Core One MMU - Next Gen Solution
Page 2 / 3
iftibashir
(@iftibashir)
RE: Core One MMU - Next Gen Solution
Thats looks decent!
So feeds into printer from where?
Posted by: @p1r4m4x
More simple without glass cut. 🙂
Publié : 27/06/2025 10:50 am
David R. Campbell
(@david-r-campbell)
Looks like they snuck it in through the back right corner.  @p1r4m4x what did you use for a mount?
Posted by: @iftibashir
Thats looks decent!
Posted by: @p1r4m4x
Publié : 27/06/2025 11:48 am
P1R4M4X
(@p1r4m4x)
Yes i used the pliers to slightly bend a bit the right corner and it follow the original swing arm path.
I made this MMU mount, you can find it there: https://www.printables.com/model/1334245-mmu3-holder-for-core-one
I like the fact that it doesn't distort the Core One.
Publié : 28/06/2025 1:13 pm
1 personnes ont aimé
boomboom21
(@boomboom21)
Very cool.  Have you had any problems not using a buffer?  Does filament fall off a full spool with a retraction?
Publié : 28/06/2025 2:17 pm
P1R4M4X
(@p1r4m4x)
I use a printed auto rewinder without problems for now. The buffer is an OLD gen system we are in 2025...  🤣
My full holder if ever: https://www.printables.com/model/1336573-mmu3-auto-rewinder-holder-for-ikea-skadis
Posted by: @boomboom21
Publié : 28/06/2025 3:47 pm
David R. Campbell
(@david-r-campbell)
I have limited vertical room above my CORE One.  With your mount what is the total vertical height above the machine?
Posted by: @p1r4m4x
Publié : 29/06/2025 12:54 am
P1R4M4X
(@p1r4m4x)
@david-r-campbell the mount + MMU3 take only 12cm above the machine.
Publié : 29/06/2025 5:58 pm
David R. Campbell
(@david-r-campbell)
Much appreciated.
Posted by: @p1r4m4x
Publié : 29/06/2025 11:16 pm
DiscoJon
(@discojon)
https://www.printables.com/model/1335447-integrated-spool-holder-buffer-for-core-one-mmu3
Publié : 30/06/2025 1:08 am
2 personnes ont aimé
iftibashir
(@iftibashir)
Thats actually a really neat design!
Posted by: @discojon
Publié : 30/06/2025 8:05 pm
Scotttomo
(@scotttomo)
I spotted this last night and saved on Printables. Was wondering, can you have 5 of these clicked together in a row?
Publié : 01/07/2025 5:49 pm
DiscoJon
(@discojon)
I don't have any provisions in the model for securing them together but it would be a simple inclusion.
Publié : 01/07/2025 6:18 pm
iftibashir
(@iftibashir)
Is there enough space in the buffer for the longer length that needs to be retracted on the Core One?
Publié : 01/07/2025 7:26 pm
DiscoJon
(@discojon)
I am using it with my Core one so yes.  I have the MMU3 mounted using the Prusa MMU3 mounts, and I am using the Prusa supplied front PTFE tube
Publié : 01/07/2025 7:33 pm
Vertex
(@vertex)
So this Next Gen Solution looks very far off, but I'm in the need of a solution today. After looking at the Prusa website for MMU3 upgrades I do not see a clear shopping and printing list I need for the core one. Could someone help provide what they have done on a net new MMU3 setup on a core one?
Publié : 02/07/2025 3:02 pm
iftibashir
(@iftibashir)
So you're not running down the PTFE that's attached to the swing arm?
Publié : 02/07/2025 9:10 pm
DiscoJon
(@discojon)
Yes. I am using the 710mm tube that comes with the Core ONE.  I just rerouted it from the filament sensor on the side panel to the front of the MMU
Publié : 02/07/2025 9:46 pm
teeloo
(@teeloo)
A hot end revolver with multiple extruders in one head unit. So that all media is already in a print state (liquified).
2 options: multiple extruders in one head or one extruder with a revolver type hot end on top that can cycle through media all in fluid state.
Publié : 02/07/2025 10:26 pm
DiscoJon
(@discojon)
You can't keep most thermoplastics above their glass temperature for that long of they will begin to break down.
Publié : 02/07/2025 10:29 pm
teeloo
(@teeloo)
Ah ok. Then that’s no good. thanks.
Publié : 02/07/2025 11:10 pm
Page 2 / 3
