Better anti vibration feet alternative?
perky890
(@perky890)
Every time i move the printer the stock anti vibration mounts come off. They seem to stick to the table more than to the printer, even with the sticky tape. Is there a better alternative?
Opublikowany : 17/09/2025 1:11 pm
RE: Better anti vibration feet alternative?
You can peel off the adhesive tape and glue them on which is what I did initially. Or you can print a replacement which is what I did. I use these: Prusa core One feet v2 - extra short - with TPU pad inserts
Opublikowany : 17/09/2025 2:26 pm
1 ludzie polubili
Posted by: @hyiger
+1. I used them on all my Core Ones. Work great
Opublikowany : 20/09/2025 3:06 am
vhubbard
(@vhubbard)
I had one of the original Core Ones and it came with 2 long rubber strips that glued the full length on each side.  These stayed stuck to the core one.  It appears they were changed later.
There are a few mods for Core One feet.
I wanted the drawers under the core one and converted to the squash ball feet.   I did a tall squash ball foot mod if you want to put drawers under the Core One also.  If you don't want drawers, stick with shorter ones.   The core one comes with just one hole per corner.  You may have to drill an extra hole at each corner to use 2 screws to attach each foot.   There are notes on that in the mod above.
Opublikowany : 20/09/2025 3:51 am
