Only one belt vibrating (twice in a row) during manual belt tuning
[Rozwiązany] Only one belt vibrating (twice in a row) during manual belt tuning
volcryn
(@volcryn)
I'm sure I did something wrong. but when trying to use the manual belt tuning test only one belt vibrates during both upper and lower testing. It'll be one or the other, I haven't yet figured out the reason for why upper or lower is the one reacting. I have done a lot of testing while tightening and loosening the tensioners and even had them pop out once, which was fun to fix. I did tighten the belts a fair amount early in the build, so I wonder if I did myself a disservice with that. Before I start disassembling, any ideas? It's a kit.
Opublikowany : 30/12/2025 1:54 am
RE: Only one belt vibrating (twice in a row) during manual belt tuning
Be sure to always tension the belts evenly. Start with completely relaxed belts, loosening the tensioners as much as you can. In that state check that the X gantry is straight, i.e. touches the front left and right end stops at the same time -- if it is not, bend the gantry L brackets to get there. Then gradually tighten the belts, always turning both tensioners by the same amount.
Once the belts are tight enough to produce audible tones when plucked (above 60 Hz), you can switch to the stroboscope-based Manual Belt Tuning wizard in firmware 6.4.0. You should find visible resonances for both belts, although they will not be at the exact same frequency, because the free belt length along the gantry is a bit different.
Detailed and illustrated version of the above procedure:
https://help.prusa3d.com/article/adjusting-belt-tension-core-one-l-core-one_845048
Opublikowany : 30/12/2025 1:33 pm
volcryn
(@volcryn)
Thank you. When the tensioners are completely loose should they stick out and interfere with the gantry alignment test?
Opublikowany : 30/12/2025 1:57 pm
mnentwig
(@mnentwig)
You could relax the belts and check whether the gantry is aligned without belt tension. If the metal is bent but perpendicular under tension (forced by the belts) there is be imbalanced force between the belt that shows in resonant frequencies being off. As Jürgen stated above, in a normal setup the different "tuning" comes simply from the different length of the visible belt segments but the force is exactly the same.
Opublikowany : 30/12/2025 2:20 pm
Posted by: @volcryn
If I recall correctly, they should not collide even in the fully loose position. The movable idler wheel may stick out of the stationary tensioner block a bit, but there is a matching recess in the idler block on the gantry.
Opublikowany : 30/12/2025 5:58 pm
volcryn
(@volcryn)
Thanks to everyone for the input. I misread a comment during the nextruder mount/belt clamp installation phase and tightened the belts  at the clamp instead of the tensioners. Not only that - one was much, much tighter than the other even without the tensioners.
It was not the only mistake I made during this build but it was certainly the most annoying to fix. The upside is I have a much better understanding of the belt system and the nextruder assembly.
Also, perhaps pushing to finish a build when very tired is not a great choice.
Opublikowany : 04/01/2026 1:23 am
1 ludzie polubili
Steve
(@steve-11)
Posted by: @volcryn
We've all been there 😆
I myself pushed to finish up a couple of nights back and finally went to bed with a failed Y axis mystery. Fresh eyes the following morning saw the slightly out of place filament sensor cable that was catching the bearing 🙄
Opublikowany : 04/01/2026 12:42 pm
2 ludzie polubili
Posted by: @steve-11
That one's a classic! I like to think that I was the first to get it wrong...
Opublikowany : 04/01/2026 12:51 pm
3 ludzie polubili
Mac-N4MCC
(@mac-n4mcc)
NO! I have that T-shirt! Make sure the pulleys are inside the holder or the gantry will not square up. After numerous nextruder assemblies, I began doing preliminary belt tension testing right after mounting the belt holder and before teh nextruder. Get your belts close with the pulleys just behind the leading edge of eeh pulley holder, then , count it all.
Extra HAM (and eggs some say) Radio - N4MCC
Opublikowany : 10/01/2026 11:15 pm
1 ludzie polubili
volcryn
(@volcryn)
Yes, agreed. If/when I build another core one I will be doing the same. Thanks for the info!
Opublikowany : 11/01/2026 7:29 pm
