Z axis trouble but only when printing
Stránka 5 / 6
nateysmith
(@nateysmith)
RE: Z axis trouble but only when printing
Posted by: @james-jestings
Not sure if anyone else has posted this but outside of adding the gcode I have had some luck with lowering the idle temperature down to around 120c in the filament settings. After reading through how as others have said the issue seems to be related to the heating being on and interfering with the load cell, turning down the idle temp seems to have reduced the noise enough to get some good readings. Ambient is 80F where I am so you might need to lower it further based on chamber temp.
How did you do this? Do I have to create a new filament type for PLA for that to work, or do I do that in PrusaSlicer?
Napsal : 24/09/2025 12:22 am
David H. Brown
(@david-h-brown)
Just as a point of information, the wire twisting unfortunately did not work for me. Not that it isn't a good idea. As Prusa have said, there seem to be several possible causes and so there will be different fixes (or so I continue to hope). The wires are red and black on my old cable... the new cable is mostly black with a few white wires.
Core ONE main cable with nozzle heater wires twisted
Maybe I should have put more twists into it (and I could have spaced them more evenly) but I didn't want to shorten those wires too much relative to the others. Back to the modified starting G-code for now... cable swap later (still in the box in the background).
https://www.printables.com/@DavidHBrown_24313https://www.thingiverse.com/davidhbrown/designs
Napsal : 25/09/2025 1:25 am
tdcsf
(@tdcsf)
Out of curiosity did you twist 1/2 and 3/4 or 1/3 and 2/4.  The former won’t help as 3 and 4 are ground.
Napsal : 25/09/2025 2:12 am
Charles Webb
(@charles-webb)
@David H. Brown: It is a little hard to tell from your photo, but it looks like the twisting isn't right. In the photo I see two red wires twisted together and two black wires twisted together, and it looks like the reds are both HEATER_24V and the blacks are both HEATER_GND. If I'm right about the signals in your picture, that twisting won't help reduce crosstalk.
You actually want to twist together one HEATER_24V wire (red?) together with one HEATER_GND wire (black?), and then do the same with the other red/black pair for these signals. That way the current flowing in the two wires in a twisted pair will always go in opposite directions. This is what minimizes the crosstalk. After making the two red/black twisted pairs, I'd also twist them together loosely, in case one of the HEATER_24V wires carries a little more current than the other.
Based on the Love board schematics, the extruder harnesss connector is J13. On this connector, HEATER_GND is on pins 16 and 18 and HEATER_24V is on pins 20 and 22. It is J5 of the xBuddy board on page 11. Here's a screenshot:
Love board schematic is at:
      https://www.prusa3d.com/downloads/Electronics_drawings/FDM-MK4-LoveBoard-38.pdf
xBuddy schematic, page 11, top right (A5 coords) has the connector for the extruder harness.
    https://www.prusa3d.com/downloads/Electronics_drawings/FDM-xBUDDY-44.pdf
This post was modified před 7 months 3 times by Charles Webb
Napsal : 25/09/2025 3:14 am
1 lidem se líbí
emmanuel.r5
(@emmanuel-r5-2)
Hello,
Do you think firmware 6.4.0RC fixes this issue? I can't find any mention of support for this specific issue.
Napsal : 28/09/2025 3:43 pm
emmanuel.r5
(@emmanuel-r5-2)
I solved this problem.
After chatting with Prusa, I received a new heatsink to try out. I didn't have high hopes, and sure enough, it didn't solve my Z-axis trouble.
So I decided to go further, even if it meant taking risks.
I removed the main cable from the printer and inspected it from end to end. I didn't see anything unusual.
I then proceeded to unpin pins 1, 2, 3, and 4. using a needle as indicated by Charles Webb (thanks to you !)
Then I insulated these four cables properly. I noticed that cable 2 was running somewhat randomly along the cable, and was even passing through the twisted white and black pairs...
Then I twisted pairs 1 and 3, then 2 and 4, then twisted 1-3 and 2-4.I put everything back together and... ta-da! The printer now works like a charm. I no longer need a specific startup gcode.
I don't know if cable 2, which was running anywhere, was enough to cause the problem, but I have a feeling that it was.
Below are some photos.
Napsal : 03/10/2025 3:19 pm
1 lidem se líbí
David H. Brown
(@david-h-brown)
@charles-web and @tdcsf I expect that I did do the twisting improperly as it was my (mistaken) intent to twist the power wires together and ground wires together. Thank you for pointing that out.
