					                		Filament Blob Forming Around Nozzle – Need Help - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/filament-blob-forming-around-nozzle-need-help/</link>
                <lastBuildDate>Fri, 06 Mar 2026 09:11:21 +0000</lastBuildDate>
                        <title>RE: Filament Blob Forming Around Nozzle – Need Help</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/filament-blob-forming-around-nozzle-need-help/#post-748569</link>
                        <pubDate>Mon, 05 May 2025 11:03:36 +0000</pubDate>
                        <description><![CDATA[Thank you both. That was really helpful. I think it was actually the bed. Once everything got cleaned and I removed the blob all further prints worked out great again]]></description>
                        <content:encoded><![CDATA[<p>Thank you both. That was really helpful. I think it was actually the bed. Once everything got cleaned and I removed the blob all further prints worked out great again</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Daniel Winter</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/filament-blob-forming-around-nozzle-need-help/#post-748569</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/filament-blob-forming-around-nozzle-need-help/#post-748264</link>
                        <pubDate>Fri, 02 May 2025 10:03:24 +0000</pubDate>
                        <description><![CDATA[You have a small blob of doom; search here under that name to find how others have dealt with them.They are less frequent nowadays as recent printers take care of first layer settings so the...]]></description>
                        <content:encoded><![CDATA[<p>You have a small blob of doom; search here under that name to find how others have dealt with them.</p><p>They are less frequent nowadays as recent printers take care of first layer settings so the commonest cause is now poor adhesion due to dirty print-sheets, very often fingerprints.</p><p>Search here for threads about bed cleaning - I would use dishwashing detergent (Dawn/Fairy) and very HOT water.</p><p>Yes, there are a few signs that humidity might be having a detrimental effect but this is not the cause of your current problem.</p><p>Cheerio,</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Diem</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/filament-blob-forming-around-nozzle-need-help/#post-748264</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/filament-blob-forming-around-nozzle-need-help/#post-748253</link>
                        <pubDate>Fri, 02 May 2025 09:02:15 +0000</pubDate>
                        <description><![CDATA[Hello there!First of all, remove the silicone cap from the heatblock assembly and warm up the nozzle to 170 C. After a couple of minutes that blob will be easier to remove from the assembly ...]]></description>
                        <content:encoded><![CDATA[<p>Hello there!</p><p>First of all, remove the silicone cap from the heatblock assembly and warm up the nozzle to 170 C. After a couple of minutes that blob will be easier to remove from the assembly with a pair of pliers or something. Then purge some filament a few times, just to make sure that there is no filament stuck.</p><p> </p><p>I would assume that your problem is that the first couple of layers don't stick to the sheet. Try cleaning carefully with IPA before each print. Also, from this<a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/05/013b94d2-extrusion.jpg"><img class="alignnone size-full wp-image-176595" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/05/013b94d2-extrusion.jpg" alt="" width="305" height="246" /></a></p><p>I would say that you have some extrusion problems.</p><p> </p><p>Lastly, is that part crooked normally or is it somehow damaged?</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/05/6696ec88-wtf.jpg"><img class="alignnone size-full wp-image-176596" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/05/6696ec88-wtf.jpg" alt="" width="212" height="238" /></a></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>AvariCe</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/filament-blob-forming-around-nozzle-need-help/#post-748253</guid>
                        <title>Filament Blob Forming Around Nozzle – Need Help</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/filament-blob-forming-around-nozzle-need-help/#post-748243</link>
                        <pubDate>Fri, 02 May 2025 06:23:07 +0000</pubDate>
                        <description><![CDATA[Hey everyone, I’m new to 3D printing and could use some help. I’m running into a strange issue where filament builds up around the nozzle and eventually forms a big blob of material. This ha...]]></description>
                        <content:encoded><![CDATA[<p>Hey everyone, I’m new to 3D printing and could use some help.</p><p> </p><p>I’m running into a strange issue where filament builds up around the nozzle and eventually forms a big blob of material. This has now happened twice, even though the print before worked perfectly.</p><p> </p><p>I’m using PLA that was dried and stored properly in my Polymaker container. The printer is set up in my workshop, which has relatively high humidity—around 60%.</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/05/f244c46a-img_4515-scaled.jpeg"><img class="alignnone size-medium wp-image-176591" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/05/f244c46a-img_4515-600x500.jpeg" alt="" width="600" height="500" /></a> <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/05/ccf8de65-img_4516-scaled.jpeg"><img class="alignnone size-medium wp-image-176592" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/05/ccf8de65-img_4516-600x500.jpeg" alt="" width="600" height="500" /></a></p><p>Any idea what could be causing this? Really appreciate any suggestions!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-assembly-and-first-prints-troubleshooting/filament-blob-forming-around-nozzle-need-help/#post-748243</guid>
