Loud buzzing during movement
Seite 3 / 3
SgtCaffran
(@sgtcaffran)
RE: Loud buzzing during movement
Yeah it can but I'm not sure which plastics are affected. Didn't want to take any chances so I only applied thread locker for the metal on metal parts.
Veröffentlicht : 01/08/2025 7:26 am
Oleg
 Oleg
(@oleg-3)
I seem to have similar issue with rattling sounds/vibration at certain print-head travel speeds.
The sound is produced both when printing and when moving gantry by hand (motors are not engaged). Initially it was very bad and I followed the advice in this thread to unscrew the linear rail and re-tighten. That reduced the scale of the problem or maybe shifted the resonance frequency.
It is still bad. Here's the example video of it printing with 0.20 STRUCTURAL profile.
You can see that when it prints inner perimeter at higher speed the sound is very pronounced, but when it does outer perimeter with lower speed the sound is gone.
I only read about late tightening of Y rod clamps after mounting gantry so didn't try that. Did anyone had success doing it without stripping most of the outer case apart?
Another point is that if I completely loosen the belts vibration seem to go away. Going to raise it with support if I can't get any further.
Diese r Beitrag wurde geändert Vor 11 months von Oleg
Veröffentlicht : 01/08/2025 8:11 pm
hbear
(@hbear)
Mitglied
I am chasing a similar sound. Disconnecting the motors one by one and running gcode to replicate the problem, it seemed to only occur when the X-Axis motor was running. Support has sent me a new one, as well as two new sets of bearings. None of these have solved the issue.
I have now taken both Y-rods off and on quite a few times. Typically, I remove/replace with only the side panels and top removed (including the top of the metal frame). First loosen the 4 bearing screws. Then, I loosen just the front rod clamp (this is the trickiest part, as the bolt is blind and behind the Z rod), then remove the two screws holding the back side of the Y rod holder to the gantry, then while supporting the front of the rod, slide it backwards. I can then gently take the rear Y rod clamp, Y rod, and bearing away from the printer. I only had to drop it once and clobber my build sheet to figure this out.
I also have noticed that, sometimes, depending on how I assembled things, the resonance moves around. The resonance is not even my main issue, but the rattle/buzz it causes. I've worked with support, and now even prodded around with a mechanics stethoscope, to no avail. I went as far as running my gcode to replicate the issue with the left Y rod in place, but the bearing removed, holding the left gantry up by hand, and the noise was completely abated. With the stethoscope, the noise does seem loudest around the left side for me, and I can also eliminate it by pushing up on the left bearing while it runs, but clearly having tried 4 different bearings, it's not the bearing itself but something else causing it.
Diese r Beitrag wurde geändert Vor 11 months 3 mal von hbear
Veröffentlicht : 04/08/2025 11:11 pm
Oleg
 Oleg
(@oleg-3)
I did some investigation on my side and made a repro to demonstrate with different movements.
For me it happens on 1 axis move (x louder than y) at speed of 80mm/s and 2 axis diagonal move at 57mm/s. Diagonal move causes 1 belt to move at the same speed as both when doing 1 axis so it adds up.
At that speed I get 253Hz frequency (measured by phone).
When moving gantry/head by hand on printer that's turned off I can feel roughly 6 steps/"clicks" per 1 belt tooth movement. Belt has 2mm tooth pitch so we have 3 clicks per mm. 80×3 gives us 240 which is close to 253hz resonance speed.
I suspect this is resonance happening in the structure that makes such vibrations. Nothing to do with actual motors, pulleys, idlers.
I also tried measuring freq when changing belt tension and it seem unaffected.
Raised it with support and yet to hear back from them.
Veröffentlicht : 05/08/2025 8:57 am
I would suggest buying the accelerometer and running the pulse stepper calibration. Made my printer a lot quieter.
Veröffentlicht : 06/08/2025 1:36 am
Oleg
 Oleg
(@oleg-3)
I got a bit disappointed by support largely citing me the assembly manual, asking to make a video of how belts are tensioned and all the useless dance around without any progress on solving the issue. Plus each question round-trip is a least two days.
So I got the accelerometer from the local distributor and run phase calibration and input shaper calibration and observed 0 improvements. Shaper freqs were way off from the factory setting. The fact that there's a resonance at speed that is used by default structural profile doesn't help. If it was 20hz above it might have gone unnoticed because printer would mostly pass through that speed during acceleration or braking phase. Still even when it passes, there's this buzzing sound which is noticeable.
At this point I feel like the situation is worse than with Ender3 where manufacturer provides 0 support, but community knowledge is vast and you can always fix any problem.
/rant
Veröffentlicht : 09/08/2025 3:35 pm
Seite 3 / 3
