What is happening here?
Seite 1 / 3
TheRandy
(@therandy)
Brand new Prusa Core One (Factory assembled) and Ive had one successful print off of it.  I have attempted to print this part now 6 times.  Different Prusa slicer settings (with supports, without supports, 10mm, 15mm, 20mm, 25mm) All fail.  This is the tool box listed on Printables that goes into the side compartment of the Prusa Core One.  I've run a benchy and the crazy fast benchy from the thumb drive that comes with the printer with minimal issues, but they didn't look as good as I expected.  For a new machine with less than 5 hours print time on it, it's kind of disappointing.  I've reverted to my Mk3S+ for now printing some of the other parts of this build (WITH NO PROBLEMS), but some are too large and need to be printed on the Core One.
Just a note: The first layer prints beautifully, nice adhesion and smooth surface.  Then when the additional layers get added, it starts to sound like crap like it's dragging and then after a couple hours looks like the above.
I have recalibrated the printer as far as I can tell.  It went through the whole process where I had to touch the print head and all that, and reran the print to the same messy outcome.
Any help would be appreciated.
Best Answer by hyiger:
One last thought. I'm 100% convinced now that its a nozzle clog. When you are printing the PLA I assume you have the top vents opened? Try doing another cold pull and leave the door open when you print (you'll need to disable the door sensor in UI setup screen). Anyway, unclogging a HF nozzle is difficult at best.
Veröffentlicht : 21/10/2025 6:16 pm
TheRandy
(@therandy)
RE: What is happening here?
Here is the first layer of the same print above
Veröffentlicht : 21/10/2025 6:38 pm
Wet filament. Needs to go into a filament dryer. If you don't already own one I recommend you do.
Diese r Beitrag wurde geändert Vor 2 months von hyiger
Veröffentlicht : 21/10/2025 6:47 pm
BTW, what type of filament is this? Is it Nylon (PA)?
Veröffentlicht : 21/10/2025 6:56 pm
TheRandy
(@therandy)
Hi, I do own one for my MK3S+, but I don't think it would reliably work for the Core One.  This is Prusament PLA - Galaxy black (the roll that came with the Core One.
Veröffentlicht : 21/10/2025 7:06 pm
It won't matter. If it can maintain 50C for around 6hrs then that's enough.
Veröffentlicht : 22/10/2025 3:44 am
TheRandy
(@therandy)
Man!  There’s gotta be something else, are we sure it’s the PLA filament.  Here is a NEW roll, stayed in my dry box overnight (8+ hours) with a humidity of 44% (I live in Florida - it’s ALWAYS humid).  Also, all of my other prints on my MK3S+ lived in this same environment and had no issues printing.
Can it be anything else?
Veröffentlicht : 22/10/2025 1:16 pm
Artur5
(@artur5)
Could be a problem with this filament or/and something else. Please upload here a zipped file of your  *.3mf  project so we can see your print settings
Veröffentlicht : 22/10/2025 3:51 pm
TheRandy
(@therandy)
Here you go.  I got it off Printables.
https://www.printables.com/model/1199587-prusa-core-one-dry-box-mod
Veröffentlicht : 22/10/2025 4:52 pm
Posted by: @therandy
A dry box does not dry out filament. It just prevents it from collecting moisture as quickly as it would sitting out in the open air. Damp filament going into a dry box will still be damp when you take it out again. It needs to go into a dryer first. Especially if you live in a humid environment. As for brand new roll of filament, straight from the vacuum bag? I've had to dry it for 8hrs before it was usable. Here is an example. The test object on the left was printed immediately after removing a brand new roll of  TPU filament from the sealed vacuum bag and the on the right is the same object after drying the filament for 8hrs.
Veröffentlicht : 22/10/2025 10:35 pm
TheRandy
(@therandy)
Okay, purchased a dryer.  Had it dry PLA for 8+ hours at 50°C
ran the filament through a tube directly from dryer to Core One…same outcome!!!
Veröffentlicht : 24/10/2025 3:04 pm
Buying the filament dryer regardless was a good decision. You will most definitely need it.
As for the photos it doesn't look like the same outcome. The first photos (at the beginning of the thread) was clearly due to, in part, to damp filament. The last photo to me looks like a clogged nozzle. Sometimes this can happen if (for example) you set your Printer profile to a high flow nozzle but you don't have a high flow nozzle installed.
Also, it would help if you could zip your .3mf project file (exported from PrusaSlicer) and attach it here.
Diese r Beitrag wurde geändert Vor 2 months 2 mal von hyiger
Veröffentlicht : 24/10/2025 4:33 pm
TheRandy
(@therandy)
Here you go, they are attached.
As far as the nozzle, its the one that came with the printer...so I'm assuming the .4 HF.
Veröffentlicht : 24/10/2025 4:52 pm
I'm still thinking the nozzle is clogged. Can happen if you push damp filament through it. Do you have another nozzle you can test with? If not you should because those brass nozzles will eventually wear out. Try doing a cold pull.
BTW, in my opinion, that dry box is not worth the trouble. I added an extra gasket around the rim but was never able to get the RH to a decent level (staying within -10% of ambient RH. It was also a PITA to have to use the different adapters for different spools. I just find it much easier instead to print from an external dry box
Veröffentlicht : 24/10/2025 6:20 pm
One more thing, check the idler tension screws. Perhaps the filament is slipping in the extruder gears. Try tightening by 1/8 of a turn.
Veröffentlicht : 24/10/2025 7:30 pm
TheRandy
(@therandy)
Okay, I ran two cold pulls after upgrading the Core One's FW to 6.4.0-RC so the LCD could walk me through the cold pull's; that seemed to have done the trick.  I printed the sample "scraper" from the Prusa thumb-drive and it printed with no issues.  I'm no moving on to what I actually want to print.  Thanks all.
Veröffentlicht : 25/10/2025 1:58 pm
TheRandy
(@therandy)
Okay - it happened again right after I hit send on that last comment.  WTH is happening???
Video of what it's doing is below.
Too large to upload, here is the Dropbox link:
https://www.dropbox.com/scl/fi/wfjbxq7s4puvogzfpbq2p/IMG_0476.MOV?rlkey=nnjaxmw18jw7xg2wam814z2ic&st=z4tewawr&dl=0
Veröffentlicht : 25/10/2025 2:15 pm
TheRandy
(@therandy)
Cold Pull in action and results of the two tests (I dont see any debris on either end that made it through the nexttruder)
Veröffentlicht : 25/10/2025 2:17 pm
TheRandy
(@therandy)
Lastly, I tightened the idler tension screws first an 1/8’ish, and then another 1/8’ish.  Two separate prints…and both stopping at the same place!  This is an odd one.  You can see one on top of the other
Veröffentlicht : 25/10/2025 3:35 pm
This is definitely either caused by: a clogged nozzle, debris in the extruder or perhaps the nozzle is not fully inserted into the nextruder. Either way something is blocking the filament's path through the end of the nozzle.
First, double check the heat block assembly is correctly inserted fully into the nextruder. Next, open the idler and look for debris. Perhaps a bit of plastic is blocking the entrance to the heat break tube. It could just be you have a bad nozzle. It's always important to have a spare nozzle and heat block on hand.
Would advise getting a spare (non-HF) nozzle and start with that. For example: Nozzles 3D Printer MK4
Veröffentlicht : 25/10/2025 4:29 pm
Seite 1 / 3
