6.4.0 Firmware for Prusa CORE One + & CORE One
Page 1 / 3
Jan Kratochvíl
(@jan-kratochvil)
Member Admin
Summary
  • New features
    • Automatic chamber vent opening/closing (C1/+)
    • Belt tuning wizard (C1/+)
    • Faster and more responsive Prusa Connect experience
    • Nozzle cleaning failed wizard
    • Auto-retract (MK4 family, XL)
    • Auto-retract improvements (C1/+)
    • Auto-retract disable option (C1/+)
    • Selective factory reset
    • Chamber support for backwards G-Code compatibility (C1/+)
  • Changes and improvements
    • Improved print status messages
    • Lazier homing, more cautious calibration
    • Autoload improvements
    • Unified XL & CORE One chamber filtration
    • Option to continue after nozzle cleaning failure
    • Print sheet detection (MK4 family)
    • Respect maximum printed Z position
    • Gearbox alignment calibration (XL)
    • Filament change from Tune menu in any tool (XL)
    • Support cancelling more objects
    • Wi-Fi signal strength indicator
    • BSOD knob press behavior
    • Reworked filament sensor evaluation
    • Ukrainian language support for all printers
  • Fixes
    • All the fixes from the 6.3.X releases have been expanded to other printers.
    • Various fixes and stability improvements
This is the stable release of firmware 6.4.0 for the CORE One+, CORE One, MK4S, MK4, MK3.9S, MK3.9, MK3.5S, MK3.5, MINI, and XL. It reunifies the firmware development branch after the temporary split during the CORE One launch, where 6.3.x was released exclusively for CORE One and other printers remained on 6.2.x. – along with bringing new features, quality-of-life improvements, and fixes across all platforms.
The automatic chamber vent mechanism introduced with the CORE One L is now also available on the CORE One. After updating, the feature can be enabled via Settings → Hardware → Chamber Vent Control by selecting the Auto option.
Manual mode is also available, which keeps the vents closed by default and only shows an informational reminder before each print.
Vents can be controlled manually using the new M870 G-code ("M870 O" = open, "M870 C" = close), although we do not recommend including these commands in slicer profiles, as the printer handles vent control automatically.
The printed parts required to retrofit this feature on existing CORE One printers will be published on Printables in the coming days. A link will be added here once available.
A new guided wizard has been added to the Prusa CORE One to help users properly tension the X/Y belts. The printer uses controlled belt excitation combined with stroboscopic feedback to visualize belt resonance, making the tuning process more intuitive and reliable.
The wizard, accessible via Settings → Manual Belt Tuning, begins by prompting the user to check that the gantry is properly aligned, as misalignment can affect measurement accuracy. A quick manual alignment can be done by loosening both tensioner bolts, gently straightening the gantry by hand, and re-tightening the bolts evenly while keeping the gantry square. More information about gantry alignment can be found in this article.
The wizard then measures the vibration frequency of both belts and recommends whether to tighten or loosen them. The target frequencies are 96 Hz for the upper belt and 92 Hz for the lower belt.
Important: Always tighten both tensioner bolts evenly and alternately. This ensures that the gantry stays square during adjustment.
NOTE: A difference of up to 8 Hz between the belts is acceptable, as long as both values remain within the 90–98 Hz range. If values cannot be reached, the wizard will suggest manual squaring before continuing.
If your gantry is out of alignment, you may not be able to reach these exact values. In some cases, the lower belt can even show a slightly higher frequency than the upper belt.
Communication between the printer and Prusa Connect is now handled using WebSockets, replacing the previous polling-based method.
While this change does not affect raw data transfer speed, it significantly improves overall responsiveness and interaction with the cloud service. Users can expect (via Prusa Connect):
  • Lower latency when starting prints
  • Faster execution of remote commands
  • Smoother and more fluid control during cloud-based workflows
This update also lays the groundwork for future enhancements to remote monitoring and control by the user, allowing for continued improvements to the connected experience in future releases.
The recovery process for failed nozzle cleaning has been reworked into a new step-by-step wizard.
The wizard also includes a filament retraction step to prevent oozing before retrying the automatic cleaning sequence, increasing the chance of successful recovery.
