No Filament Extruded and Heat Bed Issues
Page 2 / 2
Butters
(@butters)
RE: No Filament Extruded and Heat Bed Issues
What do you or anyone if they should so wish to comment use to measure the belts, just internal firmware belt measure tool or something else as well. I know there is a tool for Android devices but that tool is not available for recent version of Android.
Posted by: @hyiger
Posted by: @butters
It was the spring screws on the idler a little too tight.
Right... Those are the same screws I was referring to in the photo. It's also why I wanted you to take a photo. It would have saved time.
Hopefully no more issues. Just make sure you check the belt tension from time to time.
Posted : 05/12/2025 3:01 pm
Posted by: @butters
Posted by: @hyiger
Posted by: @butters
Use the 6.4.0 Settings -> Manual Belt Tuning. There is no reason to use anything else unless your white LED strip is not working.
Posted : 05/12/2025 6:24 pm
Page 2 / 2
