Uneven Layers Thickness - with stringing
Hi
,after i changed my nozzle to a non HF i printed the first object on the left-no problem.In the very moment, when i made the outer wall a bit thinner ,strange stringing an unevenly organized layers started to emerge, i tryed it mutliple times with different wall thickness or placement on the heatbed, but it never came the out correctly.
What setup could it be? if i tryed to reprint the correct cylinder file on the left, once again it came out smooth and correct
Veröffentlicht : 10/06/2025 12:34 pm
RE: Uneven Layers Thickness - with stringing
Please save your Prusa Slicer project with a clear name for us, then zip it and attach the zip-file to your next post.
Everything else is just inefficient guessing, but looking into your project will probably lead to a quick solution 🙂
Veröffentlicht : 10/06/2025 9:10 pm
