					                		first layer - FW update - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-fw-update/</link>
                <lastBuildDate>Wed, 17 Jun 2026 16:40:48 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-fw-update/#post-781336</link>
                        <pubDate>Sun, 08 Feb 2026 07:44:31 +0000</pubDate>
                        <description><![CDATA[hello, i wrote with support and they advised me to clean the sheet with warm water and dishwashing liquid. i did it and now it seems to be good again. 
before i always used handgloves when ...]]></description>
                        <content:encoded><![CDATA[<p>hello, i wrote with support and they advised me to clean the sheet with warm water and dishwashing liquid. i did it and now it seems to be good again. </p>
<p>before i always used handgloves when i touch the sheet. sometimes IPA. but never the advised method. only one time, after the problems occured, i used acetone. i wonder how good the results now are.</p>
<p>but i flashed the firmware with v6.3.4 too. so its not sure if only the washing was the solution. </p>
<p>do you know if (and how) i can deactivate the info about new FW available every time i want to start a new print? its annoying.</p>
<p>so for now the problem is solved. lets have a look how long it would last. cheerio</p>
<p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/02/6f5917fd-20260206_215127-scaled.jpg"><img class="alignnone size-medium wp-image-184021" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/02/6f5917fd-20260206_215127-600x500.jpg" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Micha</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-fw-update/#post-781336</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-fw-update/#post-781199</link>
                        <pubDate>Sat, 07 Feb 2026 13:16:19 +0000</pubDate>
                        <description><![CDATA[How are you cleaning your build sheet?Cheerio,]]></description>
                        <content:encoded><![CDATA[<p>How are you cleaning your build sheet?</p><p>Cheerio,</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Diem</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-fw-update/#post-781199</guid>
                        <title>RE: first layer - FW update</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-fw-update/#post-781007</link>
                        <pubDate>Fri, 06 Feb 2026 08:22:44 +0000</pubDate>
                        <description><![CDATA[hello. every time i push the plate correctly in position. so thats not possible.next]]></description>
                        <content:encoded><![CDATA[<p>hello. every time i push the plate correctly in position. so thats not possible.</p><p>next </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-fw-update/#post-781007</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-fw-update/#post-780991</link>
                        <pubDate>Fri, 06 Feb 2026 02:27:04 +0000</pubDate>
                        <description><![CDATA[OK, let&#039;s try the easiest one first - I have seen this occur when the smooth sheet was not fully pushed into place and then shifted against the retaining pins.Cheerio,]]></description>
                        <content:encoded><![CDATA[<p>OK, let's try the easiest one first - I have seen this occur when the smooth sheet was not fully pushed into place and then shifted against the retaining pins.</p><p>Cheerio,</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-fw-update/#post-780991</guid>
                        <title>first layer - FW update</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-fw-update/#post-780950</link>
                        <pubDate>Thu, 05 Feb 2026 21:37:32 +0000</pubDate>
                        <content:encoded><![CDATA[<p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/02/6d44547d-20260205_223509-scaled.jpg"><img class="alignnone size-medium wp-image-183998" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/02/6d44547d-20260205_223509-600x500.jpg" alt="" width="600" height="500" /></a> <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/02/35ab393a-20260205_223515-scaled.jpg"><img class="alignnone size-medium wp-image-183999" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/02/35ab393a-20260205_223515-600x500.jpg" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-fw-update/#post-780950</guid>
