Nozzle heiz nicht auf
Alois Braun
(@alois-braun)
Hallo,
habe einen Core One Bausatz fertig aufgebaut alles überprüft und dann die Kalibrierung gestartet, Türsensor ist ausgeschaltet. Alle Achsen laufen die Wegezelle funktioniert nur beim Probe aufheizen brichte er ab und geht auf Störung. Daraufhin alle Komponenten durchgecheckt alle Stecker überprüft, Heizung und Thermistor druchgemessen. Alles meines Erachtens ok. Nur heizen mag er nicht.
Hatte das schon wer? Gibt es abhilfe oder was kann ich noch prüfen?
Posted : 24/11/2025 11:29 am
Posted by: @alois-braun
Hello,
I've finished assembling a Core One kit, checked everything, and then started the calibration. The door sensor is switched off. All axes are moving, and the load cell is working, but during the test heating phase, it stops and goes into error mode. I then checked all the components and connectors, and measured the heater and thermistor. Everything seems okay to me. It just won't heat up.
Has anyone else experienced this? Is there a solution, or what else can I check?
Are you using a silicon sock? If so, make sure that it is turned on in the printhead setup. Not doing this will cause the heater test to fail. It’s under: Settings -> Hardware -> Printhead -> Nextruder Silicon Sock
If not, are you using a copper heat block and not the stock aluminum one? This can also cause the heater test to fail.
Also, since this is the English forum, please comment in English. You can use Google Translate (or whichever you prefer).
Posted : 24/11/2025 11:15 pm
Alois Braun
(@alois-braun)
RE: Nozzle heiz nicht auf
thank you for your reply, I'll check the settings.
Alois
Posted : 24/11/2025 11:43 pm
Alois Braun
(@alois-braun)
Hello, I just checked the settings, everything is as intended, silicone sock is activated, subsequent test failed.
Posted : 25/11/2025 7:38 am
chmax
(@chmax)
Since this is a new build and you checked all the obvious things, I would now contact prusa support.
Posted : 25/11/2025 9:57 am
Does it actually get hot (and the firmware is just not satisfied with the time course or sensor readings), or does it stay entirely cold?
As @chmax said, it's probably time to contact support. But if you have not done so yet, measuring the heater + cables as well as the NTC + cables might be worthwhile: Unplug from the xBuddy board and measure resistances directly on the cable's connector there.
Posted : 25/11/2025 10:57 am