The auto-retract feature is now enabled on MK4 and XL printers, after its first introduction on CORE One in firmware 6.3.X. Filament is automatically retracted from the nozzle at the end of each print, which helps reduce oozing during bed leveling and removes the need to preheat the nozzle when unloading.
NOTE: Auto-retraction is not applied to flexible filaments; to handle these, we have added a new “Is flexible” parameter, configurable in filament presets via the printer’s GUI or using the M865 G-code.
The auto-retract system has been improved across the board, with particularly noticeable benefits for multi-tool prints on the XL. It now respects slicer-issued retractions and avoids adding redundant movements.
On the MK4, the print head now parks at a higher Z-height after print completion to make it easier to remove any ooze left by the auto-retract ramming process.
Auto-retract can now be disabled globally in the Settings menu, although this is not recommended for standard use.
It is also possible to disable auto-retract per filament type. In the filament detail menu, the former "Flexible" option has been renamed to "Auto Retract", with its behavior adjusted accordingly.
We have introduced more granular control over the factory reset process. Instead of wiping all data at once, settings are now divided into categories, allowing you to decide what to reset and what to keep. These categories include:
  • Calibrations: All the calibrations data and selftest results
  • Common misconfigurations: Quirky settings that might cause unexpected behavior if you don’t know about them, for example disabling filament sensors, changing steps per mm
  • Network: Wi-Fi, Ethernet, Prusa Connect, PrusaLink related items
  • User interface: Items that affect user interaction with the printer – language, sound settings, footer settings, touchscreen, LEDs, and so on
  • Stats: Print & error statistics
  • HW configuration: Items that are linked to the hardware installed on the printer: nozzle diameters, extruder type, (also) steps per mm, printer type,...
  • Printer functions: Configuration of various print functions, such as MMU, chamber filtration, HW checks,...
  • User profiles: Custom filaments, print sheets (MINI and MK3.5)
To simplify the process, we have also prepared several reset presets for the most common scenarios:
  • Ownership transfer: Useful when you’re giving the printer to someone else. Will reset all your personal settings such like network and filament profiles, but keep things like hardware configuration, calibrations and statistics.
  • Fix common misconfigurations: This is what the support team will likely advise you to do during troubleshooting. Intended to fix things like filament sensor not working because it was accidentally turned off from the menu.
  • Keep HW config: Keeps only the hardware configuration (what nozzles, fans, extruders the printer has), nothing else. This reset is performed before shipping assembled units to the customers.
  • Full reset: Wipes everything, except for the firmware itself
  • Hard reset: Wipes everything, including the firmware. A USB drive with a new firmware will be needed.
If none of the presets fits your needs, you can start with the closest one and then manually adjust each category to reset or keep it according to your preference.
When printing on the CORE One in compatibility mode using files sliced for the MK4 or other supported printers, the firmware now automatically handles chamber temperature control. Since these G-code files do not contain the required commands for chamber heating or cooling, the printer applies chamber management heuristically. Previously, no chamber control was performed in this mode.
Status messages have been revised to provide clearer feedback during printer operations. They now give more detail about what is happening, show progress where applicable, and remain visible until the operation is completed instead of disappearing after just a few seconds.
NOTE: They also do not disappear when the print is paused, which addresses the issue #3143
Homing behavior on the XL and CORE One has been refined to avoid unnecessary movements. In cases such as filament load or unload, the printer now performs only basic homing, skipping the extra diagonal movements. If a precise position is required later, only the refinement step is executed. For unload operations with auto-retraction, homing is still performed to ensure the correct filament removal angle.
This change applies only to specific situations—G-code G28 without parameters, which is placed at the start of every print, will still trigger a full homing sequence. We are also considering updating slicer profiles in the future to allow optional homing.
In addition, the long and noisy precise homing calibration is no longer run automatically. Instead, the printer now checks reliability and suggests the calibration only when needed, and you can always choose to skip it. If required, the precise homing calibration can be started manually at any time from the Calibrations menu.