Unfortunately, the forums seem to have stopped sending me notifications of posts in threads I'm participating in, so I didn't notice your replies before I finally found some time to replace the cable over the past two or three days. The replacement is about 1.5cm longer than my kit cable, no colors (just black and white) and seems to have somewhat more fabric wrap. No twisting on the nozzle heater wires.
It seems to be working at least in the first two prints with one full-bed print and one smaller print having done easy homing, nozzle cleaning, and bed probing on one touch per point.
Of course in replacing the main cable, I've also completely redone its routing with the swing arm and tubing, plus I also broke the clip that holds it to the right-hand X/Y motor bracket (I reprinted in TPU). Both of those (routing, clip) have also been identified as possible issues that can cause this problem, so it's not guaranteed that replacing the cable is what helped, but it seems probable.
If it starts causing trouble again, I will certainly try twisting this cable correctly; @emmanuel-r5-2, your thorough photos will be a good help. (I had also tried the 6.4.0 RC firmware and it didn't help. Isn't hurting either, so I haven't reverted.)
Thanks all!
Napsal : 03/10/2025 10:20 pm
lte
 lte
(@lte)
I have some Z axis problem too. i have try many of the solution mention in the original post up here.
(Adjusted X/Y belt tension that was uneven. This reduced X/Y banging during homing, but didn't do anything for the Z axis predictably.Checked for Y axis gaps - there were none.Tightened the lead screw and Z stepper bolts a bit, though they seemed to be OK. I enabled the Stealth mode (firmware issue?). After the print is done I'll try to disable it and see if failure rate changes.I installed anti-vibration pads. )
but my print continue to have the same problem one print out of 2. the Z axis seem to skip one layer or lift to much a time, this cause a line in the print and the print is easyly splitting appart. (see the picture)
Does someone have more new ?
Posted by: @ghostrider13
New Prusa Core One. Replaced stock nozzle with Nextruder Diamondback Passed all initial checkouts and calibrations.
Was able to print a few parts and the quality was quite good.
Then gradually Z axis homing and nozzle cleaning became more and more challenging. With problems significantly more frequent when homing before print. The printer still passes all axis and load cell tests. Most of the time it homes successfully when commanded from the main menu. However when I try to start a print, the printer either moves the table up and down without touching the nozzle most of the time (sometimes moving the table progressively lower) or even if it eventually homes after several retries, claims to fail the nozzle cleaning (even thought the nozzle has been manually wiped clean).
In the lower 15% of Z axis during movement there is loud scraping sound. Most likely it is heatbed cable but hard to confirm since it's hard to get reach there when the bed is low.
Also when bed probing is done ~20% of points are probed multiple times with small X/Y shift between attempts. I don't recall seeing this behavior on MK4 or XL. Older models seem to occasionally double tap a point but without X/Y shift.
Spent a lot of time with Prusa support:
  • Adjusted X/Y belt tension that was uneven. This reduced X/Y banging during homing, but didn't do anything for the Z axis predictably.
  • Checked for Y axis gaps - there were none.
  • Tightened the lead screw and Z stepper bolts a bit, though they seemed to be OK.
Later, without talking to support, lubricated all 3 z-rods. Didn't help.
At this point support is consulting the product team.
As I was typing this post, the printer finally homed after many retries and is printing just fine.
Seems that something is wrong with either the load cell or Z-axis. What else can I check?
A few other wild theories on what could have made the problem worse:
  • I enabled the Stealth mode (firmware issue?). After the print is done I'll try to disable it and see if failure rate changes.
  • I installed anti-vibration pads. Initially I was printing without them. But less vibration is usually good, right?
  • One of the early prints ended up in spaghetti. It could be that filament fragment made it's way into the print head and is messing with the load cell (perhaps only when the head is hot?). Possibly a fragment is somehow jamming one of the lead screws, but it is unclear why it would behave differently when homing from menu or when running a print. Also I don't see any visible debris there and the filament in question is red, so should be very visible.
What else can I try as I'm waiting for a response from support?
It seems that majority of the users are not having this sort of problem with Z-homing or any problems at all.
Napsal : 14/10/2025 12:47 pm
Ckobar
(@ckobar)
If it`s a kit...
 the standard question would be : did you check the x/y motor pulleys  correct orientation ?
