Z axis trouble but only when printing
Page 4 / 5
J-L MONIEZ
(@j-l-moniez)
Membre
RE: Z axis trouble but only when printing
I solve myself this problem.The Z guide on the printing plate which is in the rear (two in front, one back)was not mounted in the right position (inverted, upside down).Best regards,
Publié : 23/07/2025 12:42 pm
Charles Webb
(@charles-webb)
@Abel (and others): From my perspective, it appears that the root cause is an electrical noise/interference problem, whereby the activity of the relatively high power PWM of the nozzle heater interferes with the relatively weak analog signal from the load cell. It also appears that this noise/interference contributes to difficulty in X/Y homing (the "corner humping" problem where the print head repeatedly bangs against the front right corner of the chassis). Some CORE One units (like mine) are much more prone to this issue. I read  that the firmware has been modified to filter the noisy signal, in an attempt to mitigate the problem - unfortunately that doesn't fix the issue for my CORE One. I also read here that Prusa support has sent a modified cable to at least one user with positive outcome.
Since I found the G-Code hack that disables the nozzle heater while the Nextruder is homing & cleaning the nozzle tip, I haven't had any difficulty getting my CORE One to print, and I haven't had the desire to investigate further. The post was by @david.b36 on May 17 and is found near the top of Page 2 of this thread in the English Forum. The two added lines are "M104 S0" and are marked by a comment that says "turn off temperature ADDED BY ME" (FORUM LINK: https://forum.prusa3d.com/forum/postid/750274/)
As a retired electrical engineer, I suspect the "true" fix for this problem is a hardware change, but I know that isn't economically feasible given the number of units in the field and the cost of such a modification. Furthermore, the G-Code hack is free and works well, at least for me. I am surprised, however, that this issue did not occur on previous printers with the Nextruder/loadcell/Love board, and therefore get fixed for CORE One. Perhaps there is a minor difference in how the Nextruder or Love board are connected/grounded to the gantry or xBuddy board, specifically in the CORE One, that exacerbates the issue? My desire to investigate further is low. It would be much easier to help out if the designs were fully open source (i.e. schematics/gerbers for the PCBs), but for understandable reasons Prusa now have to keep some aspects of their printer designs private.
Publié : 23/07/2025 3:52 pm
3dPrintCrafter
(@3dprintcrafter)
Membre
I realize this is an older thread but it describes the exact problem I am having with my new fully assembled Core 1 printer I just received.  It printed great for a couple days then I have not been able to get a print started.  I went through all the troubleshooting steps listed on their webpage and after following everything they said to check I still can not get passed the errors; Printer collision has been detected and Filament failed to load.   I finally decided to chat with tech support and went through all their checks including sending them pictures they had requested of various parts and they said everything look good. Support had me do a hard reset and re-flash the firmware and then calibrate the printer, still the same problem.  They are sending me a new heat sink and bundle cable to see if that will fix the problem.
Publié : 01/08/2025 4:11 pm
James Jestings
(@james-jestings)
Membre
Not sure if anyone else has posted this but outside of adding the gcode I have had some luck with lowering the idle temperature down to around 120c in the filament settings. After reading through how as others have said the issue seems to be related to the heating being on and interfering with the load cell, turning down the idle temp seems to have reduced the noise enough to get some good readings. Ambient is 80F where I am so you might need to lower it further based on chamber temp.
Publié : 04/08/2025 4:53 pm
David H. Brown
(@david-h-brown)
I spent 5h yesterday on various chats with Prusa Support as I'm also having this issue and had reached the end of the troubleshooting page for the load cell. One rep (Kaloyan) confirmed that my load cell looked fine (despite being covered in gray material instead of white) and had me try downgrading to firmware 6.3.0 (my kit came with at least 6.3.2) which required a hard reset, reconnecting to the network, and redoing all the calibrations which passed. Didn't help. Then their shift ended and tried to pass me on to someone else but the connection dropped. Eventually resumed with another tech (Daniel) who is sending a replacement heatsink/load-cell and a thermistor. (I thought he meant the nozzle thermistor, but maybe the heat sink? (The nozzle was still hot when he had me check with the multimeter so the thermistor resistance was very low, around 30kΩ and rising. But it later got up to 100Ω.) I am suspicious that I'll have to rebuild the Nextruder twice or three times to eventually replace the main cable and/or LoveBoard too.
Starting to feel like I'm getting too old and life is too short to spend this much time tinkering with what really ought to be a pretty mature tech these days. Probably not a coincidence, considering my recent search terms, I saw an ad that Bambu is having a flash sale Tuesday (? check their store page for the countdown) where the base X1C is only US$799. (That's the model that is most similar to the CORE One.) Getting tempting to take advantage of China's anticompetitive subsidies.
https://www.printables.com/@DavidHBrown_24313https://www.thingiverse.com/davidhbrown/designs
Publié : 24/08/2025 6:59 pm
3dPrintCrafter
(@3dprintcrafter)
Membre
After my conversation with tech support they sent me the Heatsink/ Loadcell and the main cable.   I replaced the Heatsink / Loadcell first and it did not fix the problem.  I then replaced the main cable they sent me and this did fix the problem.  It has been printing fine ever since.
Publié : 25/08/2025 7:02 pm
1 personnes ont aimé
Weets 3D Printing and Design
(@weets-3d-printing-and-design)
Membre
After replacing the cable it worked perfectly before I replaced it tho i could only get it to work with a modded gcode
Publié : 26/08/2025 3:26 pm
David H. Brown
(@david-h-brown)
I received a replacement heatsink (and thermistor) yesterday and replaced them today. No change... Z axis still misbehaving with the hot end on; still fine with it off. Probably a firmware update to briefly turn off the hot end heater while reading the loadcell would work. Will also try tweaking G-code.
