first layer - FW update
Micha
(@micha-4)
Opublikowany : 05/02/2026 9:37 pm
OK, let's try the easiest one first - I have seen this occur when the smooth sheet was not fully pushed into place and then shifted against the retaining pins.
Opublikowany : 06/02/2026 2:27 am
Micha
(@micha-4)
RE: first layer - FW update
hello. every time i push the plate correctly in position. so thats not possible.
next
Opublikowany : 06/02/2026 8:22 am
How are you cleaning your build sheet?
Opublikowany : 07/02/2026 1:16 pm
Micha
(@micha-4)
hello, i wrote with support and they advised me to clean the sheet with warm water and dishwashing liquid. i did it and now it seems to be good again.
before i always used handgloves when i touch the sheet. sometimes IPA. but never the advised method. only one time, after the problems occured, i used acetone. i wonder how good the results now are.
but i flashed the firmware with v6.3.4 too. so its not sure if only the washing was the solution.
do you know if (and how) i can deactivate the info about new FW available every time i want to start a new print? its annoying.
so for now the problem is solved. lets have a look how long it would last. cheerio
This post was modified 4 months temu by Micha
Opublikowany : 08/02/2026 7:44 am
