Random restart printer during print
ZelenaObora
(@zelenaobora)
Miembro
Hi all,
I have problem with my Prusa Core One. When I printing one simple project, my printer is restarted each aproximately 2 - 3 minutes during printing. After that sound from printer beeping 10 times and dislay is switch off.  Printer is restarting and continue with printing project.
Do you have any idea where is problem ?
Thanks
Respondido : 14/06/2025 8:55 pm
k1mu
 k1mu
(@k1mu)
RE: Random restart printer during print
Posted by: @zelenaobora
Hi all,
Thanks
Sounds like a power problem.
Are there any messages on the display before it restarts?
I'd start with checking the screws attaching the power cable to the power supply and electronics board.
Kit or assembled?
Respondido : 15/06/2025 4:53 pm
There are two threads on this, which just recently seem to have converged on a (surprising!) solution. The issue seems to be that on many Core One units, the XY stepper motors are not grounded. During long, fast moves, apparently the belt friction creates enough buildup of static electricity to cause a discharge which disturbs printer operation.
https://forum.prusa3d.com/forum/postid/753022/
https://forum.prusa3d.com/forum/postid/753762/
Grounding the motor chassis -- either via a separate ground strap (cable), or by just removing the paint below one of the screw heads which attach each motor to the CoreXY frame -- has solved this problem for several users. See the above threads for details and illustrations.
Respondido : 15/06/2025 6:12 pm
4 les gusta
SaintGeorge22
(@saintgeorge22)
Miembro
I had the same issue and fixed it by testing the power cable connections, turned out one wasn’t fully seated on the PSU side. Also swapped wall outlets to rule that out.
Respondido : 18/09/2025 11:38 am
Tim
 Tim
(@tim-21)
Miembro
The motors are intended to be grounded by the mounting screws. Prusa even added a grounding lug to accommodate a proper path from the frame to a good earth near the power supply. But paint gets in the way and insulates the screw heads from making a connection. Scrub away the paint from two accessible screws (one per motor), and problem solved. Here's how I fixed my printer: scrape away paint under the screw with an Exacto knife then as insurance added an internal star washer to cut through the paint. Only one per motor is required.
Respondido : 18/09/2025 4:40 pm
1 les gusta
TimeOut@Home
(@timeouthome)
Miembro
Removing a little paint underneath the most accessible screw on each motor completely solved the issue for me. I did not have to do any disassembly. It is a little awkward to reach the screws but not truly difficult.
Respondido : 01/05/2026 12:58 am
