RE: inconsistent layers
In short:
- layer time variation
- fan speed variation
- too fast to stay accurate
- too high acceleration values to stay accurate
- internal geometry changing too much from one layer to the next (like the bottom of a box ending and only thin walls from there etc.)
After slicing, select a different view in the top left menu. There are "Actual speed", "layer time" and "fan speed". Check if you see a similar pattern in the colors, as you see in the finished part.
Opublikowany : 16/07/2025 10:19 pm
