					                		Y-axis calibration failure, new kit - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/</link>
                <lastBuildDate>Thu, 21 May 2026 01:28:02 +0000</lastBuildDate>
                        <title>RE: Y-axis calibration failure, new kit</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-765470</link>
                        <pubDate>Wed, 24 Sep 2025 17:57:10 +0000</pubDate>
                        <description><![CDATA[Also though in my case, I believe one of the belts is slipping in the harness which is why (maybe) I keep losing belt tension over time.]]></description>
                        <content:encoded><![CDATA[<p>Also though in my case, I believe one of the belts is slipping in the harness which is why (maybe) I keep losing belt tension over time. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>hyiger</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-765470</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-765462</link>
                        <pubDate>Wed, 24 Sep 2025 16:52:58 +0000</pubDate>
                        <description><![CDATA[correct, I did read the comment and did that; my core one works rather well... Posted by: @hyiger   Posted by: @chmax There are indeed a few comments in the building notes on how many &quot;teeth...]]></description>
                        <content:encoded><![CDATA[<p>correct, I did read the comment and did that; my core one works rather well...</p><blockquote data-userid="590790" data-postid="765461" data-mention="hyiger"><div class="wpforo-post-quote-author"><strong> Posted by: @hyiger </strong></div><p> </p><blockquote data-userid="103931" data-postid="765063" data-mention="chmax"><div class="wpforo-post-quote-author"><strong> Posted by: @chmax </strong></div><p>There are indeed a few comments in the building notes on how many "teeth" of the belts need to be inserted in the holder. It is probably worth leaving a comment in the appropriate building step along the lines of "if you insert too may teeth this may happen:..."</p></blockquote><p>Also, the number of exposed teeth for both belts need to be the same. If not (which was my case) I was having problems getting a proper belt tension which led to Y calibration failures. </p></blockquote><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>chmax</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-765462</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-765461</link>
                        <pubDate>Wed, 24 Sep 2025 16:47:34 +0000</pubDate>
                        <description><![CDATA[Posted by: @chmax There are indeed a few comments in the building notes on how many &quot;teeth&quot; of the belts need to be inserted in the holder. It is probably worth leaving a comment in the appr...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="103931" data-postid="765063" data-mention="chmax"><div class="wpforo-post-quote-author"><strong> Posted by: @chmax </strong></div><p>There are indeed a few comments in the building notes on how many "teeth" of the belts need to be inserted in the holder. It is probably worth leaving a comment in the appropriate building step along the lines of "if you insert too may teeth this may happen:..."</p></blockquote><p>Also, the number of exposed teeth for both belts need to be the same. If not (which was my case) I was having problems getting a proper belt tension which led to Y calibration failures. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-765461</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-765063</link>
                        <pubDate>Sat, 20 Sep 2025 07:36:02 +0000</pubDate>
                        <description><![CDATA[There are indeed a few comments in the building notes on how many &quot;teeth&quot; of the belts need to be inserted in the holder. It is probably worth leaving a comment in the appropriate building s...]]></description>
                        <content:encoded><![CDATA[<p>There are indeed a few comments in the building notes on how many "teeth" of the belts need to be inserted in the holder. It is probably worth leaving a comment in the appropriate building step along the lines of "if you insert too may teeth this may happen:..."</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-765063</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-765050</link>
                        <pubDate>Sat, 20 Sep 2025 02:36:58 +0000</pubDate>
                        <description><![CDATA[I think I figured it out. I just needed a fresh look.What I didn&#039;t understand is that the tensioner pulleys need to be retracted deep enough so that the gantry does not touch them.  The gant...]]></description>
                        <content:encoded><![CDATA[<p>I think I figured it out. I just needed a fresh look.</p><p>What I didn't understand is that the tensioner pulleys need to be retracted deep enough so that the gantry does not touch them.  The gantry needs to touch only the motor mounts. </p><p>But if the belts are already pretty tight, then you will not be able to loosen them enough to pass the belt tightness audio test.</p><p>So my real problem is that belts are inserted too much into the Nextruder holder (step 5.51).  Loosen them by 1 or 2 notches will allow me to retract the pulleys enough and still pass the tightness test.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>tabicat</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-765050</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-764982</link>
                        <pubDate>Fri, 19 Sep 2025 17:38:06 +0000</pubDate>
                        <description><![CDATA[Posted by: @chmax Did you check if the cable of the sensor behind the right handle is interfering with the gantry&#039;s movement?This happened to me. Turn the printer off (so the motors can free...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="103931" data-postid="764938" data-mention="chmax"><div class="wpforo-post-quote-author"><strong>Posted by: @chmax </strong></div><p>Did you check if the cable of the sensor behind the right handle is interfering with the gantry's movement?</p></blockquote><p>This happened to me. Turn the printer off (so the motors can free-spin) and slowly move the gantry along the same path it takes when it performs the Y-axis calibration (from the front-right corner to the back right-corner). Feel for any resistance at any point. Ensure the gantry isn't touching/squeezing/interacting with the sensor cable between the right handle and the back of the printer.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>AJ</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-764982</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-764946</link>
                        <pubDate>Fri, 19 Sep 2025 10:25:23 +0000</pubDate>
                        <description><![CDATA[For *any* problem with a new printer or a new kit-build it is always best to go to Prusa Support via the Chat option; you will need your printer&#039;s serial number.
