Heat Break Thermistor not connected
phil zphil
(@phil-zphil)
Utenti
Hy all
I just got my core one 2 days ago and of course i would not sleep until it was assembled.
During Assembly everything looked good and went well, but when i started the printer for the first time, i got an error message, that the heatbreak thermistor was not plugged in.
I double checked all the connections but all was good. Then i dissasembled the print head and inspected the Thermistor, but could not find any visual damage (grub screw has not been overtighend).
Next a measured the Thermistor with my multimeter and found 87kOhm at around 30 degree C. This seems reasonable for a 100k ntc thermistor.
Am i correct in the assumption, that the heatbreak resistor is the part which is fixed with a little grub screw to the Heat sink?
And does someone has an idea what could be wrong?
Greetings from Portugal
Questa discussione è stata modificata 4 months fa da phil zphil
Postato : 06/08/2025 1:00 pm
RobVB
(@robvb)
Utenti
RE: Heat Break Thermistor not connected
I am having the same issue. Tested the thermistor and getting 90Kohm and heater 15 ohms
Postato : 09/08/2025 6:52 pm
