distance that is loaded 'at speed', and then the loading speed drops while it waits for the filament sensor to trigger, but my impression is that it will only do this up to a total length of 1m.  So when I set 1m, hoping that the last 40cm or so would be loaded more slowly, that didn't work - it loaded 1m at speed and then immediately gave up and unloaded back to the finda.</p>
<p>No matter - I had already printed @dancan13f's top-mounted pass-through and had had a new acrylic top panel made, so I just fitted a replacement bowden through that pass-through.  After adjusting the bowden length in the firmware it now quick-loads to within a couple of cm of the filament sensor and then slows down for the last little bit.  The bowden goes through the original bowden bend on top of the Nextruder, and the MMU seems to have no trouble at all pushing the filament round that bend.  I guess I now need to print the <a href="https://help.prusa3d.com/guide/9d-core-one-nextruder-mod_111779#892321" target="_blank" rel="noopener">extruder_PTFE_holder</a> to secure the original bowden tube out of the way.</p>
<p>I haven't printed anything yet, but I've loaded and unloaded the filament numerous times while adjusting the bowden length, and it's worked perfectly.  And it's nice to finally see a filamentalist rewinder doing its thing!  Flawless so far.</p>
<p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/07/3103df6e-img_6430-scaled.jpg"><img class="alignnone size-medium wp-image-178469" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/07/3103df6e-img_6430-600x500.jpg" alt="" width="600" height="500" /></a></p>
<p>So far the rewinders are all connected up with lengths of PTFE tube that I already had, but I plan to cut some to more bespoke (shorter) lengths once I'm happy with the setup.  I've swapped the order - the nearest rewinder goes to input no.1, which is the furthest away on the MMU, because no.1 is the easiest to load and I didn't want to get used to using no.5 most of the time!</p>
<p>So far I'm pleased with the setup.  The MMU is much more accessible on the side than it would be at the back in my setup, and I'm quietly confident that this setup is going to work well.  </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Chris Hill</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/15/#post-757056</guid>
                        <title>RE: Core One MMU3 Prototypes</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/15/#post-755524</link>
                        <pubDate>Thu, 26 Jun 2025 08:10:31 +0000</pubDate>
                        <description><![CDATA[&gt; Can I do the same on Core One?Yes, that worked fine here, just turn off the MMU in the menu and change the PTFE tube.&gt; Also, do I have to go through all the calibration business when...]]></description>
                        <content:encoded><![CDATA[<p>&gt; Can I do the same on Core One?</p><p>Yes, that worked fine here, just turn off the MMU in the menu and change the PTFE tube.</p><p>&gt; Also, do I have to go through all the calibration business when the MMU3 has already worked with MK4S? </p><p>I didn't. Worked just fine.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Hari Hurtig</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/15/#post-755524</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/15/#post-755205</link>
                        <pubDate>Mon, 23 Jun 2025 18:59:21 +0000</pubDate>
                        <description><![CDATA[The manual on upgrading the MMU3 form MK4S to Core One confuses me a bit. It is not always clear when it guides you installing your MMU3 that functioned on your old MK4S or if you are instal...]]></description>
                        <content:encoded><![CDATA[<p>The manual on upgrading the MMU3 form MK4S to Core One confuses me a bit. It is not always clear when it guides you installing your MMU3 that functioned on your old MK4S or if you are installing a new MMU3.On my old MK4S (now converted to Core One) printer I swapped between using MMU3 for multi-colour printing and single-colour printing using a seperate single spool by just changing the the PTFE on the nextruder. It worked great and without problems. Can I do the same on Core One? (I am installing ther MMU3 Light Version, just attaching it to the back of the top frame).Also, do I have to go through all the calibration business when the MMU3 has already worked with MK4S? Of couse, I have to flash the latest MMU3 firmware.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>NielsE</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/15/#post-755205</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/15/#post-754709</link>
                        <pubDate>Thu, 19 Jun 2025 12:39:46 +0000</pubDate>
                        <description><![CDATA[Posted by: @mercur12 Did you see this one? Exactly my intention ! Vary good work ! Thanks to  @jvitrivery nice. Alas, not really an option in a farm environment with multiple printers next t...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="536999" data-postid="754689" data-mention="mercur12"><div class="wpforo-post-quote-author"><strong>Posted by: @mercur12 </strong></div><p>Did you see this one? Exactly my intention ! Vary good work ! Thanks to  @jvitri.</p><p>https://www.printables.com/model/1321861-mmu3-lateral-droit-pour-prusa-core-one</p></blockquote><p>Looks very nice. Alas, not really an option in a farm environment with multiple printers next to each other. </p><p>At this point I'm most likely to go with https://www.printables.com/model/1283543-prusa-core-one-mmu3-install-and-mmu3-setup —if I ever find the time...</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>FoxRun3D</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/15/#post-754709</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/15/#post-754708</link>
