Any recommendation for Core One spool holder?
zapta
(@zapta)
Printables.com has a few user designed spool holders for the Core One. Any recommendation for good one that provide value (better print quality, easy of changing filament, etc)?  For example, I saw this one https://www.printables.com/model/1311651-prusa-core-one-bearing-spool-holder that reduces the spool friction and I wonder if it provides any value over the stock spool holder.
Posted : 07/12/2025 5:27 pm
RE: Any recommendation for Core One spool holder?
Posted by: @zapta
In my personal experience, I've found the bearing based spool holders to cause more problems (for me) than they solve. A bit of friction and resistance is actually better for the stiffer filaments and I get less tangles without having to resort to a filament clip. I've since switched over to the Core One + bayonet style. But most of the time I'm printing from a dry box anyway.
Posted : 07/12/2025 5:41 pm
iftibashir
(@iftibashir)
Never bothered with that side spool holder TBH - I have my filaments in the cereal dryboxes and feed those via PTFE directly into the side of the printer. That way the filament stays dry with lots of desiccant and I don't have to worry about unloading after a print.
Posted : 07/12/2025 6:48 pm
zapta
(@zapta)
I have 4-5 ABS/ASA spools that I switch between so just having one in a dry box and the reset in open air will not help me much. Generally speaking, I ignore the humidity issue, and don't use much my filament dryer.
Posted : 07/12/2025 6:58 pm