The autoload process has been refined to make filament changes faster and easier. Printers now begin preheating the nozzle to 170 °C as soon as the load procedure starts, without waiting for the user to confirm the filament type. On printers equipped with a side filament sensor (CORE One, XL), the procedure also starts automatically when filament is inserted into the sensor. In this case, the toolhead moves to an optimal position for feeding filament through the PTFE tube, and the extruder begins spinning to assist insertion.
NOTE: On the XL, the relevant tool still needs to be selected before autoload is triggered.
Additionally, the printer now checks whether the extruder filament sensor is already active when filament is inserted into the side sensor, warning the user in case debris or leftover filament is present in the printhead.
We have unified the code for chamber filtration between the XL and CORE One, so both printers now share the same features. As a result, the CORE One gains all functionality previously available on the XL, and vice versa.
In addition, several new options have been introduced. You can enable Filter all materials to keep filtration running regardless of filament type, and the Filter usage counter can now be adjusted manually for your own convenience.
We have also added two new G-codes: M147 (set) and M148 (unset), which let you explicitly mark whether a print requires filtration or not, overriding the automatic behavior based on filament parameters. (#4480)
If nozzle cleaning fails, the printer now offers an Ignore option, allowing you to continue with the print instead of being forced to abort the job.
The print sheet detection feature, originally introduced with the CORE One, is now available on MK4 printers. Before starting a print, the printer checks whether a sheet is installed and notifies the user if it is missing.
The firmware now tracks the highest extruding Z position reached during a print and ensures that toolchanges, filament changes, and parking moves are performed above this level. This prevents the toolhead from colliding with already finished parts during sequential printing (complete individual objects).
Gearbox alignment procedure is now available for the XL. We recommend running the procedure in the case that you needed to disassemble and reassemble the extruder.
You can now change filament in any tool from the Tune menu, not just the currently picked one.
Formerly, our printers were only able to control cancelling of the first 64 objects in the print file. This limit has now been increased to 1024.
NOTE: In the printer UI, you will still only see the names of the first 16 objects. The rest will be displayed as “Object X”.
The Wi-Fi icon in the header now displays signal strength, with individual bars lighting up according to the connection quality.
Pressing the knob during a BSOD no longer restarts the printer - it now only silences the beeper. To restart the printer, use the dedicated Restart button.
The evaluation method for the Nextruder filament sensor has been redesigned. This update improves reliability by reducing false runout detections and ensuring that actual runouts are correctly recognized.
Ukrainian language support, first introduced on the CORE One in firmware 6.3.3, is now available across all printers.
Release notes
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.4.0
Posted : 25/11/2025 6:35 pm
4 people liked
Samael
(@samael)
RE: 6.4.0 Firmware for Prusa CORE One + & CORE One
Seems like the best upgrade for the Core One so far, testing it asap!
Also the C1 to C1+ upgraded parts for the Auto Vent functionality are already uploaded, link below since it still is not in the above patch notes.
https://www.printables.com/model/1486513-prusa-core-one-to-core-one-upgrade-community-versi
Posted : 26/11/2025 1:56 pm
Neal
 Neal
(@neal-2)
The release notes do not indicate if any tasks need to be performed after installing this firmware.
For example, are there any settings or calibrations that need to be performed after I update the firmware?
Or is it simply: Update and use it?
Thanks,
Neal
Posted : 26/11/2025 4:52 pm
Posted by: @neal-2
After updating, run the new belt tuning wizard. It's not mandatory but it's always good to check belt tension. Like checking the air pressure in your car tires.
Posted : 26/11/2025 4:55 pm
TyFo
 TyFo
(@tyfo)
The downloaded zip file contains CoreOne firmware and MMU3 as well. Should I flash it via the USB cable or does the printer handle this upgrade internally via the MMU3 cable?
Posted : 26/11/2025 5:47 pm
I have always used a Micro USB Cable to flash the MMU3
Make sure the controller USB Cable is removed before trying to flash the MMU3
Joan
Posted : 26/11/2025 6:47 pm
chmax
(@chmax)
I did upgrade to 6.4.0 and, although the prints sofar behave like with the RC versions, I had my first bootloader "no info can be displayed" crash upon startup.
It seems that this problem hasn't been fixed yet.
