Layer shift? What causes this?
Obioban
(@obioban)
Membre
Since I finished building my CORE One, it seems to have layer shift issues on large or high infill prints. What could be causing this?
Example (70% gyroid infill).
Belt tensions are good, per the tuner.
You can see it had a couple small layer shifts, then the BIG one. Also, the layer before the big one, looks like it was printing on a curve...? Part was just a cube, all the previously layers were vertical/horizontal lines.
Help! Please and thank you.
Publié : 23/10/2025 12:08 pm
RE: Layer shift? What causes this?
Is your gantry completely square? Does the print head move freely to all corners and nothing is binding?
"Some filaments feel the rain, others just get wet"
- Bob Marley
Publié : 23/10/2025 10:43 pm
Forgot to add. When you run X and Y calibration, do they still pass?
- Bob Marley
Publié : 23/10/2025 11:09 pm
andhson
(@andhson)
This will be interesting, not only does it print the gyroid infill on a curve on top of a layer of straight lines, it follows the same curve consistently in that layer, that consistency throws me off. If the part lost adhesion I would expect much more of a mess, not consistent curves, if it bumped into something I would expect a shift and continued straight lines. If the part is oriented straight on the print surface my understanding is that both x and y steppers need to move go get a straight line, it is almost like a stepper is not able to keep up periodically, in any case it will be interesting to see what ends up being the root cause.
/Anders
Publié : 24/10/2025 8:58 am
chmax
(@chmax)
Is the "avoid crossing parameters"option set? Aside from the basics already discussed above, this seems to be the major culprit for layer shifts as it apparently generates such high speed directional changes that the printer loses it.
Publié : 24/10/2025 10:17 am
1 personnes ont aimé
andhson
(@andhson)
Posted by: @chmax
But there are no perimeters to cross on a single cube, why would that logic kick in? Otherwise I agree that setting has caused me pain on more complex objects and it makes sense to turn of until fixed properly.
/Anders
Publié : 24/10/2025 5:23 pm
chmax
(@chmax)
If you are building the perimeters from the inside out (standard behavior if I remember correctly) you would. That said, I don't know enough about the slicer to exclude any effects on a cube... I know that that's a bad param to choose 😁
Publié : 24/10/2025 6:15 pm
mnentwig
(@mnentwig)
"Gyroid" infill shakes the printer badly. It is rated among the worst offenders on the open-ended 3D printer Richter scale.
Is it simply the nozzle hitting the print, repeatedly?
Ce message a été modifié il y a 9 hours par mnentwig
Publié : 24/10/2025 6:48 pm
Posted by: @mnentwig
So far I've only seen layer shifts when my belts were grossly out-of-tune after I had just assembled the printer. And another time when I was printing PC and it severely warped causing the print head to crash into it.
- Bob Marley
Publié : 24/10/2025 7:20 pm
mnentwig
(@mnentwig)
yes, it's unlike the shaking alone would cause layer slip (unless something is loose, like belts as you said). My hypothesis is that the "dynamics" of the infill add up with other unwanted random mechanisms that bring the nozzle too close to solid material, such as too high extrusion factor, warping, etc.
Publié : 24/10/2025 8:31 pm
andhson
(@andhson)
But those curved infill lines, several of them with the same consistent curve does not look random but rather systematic, how could a slip or collision cause that? Then maybe I am too much stuck on them being significant, I just can’t figure out what caused them.
/Anders
Publié : 24/10/2025 9:33 pm