                        <pubDate>Thu, 19 Jun 2025 12:30:41 +0000</pubDate>
                        <description><![CDATA[Posted by: @iftibashir Anyone purchased?we waiting for the &#039;next-gen&#039; solution, whenever that may be....?Yup... I did.  Waiting for it to arrive. Though, to be honest, I&#039;ve also printed the ...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="512590" data-postid="752303" data-mention="iftibashir"><div class="wpforo-post-quote-author"><strong> Posted by: @iftibashir </strong></div><p>Anyone purchased? https://www.prusa3d.com/product/original-prusa-mmu3-enclosed-for-core-one-full-kit/</p><p>Or we waiting for the 'next-gen' solution, whenever that may be....?</p></blockquote><p>Yup... I did.  Waiting for it to arrive. Though, to be honest, I've also printed the full community version with the Ultramarine Blue (Prussian Blue) accents instead of the Netherlands orange, er, I mean Prusa Orange. ;)  Gotta keep some things German... </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>GBMaryland</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/15/#post-754708</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/15/#post-754689</link>
                        <pubDate>Thu, 19 Jun 2025 08:06:21 +0000</pubDate>
                        <description><![CDATA[Did you see this one? Exactly my intention ! Vary good work ! Thanks to  @jvitri]]></description>
                        <content:encoded><![CDATA[<p>Did you see this one? Exactly my intention ! Vary good work ! Thanks to  @jvitri.</p><p>https://www.printables.com/model/1321861-mmu3-lateral-droit-pour-prusa-core-one</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Mercur12</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/15/#post-754689</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/15/#post-753421</link>
                        <pubDate>Mon, 09 Jun 2025 13:11:54 +0000</pubDate>
                        <description><![CDATA[Ordered Posted by: @mercur12 Thanks for the link. I just ordered..]]></description>
                        <content:encoded><![CDATA[<p>Ordered</p><blockquote data-userid="536999" data-postid="753399" data-mention="mercur12"><div class="wpforo-post-quote-author"><strong> Posted by: @mercur12 </strong></div><p>Thanks for the link. I just ordered..</p></blockquote><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>David R. Campbell</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/15/#post-753421</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/15/#post-753399</link>
                        <pubDate>Mon, 09 Jun 2025 09:38:41 +0000</pubDate>
                        <description><![CDATA[Thanks for the link. I just ordered..]]></description>
                        <content:encoded><![CDATA[<p>Thanks for the link. I just ordered..</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/15/#post-753399</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/15/#post-753394</link>
                        <pubDate>Mon, 09 Jun 2025 08:52:15 +0000</pubDate>
                        <description><![CDATA[Blurolls sent me a link for the 1m version, in case anyone else is interested]]></description>
                        <content:encoded><![CDATA[<p>Blurolls sent me a link for the 1m version, in case anyone else is interested.</p><p>https://www.blurolls3d.com/products/blurolls-prusa-mmu3-extended-1-meter-cable-for-prusa-core-one-mk39-mk4s-3d-printer-multi-filament-printing?VariantsId=11076</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/15/#post-753394</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/14/#post-753296</link>
                        <pubDate>Sun, 08 Jun 2025 13:29:36 +0000</pubDate>
                        <description><![CDATA[Posted by: @mercur12 From this, I conclude that extending the cable by a few centimeters does not affect data transmission from /to MMU.Good work 👍  Posted by: @mercur12 To be on the safe si...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="536999" data-postid="753278" data-mention="mercur12"><div class="wpforo-post-quote-author"><strong> Posted by: @mercur12 </strong></div><p>From this, I conclude that extending the cable by a few centimeters does not affect data transmission from /to MMU.</p></blockquote><p>Good work 👍 </p><blockquote data-userid="536999" data-postid="753287" data-mention="mercur12"><div class="wpforo-post-quote-author"><strong> Posted by: @mercur12 </strong></div><p>To be on the safe side, I prefer a length of 1.20 m. Can you tell me the source at Blurolls/Ali where I can order this?</p></blockquote><p>I simply messaged the seller of <a href="https://www.aliexpress.com//item/1005008707216091.html" target="_blank" rel="noopener">this item</a>.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-mmu3-prototypes/paged/14/#post-753296</guid>