Cheerio,]]></description>
                        <content:encoded><![CDATA[For *any* problem with a new printer or a new kit-build it is always best to go to Prusa Support via the Chat option; you will need your printer's serial number.
Cheerio,]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Diem</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-764946</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-764938</link>
                        <pubDate>Fri, 19 Sep 2025 08:09:25 +0000</pubDate>
                        <description><![CDATA[Did you check if the cable of the sensor behind the right handle is interfering with the gantry&#039;s movement?This is a case where I would contact support via chat... it may take a long time bu...]]></description>
                        <content:encoded><![CDATA[<p>Did you check if the cable of the sensor behind the right handle is interfering with the gantry's movement?</p><p>This is a case where I would contact support via chat... it may take a long time but they usually manage to fix this kind of things...</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-764938</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-764935</link>
                        <pubDate>Fri, 19 Sep 2025 05:39:26 +0000</pubDate>
                        <description><![CDATA[I&#039;ve noticed that the failure X appears immediately when the gantry hits the rear of the printer.  The Y-axis range is apparently -19mm to 210mm, so if there&#039;s an obstruction, I don&#039;t see it...]]></description>
                        <content:encoded><![CDATA[<p>I've noticed that the failure <span style="color: #ff0000">X</span> appears immediately when the gantry hits the rear of the printer.  The Y-axis range is apparently -19mm to 210mm, so if there's an obstruction, I don't see it.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-764935</guid>
                        <title>Y-axis calibration failure, new kit</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-764934</link>
                        <pubDate>Fri, 19 Sep 2025 04:29:05 +0000</pubDate>
                        <description><![CDATA[I just finished building my Core One kit, and the Y-calibration test failed. The belt tension is correct, and there is no gap on either side of gantry.  I can move the gantry backwards and f...]]></description>
                        <content:encoded><![CDATA[<p>I just finished building my Core One kit, and the Y-calibration test failed. The belt tension is correct, and there is no gap on either side of gantry.  I can move the gantry backwards and forwards, and both sides hit the ends at the same time.  Perfectly aligned.</p>
<p>And yet, the Y-calibration is failing.  I read in a lot of places that the T16-2GT geared pulleys might be inverted.  How can I tell if they are?</p>
<p>Here's the left (X-Axis) assembly:</p>
<p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/09/527fc971-left-scaled.jpg"><img class="alignnone size-medium wp-image-180408" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/09/527fc971-left-600x500.jpg" alt="" width="600" height="500" /></a></p>
<p>And here's the right (Y-axis) assembly:</p>
<p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/09/31cbcc75-right-scaled.jpg"><img class="alignnone size-medium wp-image-180409" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/09/31cbcc75-right-600x500.jpg" alt="" width="600" height="500" /></a></p>
<p>Does this look right?  Also, could someone post a video of what a successful Y-axis calibration looks like?  I can only find videos of failures on Youtube.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/y-axis-calibration-failure-new-kit/#post-764934</guid>