Publié : 29/08/2025 2:48 am
Membre
You need to replace the cable. Mine looked perfect but was still the issue.
Publié : 29/08/2025 11:53 am
David H. Brown
(@david-h-brown)
Posted by: @weets-3d-printing-and-design
Yeah, I tried to suggest that to the Prusa Tech, but they weren't interested. Now with the end of the de minimis exemption and carriers refusing shipments to USA, I figure I should let things settle down lest I get charged US$80 tariff (minimum flat rate if the shipper/carrier doesn't do things right) for a $30 cable. Can't find it on printed solid or I'd just buy one myself.
On the plus side, I was able to tweak the starter g-code with some additions that wait for the nozzle to get up to temperature and then turn it off again just before any probing (and also turn it off for homing) -- that seems to be working for me. Just a couple improvements to confirm with that that the next time I need to print something and I'll try to remember to post it here.
Publié : 03/09/2025 2:34 am
Membre
Ya i had read this before i talked with support and once i mentioned this fourm post they said ok well send you one out and ya i could only get mine to work by modding the gcode but once i replaced the cable it worked perfectly
Publié : 03/09/2025 2:54 pm
aclii
(@aclii)
You could try to fix your main cable to minimise interference, I posted some instructions on this bug ticket https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/4596#issuecomment-3105190372 and it seems to help.
Publié : 04/09/2025 12:09 am
David H. Brown
(@david-h-brown)
Thank you @aclii for (re?) posting that link; I had found and read your ideas there previously... but despite having about 8 crimping tools and dozens of different extractor needle pins on hand, I am reluctant to try modifying the cable until I was able to obtain a replacement. Having reported the failure of replacing just the heatsink/loadcell/thermistor, Prusa tech is sending me a cable. They think I may have pinched it in the "Covering the LoveBoard" step 33 of section 6. I will try twisting some pairs before replacing it, though, to see what happens.
I also wanted to share the starter gcode I'm using. Each time there's an operation that requires homing/probing, I have it wait for the nozzle to get up to whatever the most recently requested temperature is and then turn the nozzle heater off. Look for comments with "loadcell" to see where I made changes.
The results with this code aren't perfect -- it just took 30 cleaning probes with a visually clean nozzle and plate (printing ASA with glue stick under the purge line where it cleans, too) -- but it's letting me print.
Publié : 04/09/2025 9:42 pm
aclii
(@aclii)
No problem ) The procedure is not that complicated, you just need to label and unclick 4 wires from one end, twist it and put them back ) Needle works pretty well to release the wires from the connector. Here is the example with the stepper motor connector and the final cable after modification.
Publié : 05/09/2025 12:37 am
tdcsf
(@tdcsf)
Prusa is sending me a new cable. I just finished my MK4S->Core One upgrade and had the same problem. We inspected the cable and it looked fine. Has anyone had a relapse since getting a new cable? Simply replacing it seems like it wouldn't by default be a full fix if it is indeed a grounding/interference issue.
Publié : 12/09/2025 1:20 am
Posted by: @tdcsf
It would if they twisted the heater wires as others have done to reduce interference on the load cell. In the upcoming firmware release there are changes that look and attempt to patch this in the firmware instead. I would guess so they don’t have to send out new cables to all the current C1 users.
Publié : 12/09/2025 12:43 pm
Charles Webb
(@charles-webb)
@tdcsf: Yes, disassembling the cable to twist the noisy nozzle-heater PWM power wires together can significantly help in two ways. First, the twisting reduces crosstalk. Each 180 degree twist will mostly cancel out coupling from another twist -- this is just like in ethernet cables. Second, just pulling those wires away from the bundle and reassembling could unintentionally provide a little more physical separation between the noisy PWM power wires and other more sensitive signals. I am hopeful that the combination of fixing the cable and the new firmware will mean I don't need the special G-code.
Publié : 12/09/2025 1:20 pm
tdcsf
(@tdcsf)
One of the things that they had me try over chat was a very easy way to reproduce the issue:
1 - Auto Home using the control menu
2 - Move the Z to the bottom
3 - Preheat using the preheat menu, wait for it to be heated
4 - Auto Home again, and it should fail.
Publié : 12/09/2025 8:04 pm
tdcsf
(@tdcsf)
I have a little more data on my experience. Just got the replacement cable, so prior to doing the replacement I slowly have been unwinding the old cable from the installation to see if I can find more details on the failure conditions.  I unwound the cable first from the buddy board inclosure and retried the test and it still failed. I then unclipped it from the cable cover zip ties in the back and it still failed. I then fed the cable back into the interior and removed the screw that held the cable to the back of the xy assembly ( https://help.prusa3d.com/guide/6-nextruder-assembly_872952#879651) and from the swing arm and now the printer is working as expected.  I have not disassembled the loveboard yet.
Publié : 18/09/2025 1:11 am
emmanuel.r5
(@emmanuel-r5-2)
Membre
Hello, I've done two mk4s-core one conversions, and I have this problem on one of them. I have this homing issue if the regulated heating of the nozzle exceeds 80°C. I tried reassembling the main cable twice, but nothing worked. It still doesn't work. I could try to move the problem by swapping components between the two machines, but I don't have time for that. The first layer isn't great because the MBL is done at a temperature ranging from 170°C to 65°C as it descends.
My question : Do you know when the firmware will be released?
Publié : 23/09/2025 4:49 am
Page 4 / 5