Posted : 27/11/2025 1:43 pm
Posted by: @chmax
The only change between RC2 and the final version is some crash recovery changes. I've have about one bootloader BSOD per week but have been ignoring it.
Posted : 27/11/2025 4:25 pm
chmax
(@chmax)
Posted by: @hyiger
Posted by: @chmax
Interesting, before moving to the RC for a few days and then the final version, I stayed a really long time on the alpha release and never had it.
Posted : 27/11/2025 4:37 pm
Posted by: @chmax
I didn't have it either until I mentioned to someone here: "I've never seen it on my printer" then I after I typed that I turn my printer on and get the BSOD 🤣
It seems to be benign (so far) and I only get it occasionally. I just reset and move on.
Posted : 27/11/2025 4:47 pm
Mchad65
(@mchad65)
I picked up a new Core One about 10 days ago, which initially performed flawlessly. Until I flashed the update. For about three days after, I got about 4 “no info” BSOD’s on power up. Hasn’t happened in a couple of days, but I also haven’t used it as much (I’m a casual user…)
Should I be concerned with that many errors? I like the features it brought, but considered rolling back if it continues.
Posted : 30/11/2025 10:39 pm
Posted by: @mchad65
This was reported a couple of months back. It is (I believe) an issue with the boot loader. It's safe to ignore it and continue.
Posted : 01/12/2025 2:59 pm
Mchad65
(@mchad65)
Posted by: @hyiger
Posted by: @mchad65
Great, thanks. New to this printer and forum so I don't have experience with the history. I'll try and search better next time.
Posted : 01/12/2025 3:40 pm
Kachidoki
(@kachidoki)
An issue with the bootloader is far from safe. If the bootloader fails, the printer becomes bricked unless you reflash it via JTAG, which requires breaking the security tab on the motherboard.
Posted : 01/12/2025 4:18 pm
chmax
(@chmax)
In principle you are right  but this issue is a bootloader regression introduced with the new version that happens to a lot of people once in a while and can be fixed by pressing reset. There are no permanent faults created by this bug recorded so as @Hyiger was saying, it is indeed safe to proceed. Annoying? Yes! Dangerous no.
Posted by: @kachidoki
Posted : 01/12/2025 4:26 pm
zapta
(@zapta)
What is the status with 6.4.0, should I upgrade now or wait for 6.4.1 with fixes?
My Core 1 is now stable and I want to avoid regressions.
Posted : 05/12/2025 6:04 pm
Posted by: @zapta
I have been running 6.4.0 since the first beta in early September. I think it is stable enough to use. The homing, nozzle cleaning fixes and the new belt tuning wizard are definitely an improvement.
Posted : 05/12/2025 6:20 pm
pjr3d
(@pjr3d-2)
RE: 6.4.0 Firmware does not accept chamber temperature above 55c
I have recently loaded 6.4.0  firmware and there seems to be a hard coded limit of 55c for the chamber temp.
M141 cannot set a chamber temp of (say) 60c and there seems no way in the UI for this to be done - it will not scroll over 55c.
This seems to be a new "feature" in 6.4.0 since I could reliably reach 65-67c in previous firmwares with a bit of judicious insulation (towel over the top).
I think that this is an unintended side effect - it should be quite safe for chamber temp to reach 65c or maybe even 70c. Meanwhile does anyone have a way to disable the chamber fans temporarily so I can reach higher chamber temps for ABS/ASA/PC etc
Thanks.
Posted : 05/12/2025 6:52 pm
Posted by: @pjr3d-2
Thanks.
The problem is the door can possibly warp at higher temperatures and the Love board electronics may have some issues. So it's probably not safe to go above 60.
That said I can have the chamber reach 58-60C by setting the bed to 120C and turning off the filtration unit.
Posted : 05/12/2025 11:57 pm
pjr3d
(@pjr3d-2)
After some more experimentation, it seems that setting the chamber fans to 0% disables the chamber temperature control which should allow it to be manipulated above 55c manually.
I still feel that the 55c limit is too low and needs revising up to (say) 65c to cater for the high temp hotend and use of higher end filaments in the Core One. Hopefully the devs will reconsider.
Posted : 06/12/2025 3:40 pm
Page 1 / 3
