[Oben angepinnt] Core One + Community project build
Seite 1 / 2
Same Old Shane
(@same-old-shane)
Mitglied Admin
Greetings all;
Myself and a few others in community management thought it might be interesting to take a core one + and build a stripped down version. So it would basically be the frame, back plate, extruder and bed and then go through community created mods and projects and add it onto the build and see what the end results would be.
So I am opening this up for submissions and if you would like to make a recommendation, respond to this post and include a link to the project. We will then go through the submissions and see what is possible with other submissions. This is open to just about any modification or project for a core one, and after the barebone build, we will then look at the submissions and see what can be added.
Once chosen we will add the modifications on, one at a time and post updates and the end result will have a core one + "community" project printer.
Please note, they are suggestions / recommendations and no guarantee nor assurances they will be used as we have to look at all submissions and then see what will work with other ones.
For submissions, please include the links to the projects on printables.
So let us know what you would like to see on a core one + and see what we can dome up with.
Dieses Thema wurde geändert Vor 2 months von Same Old Shane
Shane (AKA FromPrusa)
Veröffentlicht : 31/03/2026 9:59 am
3 weiteren Personen gefällt das
jan.d.slay
(@jan-d-slay)
RE: Core One + Community project build
Is it okay for me to post links to things I’ve found, such as printables?
Veröffentlicht : 31/03/2026 10:09 am
Tommy_Prusa3D CM
(@tommy_prusa3d-cm)
Mitglied Admin
Can you paint all of the frame pieces Prusa Orange?
Veröffentlicht : 31/03/2026 10:19 am
Same Old Shane
(@same-old-shane)
Mitglied Admin
Posted by: @jan-d-slay
Yes, you can post links to pintables since as far as I know, the majority of all projects for the printer is on Printables.
Veröffentlicht : 31/03/2026 10:21 am
Same Old Shane
(@same-old-shane)
Mitglied Admin
Posted by: @tommy_prusa3d-cm
Yes, I will get you the spraypaint can and you can go to town :p
Veröffentlicht : 31/03/2026 10:22 am
Plastic Golem
(@plastic-golem)
Chamber heater using a steel side panel, please 🙏
Veröffentlicht : 31/03/2026 10:30 am
Rainer
(@rainer-2)
Perhaps in a community version with integration into the firmware. Unfortunately, I can’t do that myself.
https://www.printables.com/model/1608753-prusa-core-one-heater
Veröffentlicht : 31/03/2026 10:31 am
jan.d.slay
(@jan-d-slay)
Nozzle Wiper
My Nozzle Wiper
Advanced filtration for Core One
Snap-in Corner Block Plug in
Quick Swap Dual and Single Idler lever
Veröffentlicht : 31/03/2026 11:13 am
CarVac
(@carvac)
Mitglied
This set for bed plate holding:
https://www.printables.com/model/1446923-crushed-legs-with-expandable-support-for-multiple
https://www.printables.com/model/51462-expandable-steel-sheet-holder-mk-mini
These shims for better bed tramming:
https://www.printables.com/model/1289015-prusa-core-one-bedlevel-correction-dust-cover
Veröffentlicht : 31/03/2026 11:18 am
ulli_ulli
(@ulli_ulli)
Mitglied
And for all parts that are already in Prusa Orange, use the complementary color. For Prusa Orange (#EA5E19), this is a light azure blue (#15A1E6).
The Jerrai Gen2 Prusa Core one Kit (new feet and a drawer-system): https://www.printables.com/model/1340773-gen2-prusa-core-one-kit
Power Switch Adapter Core One: https://www.printables.com/model/1433400-power-switch-adapter-core-one - to get a better reach
Veröffentlicht : 31/03/2026 11:37 am
MoonshineXXX
(@moonshinexxx)
Mitglied
Looking forward to the outcome!
Veröffentlicht : 31/03/2026 11:39 am
LordSkippy
(@lordskippy)
Mitglied
Hack the firmware so that you can stream a webcam feed via ethernet of the printer.
Veröffentlicht : 31/03/2026 11:51 am
sandman667
(@sandman667)
Mitglied
This, so the fan grill doesn't break if you tighten the screw a little too much: Rear fan spacer
This, so you can remove the Z splitter board if you need to: Removable Z splitter holder
This, to close the top corner holes: Corner plug
This, to close the side panel top corners: Side Corner plug
This, so the door handle doesn't fall of on high-temp prints: Door fastener (specifically, the "PrusaCore1-Door-Handle-Grip" file)
Veröffentlicht : 31/03/2026 11:57 am
berlincount
(@berlincount)
IKEA Filter Backpack: https://www.printables.com/model/1244870-prusa-coreone-bagpack-ikea-airfilter-aka-one-fornu
Veröffentlicht : 31/03/2026 12:05 pm
berlincount
(@berlincount)
Filament weight scale spool holder: https://www.printables.com/model/1196950-filament-weight-scale-spool-holder-prusa-core-one
Veröffentlicht : 31/03/2026 12:06 pm
berlincount
(@berlincount)
BlazeCut Fire Supression: https://www.printables.com/model/1297239-core-one-fire-suppression-system-blazecut
Veröffentlicht : 31/03/2026 12:08 pm
_KaszpiR_
(@_kaszpir_)
Can we recommend items from Core One L?
Veröffentlicht : 31/03/2026 12:34 pm
LarryTheWombat
(@larrythewombat)
I would like to see this printer assembled blindfolded and inverted. 🙂 happy building!
Veröffentlicht : 31/03/2026 12:36 pm
Dave G.
(@dave-g)
How about a better angle on the Buddy3D camera so that you can see the entire layer being printed?
https://www.printables.com/model/1640555-buddy3d-camera-angle-mod-for-a-better-view
Veröffentlicht : 31/03/2026 12:42 pm
LarryTheWombat
(@larrythewombat)
Chamber Heater + Left side flat steel panel + chamber fan to promote consistent temperature.
Then run all the sealing projects and test with a smoke inside the core1 🙂
Veröffentlicht : 31/03/2026 1:05 pm
Seite 1 / 2
