First Layer Adhesion Issues on Prusa Core One Due to Excessive Nozzle-to-Bed Distance
A. H.
(@a-h)
Dear Prusa Community,
I've been experiencing issues with the first layer adhesion on my Prusa Core One printer. It appears that the nozzle is too far from the print bed during printing, leading to poor adhesion. As the Core One utilizes a fully automatic first layer calibration system with its Load Cell sensor, I'm unable to manually adjust the nozzle height as I could with previous models.​
Here are the steps I've taken so far:
Nozzle and Bed Cleaning: I ensured that both the nozzle and the print bed are clean, using isopropyl alcohol to clean the print surface and removing any filament residue from the nozzle.​
Bed Leveling: I verified that the print bed is level and that there are no obstructions hindering the movement of the print head or bed.​
Despite these efforts, the first layer adhesion remains problematic. Given the automatic calibration system of the Core One, I'm uncertain how to proceed to adjust the nozzle-to-bed distance. I would greatly appreciate any advice or recommendations from the community to resolve this issue.
Thank you in advance for your assistance.
Postato : 18/03/2025 4:54 pm
1 persone hanno apprezzato
Simon
(@simon-11)
RE: First Layer Adhesion Issues on Prusa Core One Due to Excessive Nozzle-to-Bed Distance
I gave up using isopropyl alcohol  a few years ago when I realised all you have to do is use a green scourer pad after each print... never had any issues ever since... every print sticks perfectly even 4mm connectors
Postato : 18/03/2025 5:17 pm
James Kirk
(@james-kirk)
Try to clean it with warm water and dish soap using a soft brush, especially when it´s new.
After each print I clean it with alcohol and wipe it with a soft textile.
You have to be careful with what you wipe it. There are a lot of products like handkerchiefs which contains some kind of fat (for skin care).
Postato : 18/03/2025 6:44 pm
Biomech
(@biomech)
Can you post some photos of the first layer?
Postato : 19/03/2025 1:24 am
A. H.
(@a-h)
on these photos you can see, that the distance between nozzle and bed is too big. with the older prusa models I could adjust it calibrating the first layer (z).
Questo post è stato modificato 1 year fa da A. H.
Postato : 20/03/2025 10:12 am
Simon
(@simon-11)
Have you tried -> Printer menu -> Control -> Calibration and Tests - Z Alignment Calibration
Postato : 20/03/2025 10:21 am
A. H.
(@a-h)
yes
Postato : 20/03/2025 10:22 am
Simon
(@simon-11)
Then I think this is Prusa Support issue
Postato : 20/03/2025 10:38 am
Brian
(@brian-12)
You can lower the Z anytime during the first layer by pressing and holding the control knob. That will open up the live Z.
Are you using a default filament profile?
Postato : 20/03/2025 11:14 am
A. H.
(@a-h)
live z: is this also possible with the core one? are you sure? i tried it, it didn't work.
prolife: no I have a special filament profile for dental models and greentec pro filament.
Postato : 20/03/2025 11:17 am
Brian
(@brian-12)
Yes it should work.  During the first layer press and hold the control knob.
That being said something does seem to be off as the initial bed probing shouldn't be that far off.
Have you greased your lead screws.  Some have had issues with them binding up.
Also check to make sure the nozzle is not loose.
Postato : 20/03/2025 11:31 am
Chocki
(@chocki)
You do have a clean nozzle before you start?, as homing will need the build plate to touch the nozzle tip to get a good zero level, filament blobs may affect this.
It just seems that is an extraordinary large gap for homing to have worked.
Questo post è stato modificato 1 year fa da Chocki
Postato : 22/03/2025 9:27 pm
2 persone hanno apprezzato
