					                		First Layer Adhesion Issues on Prusa Core One Due to Excessive Nozzle-to-Bed Distance - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/</link>
                <lastBuildDate>Wed, 20 May 2026 04:04:00 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741843</link>
                        <pubDate>Sat, 22 Mar 2025 21:27:07 +0000</pubDate>
                        <description><![CDATA[You do have a clean nozzle before you start?, as homing will need the build plate to touch the nozzle tip to get a good zero level, filament blobs may affect this.
It just seems that is an ...]]></description>
                        <content:encoded><![CDATA[<p>You do have a clean nozzle before you start?, as homing will need the build plate to touch the nozzle tip to get a good zero level, filament blobs may affect this.</p>
<p>It just seems that is an extraordinary large gap for homing to have worked.</p>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Chocki</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741843</guid>
                        <title>RE: First Layer Adhesion Issues on Prusa Core One Due to Excessive Nozzle-to-Bed Distance</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741313</link>
                        <pubDate>Thu, 20 Mar 2025 11:31:44 +0000</pubDate>
                        <description><![CDATA[Yes it should work.  During the first layer press and hold the control knob. That being said something does seem to be off as the initial bed probing shouldn&#039;t be that far off. Have you grea...]]></description>
                        <content:encoded><![CDATA[<p>Yes it should work.  During the first layer press and hold the control knob. </p><p>That being said something does seem to be off as the initial bed probing shouldn't be that far off. </p><p>Have you greased your lead screws.  Some have had issues with them binding up. </p><p>Also check to make sure the nozzle is not loose.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Brian</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741313</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741310</link>
                        <pubDate>Thu, 20 Mar 2025 11:17:19 +0000</pubDate>
                        <description><![CDATA[live z: is this also possible with the core one? are you sure? i tried it, it didn&#039;t work.prolife: no I have a special filament profile for dental models and greentec pro filament.]]></description>
                        <content:encoded><![CDATA[<p>live z: is this also possible with the core one? are you sure? i tried it, it didn't work.<br /><br />prolife: no I have a special filament profile for dental models and greentec pro filament.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>A. H.</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741310</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741309</link>
                        <pubDate>Thu, 20 Mar 2025 11:14:29 +0000</pubDate>
                        <description><![CDATA[You can lower the Z anytime during the first layer by pressing and holding the control knob. That will open up the live Z.Are you using a default filament profile?]]></description>
                        <content:encoded><![CDATA[<p>You can lower the Z anytime during the first layer by pressing and holding the control knob. That will open up the live Z.</p><p>Are you using a default filament profile?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741309</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741305</link>
                        <pubDate>Thu, 20 Mar 2025 10:38:08 +0000</pubDate>
                        <description><![CDATA[Then I think this is Prusa Support issue]]></description>
                        <content:encoded><![CDATA[<p>Then I think this is Prusa Support issue </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Simon</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741305</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741302</link>
                        <pubDate>Thu, 20 Mar 2025 10:22:45 +0000</pubDate>
                        <description><![CDATA[yes]]></description>
                        <content:encoded><![CDATA[<p>yes</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741302</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741301</link>
                        <pubDate>Thu, 20 Mar 2025 10:21:50 +0000</pubDate>
                        <description><![CDATA[Have you tried -&gt; Printer menu -&gt; Control -&gt; Calibration and Tests - Z Alignment Calibration]]></description>
                        <content:encoded><![CDATA[<p>Have you tried -&gt; Printer menu -&gt; Control -&gt; Calibration and Tests - Z Alignment Calibration </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741301</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741299</link>
                        <pubDate>Thu, 20 Mar 2025 10:12:13 +0000</pubDate>
                        <description><![CDATA[on these photos you can see, that the distance between nozzle and bed is too big. with the older prusa models I could adjust it calibrating the first layer (z).]]></description>
                        <content:encoded><![CDATA[<p>on these photos you can see, that the distance between nozzle and bed is too big. with the older prusa models I could adjust it calibrating the first layer (z).</p>
<p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/51fdf314-img_1045-rotated.jpg"><img class="alignnone size-medium wp-image-175262" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/51fdf314-img_1045-600x500.jpg" alt="" width="600" height="500" /></a> <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/29804179-img_1040-rotated.jpg"><img class="alignnone size-medium wp-image-175263" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/29804179-img_1040-600x500.jpg" alt="" width="600" height="500" /></a> <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/1357d9dd-img_1039-rotated.jpg"><img class="alignnone size-medium wp-image-175264" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/1357d9dd-img_1039-600x500.jpg" alt="" width="600" height="500" /></a> <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/1e340d84-img_1050-rotated.jpg"><img class="alignnone size-medium wp-image-175265" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/03/1e340d84-img_1050-600x500.jpg" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741299</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741075</link>
                        <pubDate>Wed, 19 Mar 2025 01:24:00 +0000</pubDate>
                        <description><![CDATA[Can you post some photos of the first layer?]]></description>
                        <content:encoded><![CDATA[<p>Can you post some photos of the first layer?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Biomech</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741075</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741014</link>
                        <pubDate>Tue, 18 Mar 2025 18:44:19 +0000</pubDate>
                        <description><![CDATA[Try to clean it with warm water and dish soap using a soft brush, especially when it´s new.After each print I clean it with alcohol and wipe it with a soft textile.You have to be careful wit...]]></description>
                        <content:encoded><![CDATA[<p>Try to clean it with warm water and dish soap using a soft brush, especially when it´s new.</p><p>After each print I clean it with alcohol and wipe it with a soft textile.</p><p>You have to be careful with what you wipe it. There are a lot of products like handkerchiefs which contains some kind of fat (for skin care).</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>James Kirk</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/first-layer-adhesion-issues-on-prusa-core-one-due-to-excessive-nozzle-to-bed-distance/#post-741014</guid>