Napsal : 15/10/2025 11:09 am
ghostrider13
(@ghostrider13)
Well, today my saga has finally concluded. I've been printing for almost 1 year with G-code patches in slicer profile to disable heating before homing and probing and that has worked fine.
Today I finally got around to replacing the cable harness (when doing other upgrades to the printer) and that has fixed the problem. Printer now homes and probes without any issues while the heater is on.
Napsal : 12/01/2026 2:35 am
1 lidem se líbí
I'm curious if new kits (or assembled) units now come with cables that have twisted pairs.
Napsal : 12/01/2026 3:33 am
Paul
 Paul
(@paul-20)
Did they send the cables under warranty? Support don't seem keen to do that for me...
Napsal : 12/01/2026 10:42 am
aclii
(@aclii)
Does the cable look any different to the one you previously had?
Napsal : 12/01/2026 10:56 am
ghostrider13
(@ghostrider13)
Yeah, it did look a bit different from the original one - slightly different sleeve length, different wire colors. I threw away the old one once I confirmed printer working so don't have the details.
I could have gotten one under warranty but decided not to bother - just added one to the shopping cart when I was buying another batch of filament. Prusa already sent me new load cell when trying to fix this issue initially and it didn't fix the problem back then.
Napsal : 22/01/2026 9:30 pm
Dennis
(@dennis-4)
For me also, hooray!
Even with the g-code patches I would get some "Unable to home the printer", "Repeated collision has been detected..." error messages.
What a difference a $34 cable makes. Not a single glitch in over a week of occasional printing. I was so frustrated and disappointed in attempting to get help chatting with support, I decided to spend the money and order the cable. I was able to toss in a couple spools of Prusament and accessories without raising the shipping cost.
For me, the cables looked identical except for , as @ghostrider13 mentioned, 3-4" longer sleeve.
Dennis
This post was modified před 2 months 2 times by Dennis
Napsal : 18/02/2026 9:46 pm
Posted by: @dennis-4
Congratulations on your fixed printer! But it's very disappointing to read that support did not volunteer to provide a free replacement cable. You spent a lot of time troubleshooting this, and even more installing the replacement cable -- all to correct an error Prusa is responsible for. They should have given you not only the cable, but the entire shipment of filament etc. for free...
I am mentioning @same-old-shane to see whether we can make him aware. Shane has just re-joined as the forum administrator and re-introduced himself in the General thread. Shane -- this is an example of what we talked about in the General discussion: A recurring design issue that was diagnosed here on the forum, and which Prusa support is either genuinely unaware of, or unwilling to accept as a cause for providing free replacement parts.
Napsal : 18/02/2026 9:57 pm
2 lidem se líbí
Paul
 Paul
(@paul-20)
Hi all. I took the plunge and bought a new main cable:
https://www.prusa3d.com/product/main-cable-1300mm/
To my surprise it has in fact worked - no more modified gcode.
Fitting is not as bad as feared - buddy board side and rear cover off and then fiddling cable ties
New cable may be shorter
Napsal : 28/02/2026 1:04 pm
1 lidem se líbí
mnentwig
(@mnentwig)
One low-tech cause for "nozzle clean" failure, "bed probing" issues and anything loadcell-related is simple mechanical tension on the cables that go to the hotend. Any mechanical force on those cables is seen by the loadcell. Add some friction (=hysteresis) and the readings are thrown off.
The intended cable routing never worked on my printer. I leave them in the open, passing underneath the lower thumb screw without touching.
Napsal : 28/02/2026 1:09 pm
gb160
(@gb160)
Crazy that people are buying this cable themselves to solve the issue. This is 100% on Prusa to resolve.
I contacted support, described the problem with a quick video, linked to this thread and they're sending me out a replacement cable. Entire process took less than 5 minutes, 2 of which were waiting in the queue for chat.
I honestly believe a lot of the frustration all pivots on who you speak with at support, I've had one or 2 interactions that can be described as frustrating, but the vast majority of my experience with Prusa support has been highly positive.
Napsal : 05/03/2026 11:41 am
1 lidem se líbí
Dennis
(@dennis-4)
Posted by: @gb160
... with a quick video...
Video of what? Can you post a link to it for an example.
I couldn't come up with a video that would meet the 10 MB chat limit.
Dennis
Napsal : 05/03/2026 4:54 pm
Stránka 5 / 6
